Question about Canon PIXMA MP210 Photo All-In-One Printer
Click on the link below to download the Canon MP210 driver:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp210
Posted on Feb 04, 2011
SOURCE: CANON PIXMA MP 210
The MP210 does not support Win98 so you won't ever find the perfect driver.
Posted on Apr 25, 2008
SOURCE: canon pixma mp 210
hej ljudi kako da resetujem kertridze za moj canon mp210,posle prvog punjenja ne radi.
Posted on Jul 06, 2008
SOURCE: Canon PIXMA MP 210- Setup CD doesnot work
All cannon Drivers are available on Cannon web site, try with the link given www.canon-asia.com.
Posted on Jul 14, 2008
SOURCE: Canon MP 210 gives E5
In fact the noise/E52 service problem might be easy to fix:
You just have to oil the mirror motor shaft in the laser unit.
Step-by-step instruction:
1 – Remove gently the top cover of the printer ( 4 screws – 2 on top/front + 2 in back/side).
2 – Be careful with the connectors going to the top LCD panel. You might want to disconnect the shorter one.
3 – Remove the laser unit located on top of the printer covered by a steel plate.
To do that:
1 – Unplug (pull) the white flat connector going to the left side of the laser unit.
2 – Unscrew the 3 screws keeping the laser unit in place.
3 – The lower/right screw also maintains in place the second connector going to the unit. Remove it and unplug (pull) the connector.
4 – Squeeze out the laser unit from under the wires (going back and up).
You now have the laser unit outside of the printer.
1 - Remove the steel plate of the laser unit. There is a plastic shutter that will come loose. Don’t loose it and take note of its location in case you need to put it back.
2 – Unscrew the 4 screws maintaining the motor section and remove it.
3 – There is a small piece of black plastic that maintains the top part of the motor unit (with the mirrors) on the left side of the board. Twist it and remove it.
4 – Pull up the mirror part.
5 – Be careful during all that not to touch any of the mirrors or prism or whatever seems to conduct light. If you do, you can always clean with isopropyl alcohol or glasses solution.
6 – Put some sewing machine oil on the shaft. Juuuust a little. I used machine oil SAE 20 or 40 (not sure – I didn’t look). WD40 would probably work also. Again, not too much – wipe the excess.
7 – Put everything back together.
good luck
Posted on Jun 21, 2009
Feb 25, 2012 | Canon PIXMA MP210 Photo All-In-One Printer
Aug 02, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Feb 16, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Nov 20, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Nov 05, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Aug 03, 2008 | Office Equipment & Supplies
Jul 12, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Apr 05, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Mar 27, 2008 | Office Equipment & Supplies
79 people viewed this question
