Question about Rockford Fosgate Punch 301S Car Audio Amplifier
Amp will not turn on
I as well, was just listening to some music and my long time working sub just stopped. I has a solid ground at the terminal and 12v from the battery and at the remote wire. I'm running it bridged into a 4 ohm load and not pushing the amp too hard. The light on the amp won't even turn on let alone any sound from the amp. It is totally dead. Has anyone else encountered this problem and found a solution? Thanks.
  • kanurys Jul 08, 2008
    When I said "terminal" I meant the terminal on the amplifier. All of these things check out. They both read between 13v and 14v.
  • 66nova Sep 02, 2008
    My amp is not turning on, everything seem's to be hooked up right,the amp does not smell burn't,and the music still turns on and the fuse still looks good?
  • 631 Answers
You need to confirm that you have voltage at the amplifier.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Posted on Jul 08, 2008
Planet Audio PX1500M Amplifier Problem
Check the FUSE to ensure that current is not cut off.
Jul 16, 2013 | Planet Audio PX1500M - 1500W MOSFET...
I just replaced my old terminator 12" subs with two new 12" jl audio w3 4ohm subs and the mtx terminator amp keeps shutting off and flashing red. I kept everthing the same from my original mtx...
You may have touching speaker leads going into the amp. Make sure the tinsel is not touching across the speaker inputs on the amp. Also check your ground. It should be solidly connected to the vehicle chassis in a paint-free location. Finally, make sure there are no exposed speaker wires touching the vehicle chassis.
Mar 09, 2011 | MTX Terminator TN400/4 Car Audio Amplifier
Amp not working
Make sure you have the amp grounded. I put one in last week and would not work till I grounded the amp to the car....Run a seperate wire to the car/truck.
Dec 22, 2009 | Power Acoustik Car Audio & Video
I need help installing a 4 Channel Power Acoustik Amplifier to Two Pioneer Subwoofers. I hooked up the power wire to the positive battery terminal in the engine compartment. I then cut the power wire and...
You are doing right on what you described. I really like to work with a clearly described what involved in an issue.
Now we have to use a Voltmeter to check if there is power to the amplifier. If there is power to the amplifier terminal, then the problem is at the amplifier, not the connection. Let check it out:
1- Turn on your Kenwood radio, make sure to hear sound from your regular speakers.
2- Turn remote control knob to the mid level between min and max.
3- Measure the blue wire where you spliced to ground to see if you have 12V, if it is not then the problem is right there.
4- Measure the Red wire power from the Amplifier to ground ( the bolt that you connect the negative power to see if there is 12V, if not trace back to the Fuse that you inserted between the positive terminal of the battery and the wire going through the firewall to correct it.
5- If you have 12V at step 3 and 4, then you have a defect unit, return it to the manufacturer for a replacement.
Sep 06, 2009 | Car Audio & Video
I cant hook up my amp
Hello cesar199064,
These are the steps you required to install your amp and subs:
1) Purchase an amp wiring kit with 2 or 1/0 gauge power and ground wires.
2) Decide on a location to mount the amp where it will get proper airflow and will not interfere with operation of the vehicle. Closer to the battery is better. Decide on the location and install the sub enclosures.
3) Locate a place on the metal body of the vehicle within about 3" of your amp for the ground. Connect the ground wire to the amp ground terminal and to BARE METAL on the vehicle.
4) Run power wire from battery positive (+) using one of the amp kit ring terminals through a 100A fuseholder to the amp positive terminal. DO NOT install the fuse yet.
5) Run a "remote" wire from the remote turn-on lead (usually blue or blue/white) of your dash mounted head unit to the amp turn-on terminal. Run a set of RCA cables from the preamp or subwoofer outputs on the head unit to the amp inputs.
6) Run speaker wire, preferably at least 12-gauge, from the amp output terminals to your subs.
7) Check all of your wiring. Make sure that no insulation was damaged or peeled off during the running process. Make sure there are no loose strands touching adjacent terminals or bare metal.
8) Use a multimeter set to read "ohms" and test from the negative battery post to the amp ground terminal. You should read "0".
9) Install the fuse.
10) Turn on your head unit and listen to those big Kickers thump.
11) Adjust the amp settings according to your manual.
The best place I've found for in depth information on audio installs is The Install Doctor. You'll find step-by-step procedures, color photos, wiring details, and even the tools required. I recommend that you begin with the "tech docs" link and read through some of the PDF documents.
Hope this helps.
May 08, 2009 | Kicker ZX10001 Car Audio Amplifier
Sub woofer
are your subs bridged? if they are try unbridging them... if that doesnt work try finding a better ground, and if neither of those work turn the amp down while music is playing until the palsating stops and the speakers are just hitting...
Dec 18, 2008 | Car Audio & Video
Music not playing from subs
Do this for the sub amp...
Jul 03, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Subwoofer works at high volume, doesnt work at low volume
You had the settings set incorrectly and overdrove it. The voice coil leads are burn't open. If you look at the little flexible braids by the terminals I'll bet they are black/brown and maybe even burn't in half. It's toast.
Sep 17, 2007 | Kicker 02S10L74 Car Subwoofer
Orion 275g4 Hcca amp
this actually could be your amp...try turning the gain down slowly and you will hear the bumping either stop or become morelike music background thanmusic foregroud. i had this problem with an older amplifier and i fixed it by getting a larder power/ground wire size and decreasing the gain a little.
Sep 03, 2007 | Orion HCCA 275G4 Car Audio Amplifier
My amp turns on then the music cuts in and out
check your main ground, if possible try to read voltage across making sure 12-14v present with load and some signal.
Aug 08, 2007 | Verge VGA285 Car Audio Amplifier
Rockford Fosgate Punch 301S Car Audio Amplifier Logo
304 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
Level 1 Expert
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
