Question about Measuring Tools & Sensors
Skil 520 ranger "Err" when attempting to measure
2 Suggested Answers
  • 157 Answers
SOURCE: i need a user's manual
Found what you're looking for. Check the link (to get to your language section, click on the sysmol on front page of manual):
http://www.skileurope.com/common/manuals/0520.pdf
I've included the main selection page in case the PDF link (above) gives you grief:
http://www.skileurope.com/service_manuals.php
Please rat a four-thumbs if this helped. Thank You.
Posted on Mar 24, 2011
HOW FAR DOES THE CHUCK TRAVEL IN IT'S FULL MOVEMENT
This will all depend on your bit an your table setting. The chuck is easy to determine. Just measure the distance it travels with a tape measurer.
Jun 22, 2015 | Skil 3320-01-RT Factory-Reconditioned 10"...
Error Bosch DLR130 distance measurer
Same problem Err and --- on display. The front lens had become misaligned. Take off front rubber boot, clean lens and replace lens exactly in glue pattern on unit with rounded side facing out. Then holding unit with seated lens upright push rubber boot slowly back on. Very hard at first but push as much in by hand then use a narrow blunt point like the back of a screwdriver handle to press around the edge working it in with slow continuous pressure a quarter inch at a time. It will reseat just take your time and work the high spots. This time was not the batteries, works like new.
May 23, 2013 | Measuring Tools & Sensors
How do i adjust the headlights on a 2001 ford ranger
There should be two screws to adjust vertically/horizontally. both headlight has those. before begining the adjustment if there is a leveling motor adjust it to 0 position.
you will need allen wrench( 4mm). i guess it is a special type for ford ranger headlight becasue screws are hard to reach. when you have proper tool you will turn screws to find correct pattern on wall.(some needs only philips screw driver)
to do this park car in front of a nice flat wall and have 10 meter distance between. direction car should be exactly perpendicular to wall surface. measure the height of hte center of head lights.
record this. mark same line on wall at same height. then find center point of your car and mark it on wall. mesaure distance between two headlight (center to center). mark same distances on the line on wall.
keep in mind that when you turn screws center of beams will move. you need to adjust 10 cm lower than your line and you will match the direction on each headlight. here is a drawing. ( if you have 8 meter of distance you will have 8 cm difference on your line and beam centers)
Nov 20, 2011 | Cars & Trucks
I need a user's manual for a skil ranger 520.my e mail is ekonde_thompson@yahoo.co.uk.
Mar 21, 2011 | Measuring Tools & Sensors
Describe your Skil 7 1/4" Magnesium
You have large plastic screw on the saw, remove it and fill the oil to bottom of threads and that should be it.
Sep 15, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
I have a very old Skil circular saw Model #586. What size blade does it use?
measure from the center of the shaft to the inside of the guard, double that distance. subtract about 3/4 of an inch and this will be real close to the blade diameter that you need
Aug 16, 2009 | Skil Saws
Will '89 Ranger leaf springs fit a '99 Ford Ranger 4x4?
Measure the distance from bolt to bolt, and to the center. If they match then, they match, if not you will have to check the numbers with fords tolerances to avoid an axle wrap. But it should fit, maybe just a little stiffer of a suspension from the 4x4.
Calvin the Mobile Mechanic.
Mar 15, 2009 | 1999 Ford Ranger SuperCab
Measuring Tools & Sensors Logo
279 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
