Question about Kenmore Microwave Ovens
Microwave won't start - Kenmore Microwave Ovens
    Brigadier General:
  • 8,909 Answers
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Posted on Dec 29, 2010
Why wont the microwave start after I have repaired the door lock
If the micro switches for the door are not aligning up then the microwave will think the door is not closed and won;t start so I would make sure the door micro switches are lined up
Nov 04, 2014 | Kenmore Microwave Ovens
Won start
what make is this
Mar 31, 2014 | Microwave Ovens
Microwave won't start when pressing the start botton
call Chas&son,s appliance repair at 579-379-0993 and they will come out the same day no less okay
Feb 13, 2013 | GE JE2160 Microwave Oven
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
My GE Hvm1450dniww over the stove microwave won't
May be an internal fuse that has blown
Sep 13, 2012 | Microwave Ovens
Door on Sharp R-K520S won't stay closed.
check the hooks and door release button and repair or replace, when this is broken, the switch is not close the microwave will not START.
SEE the diagram
God bless you
Jul 14, 2012 | Microwave Ovens
My Microsoft says H97 and won't start running and goes back to H97.
The "H97" error means that the microwave's inverter has shorted out and does not work any more. The microwave cannot transfer power to create heat, and the part has malfunctions and requires replacement. Use your microwave serial number and Panasonic customer service to find the proper part for the microwave.
Oct 05, 2011 | Panasonic Microwave Ovens
We have a sunbeam microwave. it starts but the light doesn't work and it won't heat the food. what should we do?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ;'
Sep 01, 2011 | Sunbeam SMW750 Microwave Oven
My microwave not starting
My microwave on top of stove oven,whirlpool gold. When i closed the door but it keep said"door"and won't start.
Jul 21, 2011 | LG MS-0744Y Microwave Oven
Microwave Ovens Logo
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
