Question about Dedicated Micros Digital Sprite 2 RS Video Recorder
Changing hard disk in sprite,How - Dedicated Micros Digital Sprite 2 RS Video Recorder
  • 3,976 Answers
Replace hard drive formatted to FAT32. download the software from there web site put the files on the hard drive this is master drive. slave drive format to FAT32. make drive slave and install. can put max 500gb sata drives with converters any higher drives and risk the system to fail that is 2 500gb sata drives. ruffley 926gb or 982gb depending on what the drives are.
Posted on Oct 06, 2013
Internal error-cannot load data for alert fsi open err4
the slave drive has a fault. would say it needs changing. system records onto hard drive one then send to hard drive 2 at its peek. now this can be 10gb. but alert data is stored on slave drive. unless your model has cd rom then it has 1 hard drive formatted in to 2 drives. if this is the case then your hard drive has picked up a fault wile in use. you would need a new hard drive and down load the soft wear for you system. format the hard drive in fat32 and split the drive into 2. D/E then put the hard drive in system. Now the software will be in a iso file so that will need to be burned to a disk. then put the disc into drive. now turn on system and hold down camera 2 for 5-10 seconds you should see the light on the cd rom light up and it should re-boot to new system. now you just need to set the system back up to the way you want it. hope this helps you.
Apr 11, 2013 | Dedicated Micros Digital Sprite 2 RS Video...
Digital Sprite 2 screen freezes, reboot good for a few hours then freezes again.
check the system fans they need changing every 2 years. check the hard drive-s are not over heating should be changed every 4 years. check the psu is giving out the right volts can be checked on the hard drive plug when system is plugged in if voltage is to low 12.83v is fine 5.8volts is fine under the 12v or 5v mark it makes the system crash freeze up or just the red light flashing and a buzzing sound coming from the system. psu if you don't hear a fan going round then the psu has over heated and the power coming out will have dropped. replacement capacitors and fan can be found on the bay cheap make note were they are and replace. fan is a bearing type and costs a bit more. can use a none bearing type but it will need changing every year. 12v type think it was a 30mm or 40mm type.
Jan 30, 2013 | Dedicated Micros Digital Sprite 2 RS Video...
I need to know what the specs would be for the case cooling fans so I can replace them.
40mm fans 5v bearing type. or you can change them to 12v fans same size and hook them up to the hard drive power leads. 2w fans only.
Dec 13, 2010 | Dedicated Micros Digital Sprite 2 RS Video...
Password of sprite backup lost after hard reset of my HTC S710. After hard reset, sprite backup tool ask for password during backup process from memory card. But unfortunately I don't know the password.How...
Hi nayan_cse50 I really would appreciate if you can help me cause I do have now the same problem you posted 9 months ago. The backup file to restore all my lost data asks me for a password I never wrote (or at least I can't remember). Could u help me, please?
May 07, 2010 | HTC S710 Smartphone
Sega Genesis sprite problems
Need to change the cartrage reader or get a new one sorry
Mar 28, 2010 | Sega Genesis Console
Sprite 2,digital recorder
Have you tried replacing the PSU, these units are fussy about their power requirements.
Mar 09, 2009 | Dedicated Micros Digital Sprite 2 RS Video...
Contacts copy from Nokia E50 to HTC touch
You don't need Sprite back up to sync contacts.All you need is ActiveSync 4.5 (for WinXP) or WMDC (for Vista). When installed connect your htc device and follow onscreen instruction. You can choose in settings what to sync.
Jan 23, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Random shutdown and hard reset
I had a similar problem and it turned out that there was a backup program called ´Sprite´ that was loading an image file of the system after every hour of use, erasing all changes to the configuration and saved data.
The folder of the ´Sprite´ program has a text file with the configuration data. I opened the text file and set autoexec. and similar options to ´false´ and saved the file again. After that, the problem had disappeared.
Regards,
Joep
Jul 31, 2008 | HP iPAQ h6315/h6365 Pocket PC
Televison & Video Logo
216 people viewed this question
Top Dedicated Micros Televison & Video Experts
jason
electracon
 Russ Hill
Russ Hill
Are you a Dedicated Micros Televison and Video Expert? Answer questions, earn points and help others
