Question about Optoma EP706 Projector Remote Control
When i start my projector i saw remote enter security code.. i dont have it plz help me
I hava Nokia 2730 Classic I reset my phone but forget the security code I can't enter * in security code\ help me pz
Plz enter 12345, 1122, 0000 these universal codes. if they dont work then plz reinstall its software problem will be quickly solved. Best Regards
May 27, 2011 | Nokia 2730 Cell Phone
Dear friend, I have a nokia 3110c phone. My kid entered wrong security code and it is locked and when i entered the security code my phone showing code error. Please help me. My IMEI code is...
there is nothing wrong just leave your phone switched on and dont use it for 1 hour and then enter your security code your phone will be unlocked INSHALLAH
Jun 13, 2010 | Nokia 3310 Cellular Phone
Projector buttons locked
unfortunately, you need the remote. fortunately, you can use almost any sharp projector remote (same code). when you do get one, press (in this order)- menu, enter, enter, menu, undo, undo, menu.
Jul 16, 2009 | Sharp Notevision PG-B10S Multimedia...
Security code for nokia 5310
Hi barry frl,
Goto this link and enter the IMEI code of your mobile.
You'll get your master reset code! using that code you can unlock ur mobile..
If its helpful, plz do vote for me!!
Jan 25, 2009 | Nokia 5310 Cellular Phone
Forgot d keypad password.........
hello,patel.......
reset ur security code..... this wil help u.......
pls enter *#7328748263373738# this wil resets security code....
Default security code is 12345
Nov 27, 2008 | Nokia N70 Cellular Phone
Security code for Nec lt260 multimedia projector
The menu and logo password are the only ones you can reset by yourself, if you lose your master password you must contact NEC to get the release code.
See page 113 on the manual :
NOTE: Do not forget your keyword. However, if you forget your keyword, NEC or your dealer will provide you with your Release Code.
After you call NEC and get the code do the following:
1. Press and hold the POWER button for a minimum of two seconds.
The projector will be turned on and display a message to the effect that
the projector is security-protected.
2. Select [Projector Options] → [Security] from the menu and press hte ENTER
button.
The Release Code input screen will be displayed as well as your Request
Code (24 alphanumeric characters).
3. Enter your Release Code in the Release Code Input screen.
The projector will turn on.
* If the projector is turned on by entering the Release Code, your Security
will be disabled.
find contact page from here or call the retailer:
NEC Global
Here is also the remote
Sep 10, 2008 | NEC LT 260K Multimedia Projector
button.
will be disabled.
NEC Global
Sep 10, 2008 | NEC LT20 Multimedia Projector
Security code Nokia 3110 classic
SIM pin code:
This is a pin code that locks the sim card until you enter the correct code. This protects your account, even
if your sim is put into another handset. To reset it, you need the PUK code:
Pin Unlock Code (PUK)
If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled.
Phone Security Code:
This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code:
Master Reset Code
Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times.
Which is the one that you want?
The default security code for Nokia is 12345
Apr 17, 2008 | Nokia 3110 Cellular Phone
NOKIA2310 security problem
I forget my security code and i also don't know the Ime no.
so plz help me as soon as possible
I try to unlock my phone more than 5 times that is why it's not accepting 12345 no. as well.
Now plz help me fast
Thanks
Mar 05, 2008 | Nokia 2310 Cellular Phone
Code plz
If you have the remote, then you can cure with the following instructions. If you DONT HAVE A REMOTE, then you will need to take it to a Kenwood agent and have them do it for you, or just buy one:) Good luck
try this
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
Please rate me "FixYa" for this solution. Good Luck :)
Jan 08, 2008 | Kenwood KDC-MP4028 CD Player
Optoma EP706 Projector Remote Control Logo
Top Optoma Televison & Video Experts
jasbo
jasbo
Are you an Optoma Televison and Video Expert? Answer questions, earn points and help others
