Question about Morphy Richards 48280 FastBake Bread Machine
Hello, My MR Bread Machine's blade is broke down
Hello, My MR Bread Machine's blade is broke down and spindle is also not moving freely, where can I replace the bucket inside or get a spare parts. I am living in Bahrain Middle East. Thank you Yashwant
    Problem Solver:
  • 10 Answers
Try ebay.com they usually have lots of parts.
Posted on Dec 29, 2010
My AFK breadmaker suddenly stopped kneading. The blade makes a sound as if something is holding it from turning. I mistakenly put the wrong amount of water which was less than I should have put into my...
Sounds like something is stuck under the blade, are you lifting it out and cleaning it every time after use? Cooked bread gets stuck under the blade if not and will stop it moving freely.
Jan 29, 2015 | Kitchen Appliances - Others
Mtd engage blades it smokes and make noise
Have you physically moved each blade by hand (with the machine shut-off),spark plug disconnected to see if both or all of the cutting blades move freely if there is any binding you probably have a bad blade spindle bearing . If those move o.k. then you're going to want to check the pulleys on top of the deck, one of these which do not go to the blades may possibly have a bad bearing and is not moving freely causing the belt to be burning up.
Dec 03, 2012 | Garden
My craftsman 18.0 42" lawn
First check to make sure you can turn each blade by hand, with the mower off. If neither blade spindle is frozen remove the deck and make sure all the pulleys move freely and function like they should. The cable should have been operating a spring loaded pulley arm that applied tension to the deck belt to make the blades function. Some times build up with block that from moving or rust will make it stick.
May 26, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I hvae a Regal K6726 Bread Machine that a friend gave me. When I went to use it the first time, the Kneading Blade did not turn and the bread did not mix. It made a clicking sound, but did not turn. When I...
Hi...Take the empty pan out of the machine and spin the paddle by hand. It should turn freely with no sticking and should not be loose. There is a sealed bearing on the bottom of the bread pan and if this fails then the paddle will stick and be really loose if you try to move the paddle up and down. . If this is okay then check the belts and gear. They could be loose or worn out. Belts and motor are located in base of machine. Be sure to unplug before checking this out. Also, make sure bread pan is installed in the machine correctly. Hank
Jan 17, 2011 | Regal Ware Kitchen Appliances - Others
I have an old toastmaster bread machine model 1154, and I realized that the kneading blade does not rotate when the ingredients are in the bread pan. Either the kneading blade mounting shaft and the...
If the spindle is turning and the paddle is not then your paddle is worn out and probable slipping on the spindle. If the spindle isn't turning then your problem is underneath the pan or inside the drive and your paddle may be fine.
Dec 01, 2010 | Toastmaster Kitchen Appliances - Others
Why did the kneading paddle on my 1148X bread machine quit working. This happened the third time it was used. It did the initial mixing and resting. When it started the kneading process again, the blade...
Hi, If this is the third time using it, it could be defective. Return it for service. If not under warranty, try a few things. 1) Make sure the pan is inserted in the machine correctly. 2) Make sure that the paddle is not sticking, or the sealed bearing on the bottom of the bread pan is not broken or frozen. (Take pan out and see if you can turn the paddle freely by hand). Or finally, the belt may be loose and slipping, especially when it takes more power to knead the dough the second time. Good luck...Hank
Jun 12, 2010 | Toastmaster 1148X FastBake Bread Maker
The paddle doesn't seem to have a strong enough "push" behind it
Hello, Either the blade is sticking or the belt is loose. Take the pan out and see if you can spin the paddle freely by hand. The paddle should turn nice and free. If it doesn't then the lubricated bearing the paddle rotates on is sticking. This could be due to wear. Put some warm water in the pan and let it sit. Try a few times...DO NOT put the whole pan in water...just fill it. If that's a no go the lubricated bearing is frozen and the pan needs to be replaced. If everything is fine in the pan, then the belt is loose. Belt, pulleys and motor are located in the base of the machine. Remember to unplug first before working on it.. Hank
May 25, 2010 | Toastmaster TBR15 Bread Maker
Kneading paddles dont snap into the spindles .
The situation you speak of is common for ALL bread machines. You want the paddle to come off freely so it won't get stuck on the motor spindle. You can take the paddle out of the machine after the final kneading cycle and before final rise. This will prevent a big hole in the bread. If your machine does not have a pause cycle, take the pan out of the machine to remove the paddle to be safe. Hank
Apr 12, 2010 | Black & Decker B2300 Bread Machine
Missing kneading blade & manual
I need a LIZ626 blade for my machine. Can you help me
Jan 21, 2009 | Betty Crocker BCF1690 Bread Maker
Loosening up kneading blade
Try some penatrating oil. It may be rusted a little. Then tap the center with a punch.
webetz
Jan 06, 2009 | Toastmaster TBR15 Bread Maker
Morphy Richards 48280 FastBake Bread Machine Logo
Top Morphy Richards Kitchen Appliances - Others Experts
Mike
Are you a Morphy Richards Kitchen Appliances - Other Expert? Answer questions, earn points and help others
