Question about LG 19LH20 19 in. LCD HDTV
How do i connect up my 19LH2000 (which has freeview built in) please. Not sure what connection/aerial I need fofr this? Thanks M
    Brigadier General:
  • 8,909 Answers
Freeview TV's just require an outside aerial. That's it.
Posted on Dec 29, 2010
I can't record digital tv on the dvd recorder coupled with a new philips tv with built in digital
You need a freeview box to connect to the scart INPUT of the DVD recorder. The Freeview box has to have a programmable timer built in. Connect your aerial to the freeview box, the aerial output then goes into the TV. You program the DVD to the times you want to record each program, but always the input is the SCart. You the program the Freeview box to change to the right program at the beginning of the program you want to record.
Jun 27, 2011 | Mico DVDR311
I have an acer aspire z5700 all in one pc with built in freeview and when i try to set up the freeview it says windows media center is unable to determine my tv signal.can you tell me how i can get a...
I am not sure what Freeview is, but Windows Media Center has a TV program built into it. Turn on Windows Media Center, go to the options section, and run the TV setup. Once you have TV working, just watch it in WMC.
If you don't want to do that, from the phrasing of your question, this should still solve the problem with freeview.
Apr 28, 2011 | Computers & Internet
I have an Alba 32880hdf freeview tv. I cannot record freeview programmes to my panasonic NV-FJ 780 vcr which has 2 scart sockets. I have no problem recording the teresteral channels. Can you help pls
Hi Victor,
You can't record the Freeview channels from the TV. It doesn't work that way. The reason you can still record terrestrial channels is because the VCR is still connected to your roof aerial with a co-axial cable and the VCR has its own built-in analogue tuner for recording terrestrial TV programmes.
To record the digital Freeview channels, you will either need to connect a separate Freeview set-top box to the VCR, or buy a VCR which has a built-in digital (DVB-T) tuner.
The VCR does not record programmes from the TV. It needs to be connected directly to the signal source, i.e. your aerial.
If you need any further assistance, please let me know.
Regards,
BElectric
Jan 15, 2011 | Televison & Video
My Polaroid HDTV says no signal. What is going on.
  • Have you plugged in the arial?
  • Is it in the right socket?
  • Are you using an aerial cable extender/splitter?
  • Are you using a portable indoor aerial?
  • Does it have built in Freeview?
  • Have you plugged in an external Freeview box if necessary?
  • Have you scanned for channels through the Freeview box?
  • Are you in an area where the analogue signal has been turned off?
  • Have you subscribed to a cable or satellite provider?
  • Are you on the right TV source?
  1. check the back of the tv to see if the aerial is plugged in.
  2. check the back of the tv to see if the aerial is plugged in correctly.
  3. If you are using an aerial cable extender or splitter, make sure all parts are connected all the way up to the aerial.
  4. If you're using a portable indoor aerial you might not be able to get enough signal to produce a picture. Also the aerial might need to be switched on, plugged in or need batteries.
  5. If the TV has Freeview built-in then you will need to scan for channels before you will get a picture. refur to you're TV's manual.
  6. Make sure, if you have got an external Freeview box that it is plugged in and switched on at the wall. Also make sure that it is connected to the TV either by a scart lead or by HDMI cable.
  7. Typically there will be a button on the remote called menu. From the menu screen choose setup. Then choose auto scan. Follow any on-screen instructions. Always refur to the TV's manual to avoid confusion and frustration.
  8. If you are in an area where they have switched off the analogue signal you will need to buy a Freeview box or subscribe to a cable or satellite provider. Freeview is cheep and is a one off payment ( best for people who will only really watch channels 1-5)
  9. Ring up your providers tech support.
  10. To change what input you are viewing, there will normally be a button called source on the remote. If you have connected a Freeview or cable/satalite box to the tv with a scart lead then select scart. If you used a HDMI lead then select HDMI. (There may be more than one of theses sockets so check behind the TV first. They usually have names or numbers by the side) refur to you're TV manual for help.
That is every problem i can think of. If it still doesnt work, take it back to the shop.
Hope this helps.
Jan 11, 2011 | Polaroid Televison & Video
Hitachi L42VC04U cant get freeview at all. Freeviewworks fine on another tv
The easiest way to check if the fault is with the TV or the aerial is to plug the TV in where the other WORKING TV is connected to the aerial.
If it works, then you have a problem with the aerial or the aerial cable.
If not check that the TV isn't in analogue mode. Press the "DTV" button on the remote. The TV should display "DTV" in the top corner of the screen.
If you are definitely in digital mode, and freeview doesn't work when the TV is connected to the other aerial connection, then you probably have a faulty TV.
Is the TV new or was it working OK previously?
Please rate my solution if you find this helpful. Thanks.
Oct 14, 2010 | Televison & Video
I have just purchased the sony video player SLV SF900 for my mum. I have used a scart socket to connect through the freeview box and to the back of the video. I have also added the aerial sockets. The...
Not all SCART connectors and cables carry the IN and OUT connections - make sure that the one from the freeview box has OUT connections, that the cable can carry them and that the one from the recorder has IN connections. Then , to record what you want, all you have to do is to tune the freeview box on that channel and set the recorder to use that SCART connector as source.
Sep 03, 2010 | Televison & Video
Tv with built-in digital tuner not receiving any channels
Is your outdoor aerial a proper freeview aerial and are you in a strong or weak signal area.You can check here:http://www.stevelarkins.freeuk.com/freeview_digital_tv.htm
Also check your connections as the coax may be shorting with the braid or a bad connection.once checked try ordinary channels on upstairs tv and if ok retune all your digital channels.
This can be due to a few problems.Firstly make sure your aerial is pointing in the right direction as beam aerials attenuate(disregard) signals which are not pointing directly at the aerial.
make sure you are using good quality 75ohm cable i.e rg6 and connections are good and not shorting out.
The length of run of the cable will also affect the signal as will any splitters or joins in the cable.
If you know the signal is good in your area then it will be down to the aerial,cable terminations ,aerial position or a combination of these.
If the signal is poor you can either...Buy a high db gain arial which will amplify the signal and or a masthead preamp which will again boost the signal.
please note that if your aerial is not pointing in the correct direction then any boosting of a bad signal i.e ghosting...will only make it worse.
try starting from aerial direction then connections then a high gain aerial and or booster.
Oct 14, 2009 | Televison & Video
I want to add a DVD recorder into my TV set up
If I'm right On the DVD recorder there should be an aerial input and an output. Connect external aerial to the output then run a second from the output to the TV. Then use the HDMI to connect the DVD. This will then give you the option of recording one channel on the DVD whilst watching another thru the receiver thats built into the TV. You will then get the best poss picture when viewing DVD
Nov 25, 2008 | Televison & Video
Connecting a freeview box
Your dvd player should be connected to the TV INPUT under norma conditionsl.What kind of recorder are you using? VCR player ?, Is it also a VCR recorder ( one cannot assume because I happened to own a VHS\vcr PLAYER, not player & recorder)Is Your VCR recorder? Then It must be connected to freeview box with universal scart to RCA converter box.You have "" dvd player in av2, vcr av1"" where? TV? freeview box scart connector ?
You will need scart to RCA converter box for sure.
Aug 08, 2008 | Televison & Video
LG 19LH20 19 in. LCD HDTV Logo
83 people viewed this question
