Question about ASUS Computers & Internet
I have an ASUS E5092,\r\n It come with inbuilt wireless, but when it is turned on it still won't connect to the internet. when it is asked to diagnose the problem " Install wireless networking hardware, and verify the correct drivers are loaded " pops up. How do i fix this?? if it helps, the laptop is running vista.
  • ASUS Master
  • 32,281 Answers
Try installing the latest wireless card driver.
You can download the drivers from ASUS WEB site. Selectyour model motherboard/computer/laptop, and make sure you select the Windows XPor Vista version of the drivers that matches your Windows operating system.Please click on this link to their WEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Posted on Dec 29, 2010
Can eee asus 1008HA laptops use a prepaid 'stick' for internet connection?
The USB wireless stick uses the cell phone network for wireless Internet connection provided it is within that ISP cell phone coverage area.
I doubt you can use a 2nd hand USB wireless stick unless the service is transferred to you. It is best you organise your own Internet connection with a ISP of your choice.
Laptop battery are removable and can be replaced when they are worn out, BUT the BIOS battery is inside the laptop and this can be changes but requires getting access to the insides of the laptop.
Apr 11, 2012 | Computers & Internet
I got a asus g53jw-a1 and when i connect my internet cable to it.it goes very slow and when i connect it to another laptop that isnt asus its goes normal and fast. i have 2 computers and the internet goes...
Do you have your wireless connection enabled as well as your LAN connection (wired) connected and enabled at the same time? It may be as simple as turning the your wireless card off when your are connected with a wired connection. I would try that first and see if it that could be the issue. Shut the wireless card off and see if your results are different with just the ethernet cable connected.
Cheers!
J the Guru
Oct 16, 2017 | ASUS G53Jw-A1 PC Notebook
It says my wireless capability is turned off
http://ca.asus.com/product.aspx?P_ID=QAVTJThr36Jox9Cf
i dont know what your OS is ..?
go to that link and select DOWNLOAD, then your OS --downoad the manual , Version E5092
Wireless Operation Channel for Different Domains
N. America 2.412-2.462 GHz Ch01 through CH11
Japan 2.412-2.484GHz Ch01 through Ch14
Europe ETSI 2.412-2.472 GHz Ch01 through Ch13
France Restricted Wireless Frequency Bands
Some areas of France have a restricted frequency band. The worst case maximum authorized power indoors are:
• 10mW for the entire 2.4GHz band (2400 MHz-2483.5 MHz)
• 100mW for frequencies between 2446.5 MHz and 2483.5 MHz
Channels 10 through 13 inclusive operate in the band 2446.6 MHz to 2483.5 MHz.
There are few possibilities for outdoor use: On private property or on the private property of public persons, use is subject to a preliminary authorization procedure by the Ministry of Defense, with maximum authorized power of 100mW in the 2446.5-2483.5 MHz band. Use outdoors on public property is not permitted.
In the departments listed below, for the entire 2.4GHz band:
• Maximum authorized power indoors is 100mW
• Maximum authorized power outdoors is 10mW
Departments in which the use of the 2400-2483.5 MHz band is permitted with an EIRP of less than 100mW indoors and less than 10mW outdoors:
Jan 11, 2011 | ASUS K52F-BBR9 Notebook
Can 't connect to the internet with my ASUS wl-167g I have an ASUS wl-167g wireless usb adapter on my Win7 Home Premium PC, with the latest ralink drivers. I can perfectly detect the wireless network my...
You need to enter the wireless key from your router once before the adapter will connect. The key is either on the label on the router or in the wireless section of the router.
May 04, 2017 | ASUS (WL-167G) 802.11g/b (wl167g) Wireless...
How to connect htc touch p3452 to laptop as modem to connect to the internet using bluetooth.
you should have a inbuilt bluetooth or external bluetooth for connecting your HTC mobile to laptop. If you have inbuilt bluetooth then just open the bluetooth software and turn on bluetooth on your mobile also. Pair both devices it will ask you to provide a passcode provide 1234 then it will prompt for password on your mobile enter 1234 and follow the instruction it will connected to internet. If you have external software then download the bluetooth software and follow the same steps as in inbuilt bluetooth.
May 17, 2010 | HTC Touch P3452 Smartphone
Asus eee pc 4g wont connect to internet with
Can you connect through a "wired" connection? Is your router connected to the Internet? If you're using wireless encryption, have you told your netbook what that encryption key is?
Apr 29, 2010 | ASUS Eee 4G Notebook
Hp wireless assistant problem
Is your wireless network working fine? If yes, it is better to close HP Wireless assistant program as windows has inbuilt program to detect the WIFI connections. You can type "msconfig", go to startup and close the required process. It should stop.
Feb 16, 2010 | Compaq Presario Notebook
I am trying to connect my asus mypal to my wireless internet
Hi, I helped a friend of mine with his wifi setup. His WEP Key was on the side of his router. I don't remember the exact work but it was something Key. It was 10 numbers long just right for a 64 bit key. If you are using Win XP there is a wifi setup in there. I have a mypal A626 and had it up and running in a few minutes on my wifi system. If you have security, you will need to find the code in order to get a connection. grader01
Apr 12, 2009 | ASUS MyPal A626
Won't connect to wireless internet
I just went to the properties on my wireless connection, went to the "wireless" tab, and switched the encryption type from WEP to WPA and now my wireless works.
Aug 01, 2008 | ASUS Eee 4G Notebook
Computers & Internet Logo
216 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
