Question about Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive
Cant seem to remove the "write protection" error off my store and go micro flash
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 144 Answers
It has password protection. Open My Computer on your PC, insert the USB drive, open the password file, enter your password, then select the option to remove password protection from the USB drive. If this does not work, contact Verbatim for a solution, these USB flash drives have lifetime warranties.
Posted on Oct 24, 2013
Format error
If you are getting a protected message then the data cannot be erased . there should be a way that you can remove the protected tag but you may have to have administrator status to do it. Find a good IT shop and talk to the technician as to how to do it.
May 31, 2013 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I can't seem to remove write protection from this disk to format it. It is and 8gb usb device. It tells me it's write protected whenever I try to fix it.
Try with my property click here , choose download - and download winsetup from usb.
Try format with this software ,
if still error, contact me.I will help you my friend.
Jun 16, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Hi friends, Actually I've a 2GB Micro SD it displays "Writing Protected" error while I trying to format it in windows environment with Third Formatting tool and It displays "msdc write...
Check the little white switch on the side of the memory card. That is the write protection switch. Turn it to the off position and try formatting again.
Apr 22, 2011 | SanDisk 2GB microSD Memory Card
I have a verbatim 4gb micro with a write protect error. I cannot delete the files, add more files or format the stick. Regards Mano
Jan 06, 2011 | Verbatim CORPORATION 94933 USB 2.1GB...
I am unable to copy files to my memory card the system is displaying the error as " disk is write protected "
1.Look for a switch or button on the side of the micro SD card or adapter. It might have a lock/unlock symbol on it. 2.Move the switch to the "Unlocked" position to remove write protection. This position may also be labeled "R/W" for read/write. If you have no switch, continue to Step 3. 3.Download and install Sony EzRecover (see Resources for link) and attempt to use it to format the card (this will erase all content). If this doesn't work, try Step 4. 4.Delete and repartition the micro SD card using Windows XP. Select "Control Panel" > "Administrative Tools" > "Disk Management." Select the micro SD drive and click "Delete." Right-click on empty drive and select "New Partition."
Dec 22, 2010 | SanDisk 2GB microSD Memory Card
I tried using store function but a pop-up states: "Variable or flash application is locked, protected, or archived." what do i need to do to fix it?
You may be trying to store the function in a folder that already contains that function or name. Its called Error Folder, and you will get the errors you mentioned. Try copying the function under the same name to another folder. Go to the other folder, the one you just copied your function too and, rename the function something you don't think will conflict with the original folder. Simply store your function with the new name in the original folder. That should work, and hopefully you won't get any errors.
Dec 21, 2010 | Texas Instruments TI-89 Calculator
How do I remove write protection from micro scan disk chip?
if you will look into the side of your SD CARD. theres a small toggle switch there. just slide it to the other side inorder to disable the write protection
Apr 03, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I hav 4gb pendrive of transcend.It cant be formatted becoz of write protection.How to remove write protection? and it cant be able to store information
hi
go to this link
http://www.transcendusa.com/Support/DLCenter/index.asp?LangNo=0&Func1No=11&Func2No=182
put your model name of your pen drive and search ... you will get the software to remove write protection.. install that software and remove write protection..
thats all...
have a nice day..
-rajkumar
Jun 04, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Cant format
you can remove the write protection status by inserting it to your camera and in the preview mode click the button menu, in that scroll down for options and you can see there the option for protection on or off. toggle that option.thanks for using fixya!. please dont forget to rate my solution.
May 28, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
How to Unprotect a Write Protect Flash Drive
how to unprotect a write protect my flash drive & i cant copy paste any of my files to my flash drive it gives an error
error drive not found
Oct 18, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive Logo
135 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Arora Singh
Arora Singh
Computer Links
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
