I HAVE SONY SDP-D905 DIGITAL SURROUND PROCCESOR BUT WHEN I CONNECT IT THERE IS NO AUDIO SIGNAL
  • 3 Answers
You dance
Posted on Dec 29, 2010
Sdp d905
If your profile is in the list while profiting device settings it is possible that the card is not effective from the BIOS by making sure the Windows Check to make sure the work of a full examination of the device from viruses
May 06, 2013 | Computers & Internet
Tip
How to make a connection to an iPod and Sony SS2300
<p>The SS2300 is a Sony digital surround sound system with a Blu-ray player. This gives you the ability to play high-definition video, while experiencing the content in full surround sound audio. However, the speaker system audio inputs, so you can connect external devices, including Apple iPods. Although no direct connection to iPod, you can use a single cable to the signal from the iPod surround sound system. <br /> <p><br /> <p>1. Insert the end of 3.5 mm to 3.5 mm to RCA splitter in the headphone port on top of Apple's iPod. <br /> <p><br /> <p>2. Connect the RCA cables into one of the "Audio In" ports on the back of the Sony SS2300. Multiple connections exist and you better take note of the connection you use. This makes it easier later on if the connection to the iPod. <br /> <p><br /> <p>3. Power on the Apple iPod and Sony SS2300 receiver. Press the "Input" and select the connection to the iPod is connected. <br /> <p><br /> <p>4. Press the "Play" button on the iPod and play audio content through the Sony surround sound system. <br />
on Aug 09, 2011 | Apple iPod touch
Surround sound hookup between my 2008 sony bravia and sony A/V surround sound receiver which is older.
the yellow on an RCA setup is a video signal not audio, so just hook up the yellow to video 1 and red /white to audio 1 or whatever number it happens to be
May 09, 2012 | Sony BRAVIA KDL-46V3000 Television
I cannot get sound from a sony BDS350 (Blue ray
This must be configuration problem on the BD player. In this case receiver just outputs the signal it receives digitally. If it displayes PCM 2ch, that means it receives only 2 channel audio from BD player.
You can try to configure the BD player not to decode audio and to output the RAW stream over coax cable to the receiver. Then the receiver should get raw Dolby Digital encoded data and be able to decode it into 5.1 channels. It should also display Dolby D instead of PCM in such case.
Feb 11, 2010 | Sony Audio Players & Recorders
On our Durabrand DVD/Vcr Combo, I get picture, but no sound..I'm using a S video as conectors!
S video connector is used only for video, you need to connect the audio separately via the RCA audio connectors or via digital coaxial or optical connector.
You can read more on S video standard here:
http://en.wikipedia.org/wiki/S-Video
Also see the related topics on audio, maybe you should consult the user manuals for your dvd unit and the amplifier that you use to get more info, but normally the sound can be connected via these connectors on the rear panel of dvd units:
- main left and right analog signal out RCA connectors (2 channel stereo signal - amplifier set to analog signal)
- main left and right, sub, center, surround left and right analog signal out connectors (multichannel surround signal - amplifier set to analog signal)
- coaxial digital signal out RCA connector (a single cable that takes the stereo or surround signal to the amplifier in a coded digital form - you need to set the amplifier to the digital signal mode to enable this kind of signal)
- optical digital signal out connector (same as the coaxial digital output, the difference is that the signal is in the form of light pulses instead of electrical pulses - the amplifier should be set to the digital signal mode as well)
Hope this helps somehow - if it doesn't, post me some feedback, perhaps a brief description of the units that you want to interconnect...
regards
Triarcuate
Sep 26, 2009 | Televison & Video
How do i connect my subwoofer to my sony dvd player to get the great surround sound?
there will be a subwoofer pre out( needs to be amplified) or if it don't have subwoofer pre out you will have to send the audio out to a stereo reciever that has inputs for the optical ( digital audio signal )( to a stereo or surround system that has 5.1 or higher has full surround sound ) and of course L and R audio inputs and the subwoofer pre out , then the subwoofer pre out will have to be amplified by a reciever , subwoofer amp , surround sound , ect
Oct 17, 2008 | Televison & Video
Connect PS3 for playing/viewing blue-ray thru surround sound
I just finished setting up my system last night and was facing similar problems with sound/video from my PS3. The only option I could get working was to have the HDMI cable connected from the PS3 to the TV and then connect the Optical cable to the receiver for sound. I was under the impression that HDMI handles sound and video but for whatever reason the PS3 does not agree.
I have DTS sound and fantastic picture now through my PS3, hope this helps.
Cheers
Oct 05, 2008 | Sony DAV-HDX500 System
I have an LG LCD TV (LG 37LG5000 37IN). I also have an older DVD Home Theatre System (SONY DAV-DZ100). It seems that the surround system works well with DVDs but I cannot get the sound to work with DIGITAL...
It works fine if you plug the surround system SCART lead into the AV2 input. I believe this is a 'smart' scart plug (same as SONY but it is not mentioned as in the literature). The AV1 is only good for inputs NOT outputs as well.
Oct 04, 2008 | Televison & Video
Digital audio out jack
That output only works with digital signals (digital tv channels and digital audio from the hdmi in jack).
The HDLCD2600 has no analog out. Sorry.
Aug 14, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Sony SDP-EP9ES
It is a preamplifier with sound processing which is sometimes referred to as pre pro... There is a simple solution to lack of DTS, the unit has 5 analog bypas inputs, bypass as they do not go through units Digital Signal Processing circuitry and DD processor.
If you have a DVD/BD player that has five (or more) analog outpusts you plug them in into your preamp and have the player decode DTS to analog signal. If the player has five analog outputs it mostly like has the on-board decoder. Other than this you can use a stand-analog DTS decoder in the same manner but it sounds like a cumbersome and costly alternative. Hope this helps.
Apr 26, 2008 | Sony SDP-EP9ES Receiver
556 people viewed this question
 Grubhead
Grubhead
