Newmark dm950 mixer, everytime i connect the power it works for 5-30 seconds then stops. i have tried a new adaptor and other output leads but no joy. any ideas?
    Brigadier General:
  • 8,546 Answers
Elaborate a bit on the 'adapter'. What is it?
Is your power supplied at the rated voltage for the unit?
Does it only fail with other units connected? Look at them, too. You may have an AC phasing issue, hot chassis, floating ground. Be careful.
Posted on Dec 29, 2010
My 4 year old mixer has never given any inkling of a problem untill I turned it on for the second time today-----absolutely nothing. I have checked the mains lead on other equipment, and it works fine. Any...
Sounds like a power supply failure: This will be close to the service manual for your unit:
http://elektrotanya.com/behringer_ub2442fx-pro_sm.pdf/download.html
Check teh power supply output voltages. If no voltage the main switcher has failed. One needs to be adept at electronic repair to repair this and have proper tools and equipment. The switcher runs directely off the input power and work on that portion requires using an isolation transformer for personal safety.
Feb 24, 2011 | Behringer Sx2442fx Eurodesk 24channel...
Iam trying to make my behringerXENYX 1204fx mixer, / connect
I have trouble my new behringer xenyx 1204FX VU led dead , like new VU it must play , how to repair this unit VU light
Mar 13, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
My numark x6 mixer does not work, it powers on, no output
Unless you can find someone local to fix it , you'll need to get something else
it's something internal broken and probably not an easy home fix
Nov 02, 2009 | Audio Players & Recorders
What is the best way to link a computer playing mp3 backing tracks to a powered mixer - or is it better to use an actual mp3 player or ipod
The way I used are with an adaptor,in one side are a 3.5mm terminal and in the other RCA you connect the cable to the headphones output on the cpu to the amplifier directly
Jul 27, 2009 | Fender 4 Channel Powered Mixer with 10 in...
Cant connect my Numark PT-01 to my Numark DM950 mixer
What do you mean it didn't work? What happened? Are you getting no sound, did the plugs not fit? Please be more specific.
If you are not getting any sound, make sure you connected to the LINE input of the mixer - the PT01 has Line Level outputs, so you CANNOT connect it to the Phono input, as the signal will be too hot for the mixer - so make sure it is in the LINE INPUT. Also make sure the toggle switch on the mixer is set to LINE. There is nothing else to this set up, raise volumes, and that's it. It's very simple.
- OPTiC
DIY Yourself DJ Repair Videos
DJ Equipment Sales
Jan 08, 2009 | Audio Players & Recorders
Modem power adaptor
On the bottom of the Modem, it usually lists the type of voltage/current ratio, for example, My modem is a 12VDC in, output is .75A Through the modem. Each modem has its own power requirements. Therefore if they dont match, you have the chance of either underpower (which means no use) or overpowering (and killing your modem permanently)
Best suggestion si the same as above by cnavarro, Buy the Right power supply for it, dont just try anything. get the matching one. Otherwise it will be Incident A or Incident B. Neither would work well, and you would end up buying a new modem all together.
Oct 30, 2008 | 2wire HomePortal 1000HW DSL Modem and...
Home stereo audio problems
Could be a bad patch cord, a setting on the mixer, a faulty mixer (unless it works ok with other amps), or a dirty control on the Sony amp if it has analog controls. Have you tried connecting other sources to the Sony?
Sep 27, 2008 | Audio Players & Recorders
My dab radio has stopped
hi, you just replace the power adaptor with a new one,the power transformer may be defective.
hope it may help
regards
Sep 11, 2008 | Teac Audio Players & Recorders
Numark
You need a new adaptor...the wires have lost their connection in the cable or plug which isnt user servicable
KK
Aug 29, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
118 people viewed this question
 Grubhead
Grubhead
