Question about Canon PIXMA MX310 All-In-One Printer
I want to print in white ink on black paper. According to our local help desk this is not possible. I have a Canon MX310 printer. Wayne
  • 274 Answers
Dear friend, the printer either give color or black&white printouts...so to choose individual color it will not be possible
enjoy & cheers
Posted on Dec 29, 2010
  • Canon Master
  • 32,281 Answers
The help desk is right but there is a way around this problem.
This printer is a color printer. The only way to print white text on black is to a program such as PowerPoint and create a black colored page and then use white colored text. You need to put white paper in your printer.
This will cause the printer to use a very large amount of black ink and if the paper is too porous then the printed text will not be clear. Make sure you use inkjet paper.
How can i get my Canon Pixma MX310 to print black only?
There are many ways to printer in black and white only. Follow either steps;
1. Open the document you want to print > Go to file > Print > click properties in the print window > there in the 'main' menu you will see an option "Grayscale Printing" check / tick the option to activate > click OK > now take a black and white print.
2. Open the document you want to print > Go to file > Print > click properties in the print window > in the menu select 'Maintenance' > in the 'Maintenance' click 'Ink Cartridge Settings' > select Black Only > click OK > click OK > now you can print only using the black ink in the printer.
Hope this helps.
Please rate if this solution was helpful. thanks!
Jul 14, 2011 | Canon PIXMA MX310 All-In-One Printer
I want to print in white ink on black paper. I have a Canon MX310 printer
Inkjet printer inks are dye-based, and that's the reason.
Perhaps this will help explain things. You know those little boxes of food colouring you can buy in the supermarket - the ones that have four little bottles of colour - red, blue, yellow and green. Within reason you can combine these to turn white icing into most colours. Use nothing and the icing is still white or use everything and the icing will go a black-brown colour. Use a couple of drops of red and blue and you'll get purple.
But if you start with black icing, there's nothing you can add that will make it anything but black.
It's the same with your inkjet printer - because white is obtained by not having any ink print on the white paper. But of course that only works when the paper is white. Naturally you'll get different results on all colours of paper, decreasing as the paper gets darker in colour. Print blue on yellow paper and you should get green printing.
The only way to print in white is to do what commercial printers do - use opaque inks and include a white ink in the process. And as far as I know there's no commercial ink that will do that with an inkjet printer.
I can hear lots of you muttering "Rubbish. Of course you can print light colours on dark paper." Well all I can say is, have fun experimenting, but you won't be able to do it.
About the only way to achieve the sort of result you may be after is to print the job then trim it and paste it in place. For instance, if you want to print onto a black or dark-coloured T-shirt then print onto white transfer material, trim the print to size and iron it in place.
Dec 29, 2010 | Office Equipment & Supplies
Black and white prints are not black
Sorry, steve, that you are experiencing this problem.
According to canon.com's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white Even when printing in black and white, color ink is used for the following reasons:
  1. Automatic cleaning of the print head.
    To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
    Therefore, although printing in black and white is performed, color ink is also consumed.
  2. Color inks may be used to create black.
    When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
    Therefore, although printing in black and white is performed, color ink may be consumed.
  3. In order to keep the heavy black ink from smearing on the page or in the printer, color ink is used when duplex printing to help create black text.
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
Good luck on this.
Jul 13, 2010 | Canon i9900 InkJet Photo Printer
Canon mx310 how to print color document in black
When you go to save it or just before that you select file then go to print properties under that there should be a selection to print it in black and white.
Let us know ether way but its done under printer properties.
Thanks and please do be considerate that we are trying to help when you leave your positive ratings and feedback, thanks
May 26, 2010 | Canon PIXMA MX310 All-In-One Printer
Trying to change from black and white printing to color on canon mx310 please please help
Go to Cannon My Printer file, Click Printer Settings, Click Maintenance Tab, Click Ink Cartridge Settings, Select the ink cartridge for printing, Hit ok.
Apr 02, 2010 | Canon PIXMA MX310 All-In-One Printer
Canon mx310 feeds paper w/out printing
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 09, 2009 | Canon PIXMA MX310 All-In-One Printer
I just intalled a mx310 and I can't figure out how to set it to print in black & white only. I checked "grayscale" in printer preferences but I still get color when printing from the web. Any help would be...
Click my printer icon, then go to printer settings, click maintenance tab and then click "ink cartridge settings". Then select "black only" and click ok and only black cartridge will be used for printing.
Dec 19, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon MP830 - extreme ink useage
According to a service manual for a similar Canon printer, the grayscale printing should only use the Pigment Black ink PGI-5BK.
On fast it is 300x300dpi with 1 pass, standard is 600x600dpi with 1 pass and high is 600x600 with 4 passes.
On plain paper in colour it is meant to still only use the C/M/Y and again the big pigment black ink PGI-5BK, it only uses the smaller black ink once you set it to use a photo type paper in the printing settings.
Jan 18, 2008 | Canon PIXMA MP830 All-In-One InkJet...
PRINTING ON BLACK PAPER
That would require a very special "white ink" print cartridge for your printer. The regular color ink cartridges won't do this, since they can only make the black paper "black-er" when it prints ink on the paper. You may want to ask the manufacturer (Canon) if they make a special "white ink" cartridge for that printer, or know of someone who does. Your only other option is to make a "negative" print image in Photoshop, or a similar graphics software application, and then PRINT the black ink on white paper... which will then leave everything you want to "print white" as an unprinted area on the white surface of regular paper. (Note: with such heavy printing you would want probably want to use a heavier grade of paper, such as 28# or 60#.) This will use a LOT of ink, but it may be the only way you can accomplish your goal. Hope this helps...
Aug 04, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MX310 All-In-One Printer Logo
138 people viewed this question
old marine
old marine
