Windows running slow tried antivirus and registry fix regcure plus other reg fixers no joy
    Champion:
  • 214 Answers
Hi, please let me know
1) operating system
2) RAM size
3) size of the partition where the OS is loaded
thank you
Posted on Jul 07, 2008
Not working my cd drive.
If you are running Windows 7 you can use C Cleaner or Windows 7 Manager to clean up your registry if you don't have them you can download Regcure or Registry First Aid to clean up the reg error then you can restart your computer and see if windows can reinstall your hardware.
Oct 20, 2012 | OEM Systems Acer Aspire 5742g Dvr-td11rs...
My pc is running really slow... can u please help me????!!!!?????
There are a number of reasons but mainly 2 kinds causing a PC running slow. Outdated hardware or poor system maintenance. If possible, try upgrade hardware configuration such as add more RAM etc. Otherwise try this program Speed up PC to diagnose & fix the slow pc for issues. Best regards!
Jul 17, 2011 | Computers & Internet
After installing McAfee on my computer, it seems to lag. It is very annoying...starting up and shutting down can take a minute! WEb browsing began to lag too? Is the antivirus to be blamed? My computer is...
mostly antivirus slows the pc, u have to clean up ur system, clean registry keys, to speed up ur pc download registry cleaner reg in out , it will speed ur pc
Sep 11, 2010 | Microsoft Windows XP Home Edition
My computer is very slow
Windows Vista has a bad reputation of being dumb and slow. Windows XP and Windows 7 are way better in this respect. If you are using Windows Vista make sure that your RAM is at least 1 GB and your processor should be around 1GHz. If this is not so upgrade will definitely help. Just follow the below instructions to enhance your PC's speed.
(1) Keep your PC free of viruses especially if you extensively use the internet. Always keep a good updated Antivirus on your computer all the time and make sure you do not install more than one Anti virus on a single computer it is not recommended.
(2) Keep your Windows registry clean. Use a good registry cleaning software like RegCure and keep it updated. This also makes a good difference.
(3) Clean your Hard disk of all unwanted stuff manually and you can use disk cleaning utility of Windows also. To locate Disk clean just right click on any Hard disk partition (C:, D: etc) and take the properties of it. You will see a pie chart just beside that you will find the disk cleaning button to remove unnecessary files in your PC and boost its speed.
(4)After disk cleaning "Defrag" your disk also if possible. Just right click on a disk partition and go to properties you will see a window and on top you will see a tab "Tools" click that and you will find "Disk Defragmentation".
Make sure it happens.and your PC will be running fast in no time.
Sep 01, 2010 | Microsoft Windows Vista Home Premium with...
Will not load games
First of all get a good Antivirus software and scan your PC thoroughly after UPDATING it. Updating the Virus software is extremely important.
Secondly after doing the above step install a Registry cleaning software. I recommend Uniblue Registry booster or Regcure. Virus and unclean registry are number 1 reasons to PC slow down.
Check your hard disk if it is near to full. Use the Windows built in disk cleaning software to clean unnecessary files. After that De-fragmenting the disk will also help a lot. To de-fragment a disk Go to accessories in the start menu and then go to system tools. Find disk de-fragmentation and run it the PC performance will dramatically enhance but Virus and registry cleaning is recommended to be done first.
Jul 26, 2010 | HP Computers & Internet
My son's PC *always* needs to be booted twice to get it up in Windows XP Pro. For some reason it hangs during the first boot. Once it hangs you have to push'n'hold the power button to force shutdown, and...
You can do a bit of detective work and run MSCONFIG.EXE froma command prompt and go through that - particularly the boot, services and startup entries. The startup entries in particular - as from there you can select what is and what is started at startup - and a process of elimination can maybe help you track down the problem. 'Registry cleaners' may help - but often are more problematic themselves thn they are 'fixers'. You could edit the registry by hand, using regedit, but that is NOT recommended unless you really know what you are doing. Do note that if you change the start-up programs (i.e. change their enable state), you will get a warning at start-up that you are running a custom start-up using msconfig.
As a last resort, a fresh installation of Windows will fix things. Running a virus checker might also be a good idea.
Allan
Nov 03, 2009 | Computers & Internet
CCleaner
RegCure has done it again!
pls follow these steps >>
remove RegCure from Add/Remove programs in Control Panel then exit the program
click the start button, then Run and in the dialog box, type "msconfig" (without the qoute) and press ok
in the System Configuration Utility window, select the startup tab
uncheck the box with the RegCure entry then click apply and ok, then choose 'exit without restart'
download and install this (Absulutely) free utility >>> http://www.ccleaner.com/
first run Cleaner (click the cleaner button / analyze / run cleaner
second Registry (click Registry button/ scan for issues / fix selected issue
no need to back-up changes just select fix selected issues
when done restart your computer
when a message box appear regarding the system configuration, just click on the box which says 'do not show this message again and click OK
hope this solves your problem
if problem persists see me in YM cpenny29@yahoo.com
Oct 24, 2008 | Microsoft Windows XP Home Edition
I have tried to uninstall Norton 360 to install a newer version but an error 21 message keeps appearing. Help please
Error 21is caused by missing System files or damaged registry stuctures.The only way i think you can repair it is to download Regcure and scan your PC.Once the Registry is repaired you can then uninstall Nortonshttp://simple-pc-help.com/support/downloadb.php
Jul 30, 2008 | Computers & Internet
Audio
If your computer is running kind of sluggish, you can fix it with an easy clean up of your registry. Here's a link to a free scan that works well:
www.your-free-info.com/RegCure
I've used this one and it sped up my computer by quite a bit. Hopefully this helps.
May 10, 2008 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
David Payne
David Payne
