Question about HP LaserJet P2015 Printer
HP laserjet p2015 printing problem
I have spent days trying to fix this problem. When we go to print something to this printer it will put some spaces in some of the words. like lets say I type I am a god in a word doc and click print. I will print out I am a g od. I have no idea how to fix this. It is not any of the computer's. we print to a laser 2200 and it does not do this. Any one have any ideas?
  • robertld Jul 07, 2008
    Just bought it a month ago. Got the last drivers to it.Also running windows xp. No accessories is fitted to it.
  • robertld Aug 12, 2008
    Come to find out I hope date the drivers to the newest one out. That fixed the problem. So hp most have talk to a lot of people having the same problem. thank you all of you guys for your help.
Posted on Aug 12, 2008
In the print driver, disable font subsititution.
This is a common problem with HP printers. Basically, for certain fonts like Arial and Times New Roman, the driver will say "use the built in printer font (Helvetica or Times)" instead of downloading the TrueType font to save time and get the print job out faster. The problem is that the printer engine misrenders the text if there's a double-space in the line, such as following a period at the end of the sentence. This doesn't seem to be a problem for fonts that are downloaded to the printer with the document.
Here's the test: remove all the double-spaces (not line spaces, but character spaces) from your messed-up document and print it out. It will probably look OK.
Chances are you were taught in typing class to double-space after a period at the end of a sentence. This is correct for monospace fonts such as on a typewriter, but for variable space fonts, the computer will add the correct amount of space after the period, so you don't need to hit the spacebar twice. I usually just disable all the font substitution because that's easier than retraining your typists.
  • HP Master
  • 691 Answers
How old id the printer. What OS do you use. What driver version do you have and does the printer have any accessories fitted?
Posted on Jul 07, 2008
  • Inky Fingers
    Inky Fingers Jul 07, 2008
    If the printer is only a month old your best coarse of action is to get HP out to it. There could be a problem with the formatter board.
    If the machine is connected via USB, change the cable and test it again. If the machine is connected via NIC try a direct connection to one PC using a crossover cable and test it again.
    If no change in either state, get HP out to it.
P2015 laserjet printer is giving black printing
Hi check the toner, if you have one for testing may be old and will take away the doubt
Jun 30, 2014 | HP LaserJet P2015 Printer
HP LaserJet P2015 i can't printing on both side page.
If your printer does not have a duplex unit then the printercannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn thepage upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for therest of the document.
I suggest you try a test page first, to get the printing the right way up onboth sides of the page so it reads correctly.http://www.fixya.com/support/r7325259-double_sided_printing_using_single_sided
Jan 04, 2012 | HP LaserJet P2015 Printer
I replaced a hp laserjet p2015 printer with another hp laserjet p2015 printer but it can't print.what's the problem,pls help me
This HP printer is comes with the USB cable. To install the printer software, you need to install the USB driver compatible to your printer and then it will ready to print.
Dec 08, 2010 | HP LaserJet P2015 Printer
I have a HP LasterJet P2015. I am trying to print multiple page PDF file documents and after one page has printed, the triangle and "!" light flashes and a print out says insufficient memory. How do I...
Open Printer options and reduce the print quality. It is probably 1200dpi. Make it 600 and try the print again.
You may also add more printer memory to print complex documents on highest resolution possible.
Aug 06, 2010 | HP LaserJet P2015 Printer
I have HP 2015dn printer. In Windows XP I can print duplex automatically. In Windows 7, when I installed the printer, it uses the default driver from Windows. When I tried to print duplex, it printed the...
No there isn't that's the biggest problem with Win 7. DRIVERS.. if they aren't expressly written for Win 7. Then it is all just one big headache. In saying that sometimes installing as Admin, & in XP SP2 Compatibility Mode, helps.
Feb 03, 2010 | HP LaserJet P2015 Printer
Not printing
Please open the manual feed and try to print using manual feed if you are able to print fine using manual feed that check pickup roller of Tray 2.
First of try to print using Manual feed and let me know if it is printing from Manual feed or not.
Jun 30, 2009 | HP LaserJet P2015 Printer
I could not print with hp laserjet p2015 usinh window vista
hi there,
Is the drivers of P2015 correctly installed on vista? If yes then you have to check your printer USB cable. Try to change it and see the result.
Good luck
Jun 24, 2009 | HP LaserJet P2015 Printer
HP P2015 prints horizontal lines across paper
you shuld replace the cleaning blade inside the drum!
Jun 23, 2009 | HP LaserJet P2015x Printer
Printer sends error message HP p2015
As mentioned above, install the universal PCL 5 drivers from HP website. This will fix the error.
Feb 23, 2009 | HP LaserJet P2015 Printer
HP LaserJet P2015 Printer Logo
355 people viewed this question
Ben Johnson
