Question about Vacuums
Faber ffs 916 steamer beeps non stop - Vacuums
Oreck vacum steamer stopped steaming
Probable failure of the steam generator
Jun 03, 2014 | Oreck steam-it Stick Vacuum
My ez1 Monster Floor Steamer - green light goes off when I lower the handle and stops steaming
It could be calcium deposits in the tank. Clean it with white vinegar. Good luck!
Nov 10, 2012 | Euroflex Ez1 Monster Floor Steamer -...
SOLUTION IS LEAKING FROM MY BISSELL 1697 CARPET STEAMER WHEN IT IS STORED
you should always empty the steamer before you store it away it stops it clogging up.
Sep 13, 2012 | Bissell 1697-7 Powersteamer Pro Deluxe...
I need operating manual for vapor white wing steamer
This is from an Amazon review. I have misplaced my manual and was searching for a pdf file without any luck. I think I have it under control if I only knew where to put my distilled water.Basic operation of the WhiteWing is:
1. Fill the tank with distilled water
2. Attach the hose to the steamer.
3. Attach the extension handles and attachment you want.(Be sure to watch the video and read the instruction booklet. Some of the attachments have specific uses and setup instructions)
4. Lock the finger trigger.
5. Plug it in.
6. Turn it on.
7. Wait 20 min. or until the pressure gauge reads between 3.5-4.5.
8. Get ready to rock - press the steam release button, unlock the finger trigger and start steaming.
For many jobs such as countertops, shower stalls, stovetops, you will need to follow behind the steam, wiping with a cloth to remove the released dirt from the surface. Some jobs may require you to start with a non-toxic cleaner or grease remover such as Orange Clean or Method brand cleaners. Remember, you'll be breathing in vaporized cleaner. So be sure it's something non-toxic and non-irritating. I prefer the Method brand cleaners.
Jun 20, 2012 | Vapor WhiteWing Steamer Canister Vacuum
The Shark Steamer stopped steaming. Can I fix it
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the
Shark Manuals that you need.
heatman101
Nov 22, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
The steamer will not shut off even when the plunger is not depres
your valve might be gone to much use or mechanism of the handler broken
May 27, 2009 | Scunci 52067 Handheld Steam Vacuum
Does not give steam.
Actually there was no category for clothes steamer, and before entering information I was prompted to pick a category so I chose vacuums hoping that when my problem was diagnosed it would be understood that the problem is a clothes steamer that has stopped giving off steam. Please help if you can. I appreciated your time.
May 20, 2009 | Westinghouse Vacuums
Eureka Hotshot Enviro steamer
Remove the 2 screws on the bottom of the steamer, that holds the center panel on. (Not the screws that hold the whole bottom.) Use a needle the clear the steam holes. Soak the panel in white vinegar for a couple of hours and scrub with aa brush to remove the lime calcium deposits. Check the center hole that goes into the steam and make sure it is clear. Reattach the panel. If the panel does not fit snuggly (either end does not contact the base panel, add two more screws about an inch in from either side. I used stainless steal screws because of the consist moisture. Used screws that are no more than 3/4 on an inch long and about the same diameter as the two you removed.
Jun 08, 2008 | Eureka Enviro Steamer 310 Stick Vacuum
Steamer #410 has cord problem
u can send it back or u can fix it urself its a simple fix all u have to do is check the power cord going in u can cut about an inch n reattach it and it should work good luck
Nov 16, 2007 | Eureka Enviro Steamer 310 Stick Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
