Question about Toyota Car Audio & Video
Les Bather Liverpool L19 2QZ 29.12.10 07768 747686 Hi I hope you may be able to assist me I have recently purchased a 1998 Lexus RX300 Japanese import (Harrier) I am having a problem with the radio/satnav/clock etc, as it is all in Japanese I am told that this can be formatted, is this true? If so how do i go about it, I was told i had to change the complete radio system to eradicate the Japanese writing that is showing Can you please help me in any way, it would be much appreciated if you are able too Looking forward to hearing from you Regards Les Bather
trintek
  • 111 Answers
SOURCE: transfer from japanese to english
what make/model is the vehicle? most in car monitors have a setup menu with language options that should be accessible from the remote control or front panel. if you can get into the setup menu look for an icon that has a person speaking or multiple lines of text in various languages, select it and you should have an english setting under it if the monitor's controller is equipped with the english language data.
Posted on Nov 15, 2007
  • 185 Answers
SOURCE: Removing the Radio for Lexus Rx300
take the woodgrain cover off around shifter, it pops off. next pull out the small panel just below the radio, pull it straight out towards you, set it aside. there are 4 bolts holding the radio in, you will need a light to see the back 2. remove these bolts and carefully pull radio straight out.
Posted on Oct 03, 2009
  • 87 Answers
SOURCE: I have just purchased a Nissan Elgrand van
you may want to contact pioneer i am sure they would help you out, or try looking on their site under support. Good luck
Posted on Mar 08, 2010
  • 67 Answers
SOURCE: i have an import lexus rx300, language on on board
i would visit some car wrecker (salvage) yards they may be able to provide information hope this helps.
Posted on Apr 11, 2010
logosc75
  • 625 Answers
SOURCE: I have just imported a
Try resetting the system and changing the setup features,i.e.language, location,etc.
Posted on Sep 20, 2010
What is the factory spark plug gap for a 2000 lexus rx300
hi Ale.
this link should help you find out.but it does depend on the brand/type of spark plug you use.
Get the Best Priced Lexus RX300 Spark Plugs
or this one.
NGK Lexus RX300 Spark Plugs
or this one.
2000 Lexus RX300 Spark Plug
Nov 21, 2017 | Lexus Cars & Trucks
Driver side suspension drops when turned off works ok with engine running new sensor fitted still has problem
RX300 Mega Thread. Start here if you have a problem - Club Lexus ...
www.clublexus.com/.../679100-rx300-mega-thread-start-here-if-you-ha...
Feb 17, 2013 - One question per post please. ... manual-search, just enter RX300 or whatever Lexus vehicle and year ... Side affects of CEL: Based on the error code, your RX may end up in a .... You may hear a drop in rpm of the donor car. Window Switch Problems Pass side
Jul 17, 2015
RX300 knock sensor replacement DIY
Jul 6, 2015
RX300 (year 2004) air suspension fault
Jul 17, 2015 | 2003 Lexus RX 300
I have a Lexus RX300 1999 model and have this recent problem. engine running normally but gear gets stuck in Parking mode and won't shift. had to depress the emergency button on the gear shift and
Some automatic vehicles rely on the brake switch (mounted on brake pedal) to be activated by depressing brake pedal. This signal then operates a relay and switch, to release the gear lever.
Firstly, I would check the brake pedal switch (are your brake lights working?).
If brake switch is confirmed OK, then inspect the relay (and related circuit components) of the gear release switch.
Mar 04, 2013 | 1999 Lexus RX 300
My lexus rx300 2000 has the check engine on, the diagnosis says the dtc but nobody knows what to do,I've check thre vacuum but every hose seems to be in right place.
DTC stands for diagnostic testing code but that is not a code. what code number came up? ex-P0066 or P0089? If you get the code I can assist further, I hope this helps
Jan 19, 2011 | 2000 Lexus RX 300
I have lost my lexus remote control key. how and where can i buy a new one through the net. thank you..
Buy it from :-
http://cgi.ebay.com/ebaymotors/2001-2002-2003-LEXUS-RX-300-RX300-KEY-REMOTE-KEY-_W0QQcmdZViewItemQQitemZ120607853494QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
I hope i have been helpful.
Thank You!!
Aug 21, 2010 | 2001 Lexus RX 300
99 lexus rx300 has engine miss on cyl 2,4,6 all
2-4-6 could be a fuel or ignition issue, hopefully not a valve. If you have the engine tested at the dealership they will attach a code reader under dash to analize and this should help pinpoint the problem.
Jan 07, 2010 | 1999 Lexus RX 300
How to tighten belts on a 2002 Lexus RX300
Bring it back to the dealer, tell them they squeck. new belts should not squeck. Squeaking means they are too loose or have fluids on them. If they're not shiny, the're loose.
Sep 16, 2009 | 2002 Lexus RX 300
Car Audio & Video Logo
49 people viewed this question
Top Toyota Car Audio & Video Experts
Martin Clarke
Martin Clarke
wadingriver
wadingriver
Are you a Toyota Car Audio and Video Expert? Answer questions, earn points and help others
