Dear sirs plz answer me urgent canon 2870 Error 000350-3000
KyoDoc
  • 38 Answers
SOURCE: IR 2870
The waste toner container is full. the front cover of the machine (the one with the Canon logo on it) must be removed. behind you will see a big white plastic bottle. Remove the bottle, empty the contents into the bin, wipe it off, and refit all removed parts. Finally restart the copier.
Posted on Sep 24, 2008
  • 4 Answers
SOURCE: hp laserjet 1022
It sounds like an issue with the spooler service on Windows.
You will have to download the tool kit to run it. It states for windows server 2003 but will also work on xp Her is the link fo rthe download:
http://www.microsoft.com/downloads/details.aspx?FamilyID=9D467A69-57FF-4AE7-96EE-B18C4790CFFD&displaylang=en
here is a link with direction for running it on xp
http://www.windowsreference.com/windows-xp/how-to-clean-print-spooler-in-windows-xp2003/
When you run it it will ask you if you are sure you want to delete spooler files. clcik yes. When it asks if you want to delete USB monitor click on no.
Thisis the fix for the print spooler issue after you run the cleanspl.exetool and wipe out all the ports. You have to add back in the USB portmanually.
Run regedit. Go to HKEY_LOCAL_MACHINE/System/CurrentControlSet/Control/Print/Monitors.Look for a USB Monitor entry. Before doing anything else, backup theregistry entry by right clicking on "Monitors" and selecting "Export".Give it a name and locaction so that you can put it back if you haveproblems later. If "USB Monitor" is not there, add it by right-clickingon Monitors, New, Key. Name the new key "USB Monitor". Once added,right click on the new key and select New, String Value. Name the newvalue "Driver". In the right portion of regedit, right click on the new"Driver" value and select "Modify". Make the value data "usbmon.dll".If there is an "HPUMON" entry (or the like), delete it. Disconnect theUSB cable to the printer. Run the "scrubber" or clean utility, rebootthe machine. Reconnect the printer and install the driver software permanufacturer instuction. This fixed my problem. Good luck!
Posted on Feb 24, 2009
SOURCE: sir plz give me the authorization code of photoshop cs2 urgent pl
Please can I have the Authorization Code:
Serial No. 1045-1086-5216-7540-7487-1490
Activation No. 4124-9115-6893-1009-2029-6248-7481
Thanx
Posted on Aug 06, 2009
SOURCE: P3400I
Sir,
In My HTC P3400i the start menu containt application and setting are removed how to get them back.
Please provide solution.
URGENT.
Posted on Dec 05, 2009
canontech
  • 1219 Answers
SOURCE: error code 19
You have waste toner full!
Remove the drum, on top of drum there is cork, remove cork and vacume all the waste toner out.
Posted on Jun 02, 2010
How do I solve Error Code - E000716-0010 In Canon IR2870
Failure of the communication with the 2-way unit
Description
When the communication with the 2-way unit is faulty after detecting the connection with the finisher.
Remedy
1.Install the 2-way unit.
2.Check the cable.
3.Replace the DC Controller PCB (PCB4).
4.Replace the 2-way unit driver PCB.
Sep 22, 2014 | Canon Ink Cartridge GPR15 for iR 2270, iR...
E000225 0001
Oh, it looks like your ImageRunner's fixer unit (the heater thermistor it uses to regulate temperature) burned out or disconnected on you. http://canon-ir-6000.blogspot.com/2009/02/e000-main-cause-main-thermistor-th1-has.html
Find that little sensor leading up to the coils and replace it.
Otherwise, say that again in just Hindi?
Aug 04, 2014 | Canon Crtdg, gpr15, ir 2270/2870, bk
CANON ERR 0001-002 COMEING
error clear on ur mechine .or change ur fusar unit.if ur not undastand plz call me on 09989086587 this number urs ASLAM
Apr 03, 2014 | Canon imageRUNNER 2870 Copier
Canon ir 2870 digital copier showing Error E000024-0001
plz clean ur developer unit dont adds toner .dyerect clen and replace it
Sep 24, 2013 | Canon imageRUNNER 2870 Copier
May canon ir 2870 eror code below E000732-0010
sir ihave ir 2870 mashine . the machine giving E000225 -001 error code
Oct 25, 2012 | Canon imageRUNNER 2870 Copier
Sir I have Canon IR 2870 a few weeks later machine shown Error 000007-000. I changed the fixing film but machine showing error again why
Sir I have canon 2870 machine. The machine giving the finisher problems, when starting the finisher going down. The machine showing the problem E540. Please kindly solve
Feb 22, 2011 | Canon ImageRunner 2020i Copier
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
