Question about RCA HD52W58 52" TV
Picture has suddenly changed from perfect to the top and bottom of the screen arcing towards the center
  • 70 Answers
Replace the convergence i.c.s and the safety fusible resistors around the i.c.s
Posted on Jul 09, 2008
Blue arc and ghosting across middle part of screen.
Replace Both of your convergence ICs they are big Black ICs will have STK on them! Use STK392-150s or the 180s Better ICs Call Mats Electronics 1-800-628-1118
Dec 21, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
Coloured lines on screen
Make sure first that the picture is centered by using the remote control to move the picture vertically and horizontally. Use the round pad towards the center of the remote and push the button according to which direction you want the frame to move.
Sep 10, 2009 | Philips 42 in. Plasma TV
Control of vertical TV image projected on the screen
You can try looking for 2 things
1. A button on your remote that says either: ARC, Ratio, 16:9, 4:3.... Some remotes have a picture of a square with arrows pointing out towards each corner..... I'm unfamiliar with this set, but it sounds like a widescreen, so give it a go
Apr 22, 2009 | Televison & Video
Picture not square
keystone should help in your opinion. adjust the keystone and the picture should be a square then.
Oct 28, 2008 | Hitachi CP-X275 Multimedia Projector
Convergence
you need to have the conversion chips replaced , this is a pretty common repair and i would say it is definately worth the fix, some repair shops will come and fix it within a half hour to an hour depending on the difficulty in taking out the old part and or putting in the new
Oct 07, 2008 | RCA HD52W59 HDTV Projection Television
Hitachi53SDX89B color problem
Blue convergence IC bad...have both IC's changed..insist on
STK394-160E upgrade part # CZ 01341 Hitachi brand.....Original part is STK392-110......Also, check B+ feed resistors next to
convergence amp IC's for burn / damage...after rebuild, press magic focus.......................T.
Dec 21, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Red convergence is bad.
Hi, you need to change the convergence ICs , STKs: and some resistors,low values; , after changing them, you will have to go into the service mode, to do some adjustments.that's it.
Nov 27, 2007 | Samsung HCN4226W 42" Rear Projection...
Toshiba 52HM95 has black smear in arc shape
defective light engine the light tunnel goes bad...
Oct 19, 2007 | Toshiba 52HM95 52" HDTV Projection...
WS-55809 - Video pinched in center, distorted, yellow/blue/red glow
This doesn't sound like a programming issue. I had a very similar problem about 6 months ago and I fixed problem. I had cold solder joint on the video power board. It was the board in the middle. The power supply was to the right. The video board had a driver with a bunch of legs. About 7 solder joint where cold or loose. I solder the board and my mitsu wide screen was fixed. Hope this helps.
Andy
Aug 22, 2006 | Mitsubishi WS-55809 55" Rear Projection...
RCA HD52W58 52" TV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
