Question about Logitech X-140 Speaker
I am unable to activate my speakers - after accessing sounds via the control panel the volume control is greyed out. The speakers are correctly connected
    Brigadier General:
  • 8,546 Answers
So we're talking about a PC here, right?
Perhaps you could fill in some details as everything is software-controlled. Can you access your soundcard controls? It probably overrides the basic system stuff.
Posted on Dec 29, 2010
Systemax ascent sais the sound card is already in use and cant seem to get sound
which operating system ??
XP If your computer came with a motherboard disc the sound drivers could be on it Click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers Click start control panel sounds and audio volume advanced speakers make sure you have selected the (appropriate speakers) also audio you will find 3 drop down lists make sure you have the selected correct speaker settings there Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it if his does not fix the problem Click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume Click start control panel sounds and audio volume advanced speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check the speaker plug/outlets is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line or use a can of compressed air specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer W7 click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated if you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker you might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply Hope this helps.
Dec 23, 2012 | Systemax Ascent PC Desktop
Sound card won't work
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
if its a desktop swap the speakers around if one still does not work its either a faulty speaker or the speaker connection
hope this helps
Sep 04, 2012 | Computers & Internet
Sound is not coming
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
Oct 27, 2011 | VIA ASRock K7VM3 Socket A/...
Have Koss hd-50 (hand me down) would like a diagram, have no sound, running winxp on dell xperion 8400, says "no active mixer devices"
i will go through the process of setting up sound on your computer
also
if you need more help with this post a reply
hope this helps you
Sep 21, 2011 | Koss HD 50 Computer Speakers
Change the volym
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Mar 01, 2011 | JBL CREATURE II Computer Speakers
Is there a built in microphone
Hello there is a mic on your pc on the front panel at the top if you want to check for access your volume properties by double clicking on the speaker icon in the task bar and check if the mic is not on mute or low volume alternatively access it through the control panel menu. If this does not work check that the sound driver is correctly loaded and working properly via right click my computer then select properties then select device manager and then check that the sound drivers is operating correctly if not the sound driver will possibly have to be reinstalled good luck
Dec 09, 2010 | Acer Aspire One PC Notebook
Sound not playing correctly via the speakers on the monitor Back ground music but no voice
sounds to me like you may have the monitor speakers connected to the wrong port. It typically connects to the computers Green speaker jack. If it is connected properly, look in the control panel for audio/ speaker properties, change the speaker configuration to stereo speakers, instead of 5.1 speakers. you are likely hearing the rear channel of 5 speaker setup at the moment.
Aug 29, 2010 | NEC MultiSync LCD1735NXM (Silver, Grey)...
Configuration of mic controls for VIA VT8235
NOT ALL CARD have this functionnality
or some of the files' of the drivers are not more accessible, try to reinstall soundcard drivers
http://www.majorgeeks.com/downloadget.php?id=4505&file=15&evp=7216be170eaa0a6ea7be06e810e3b4c1
Nov 26, 2008 | VIA P4MA Motherboard
Unable to change volume control on the keyboard
can you access the "speaker" icon on lower right corner of the screen ?
If not can you access sound control from control panel ?
May 23, 2008 | Acer Aspire 3690-2196 Notebook
I just bought a laptop do they have speakers built in? and if so where is the volume control I have a acer travelmate 200dx thanks Anne
volume control is normally located on the bottom right hand corner beside the clock, just double click on the speaker icon and you should be able to adjust the volume.
Mar 12, 2008 | Computers & Internet
Logitech X-140 Speaker Logo
251 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
