Casio fx-5000F Dim LCD screen even with new batteries. Screen only visible when viewed on an angle with new batteries.
damnthing
SOURCE: casio fx-260 solar fraction calculator
It's not suppose to get off the screen. Unless your trying to switch modes, which deg is what you normally would be using. If not then it says it right on the front of it.
Posted on Feb 16, 2009
  • 4 Answers
SOURCE: casio fx-570ES calculator inner screen cracked
There is a faint metal coating on the glass where the cable attaches, you would have to find another screen with the same spacing, of the horizontal and vertical lines, and try to attach the horizontal and vertical cables to that.
Posted on Apr 24, 2009
vladp995
  • 81 Answers
SOURCE: My Casio fx-85v Super - fx solar power calculator shows a erratic
Yeah I had the same problem, you need to open your calculator and check if all the screen cables is alright, i had just put sellotape on the back of the screen from inside so that the screen hold better, and it works for me if for you not maybe something broken in the schema but try it. The thing I know for sure the problem is in the screen or from where it get the data the schema. Tell me if it's working
Posted on Jul 07, 2009
  • 7993 Answers
SOURCE: can't find angle measurements function on casio fx 9750
In [RUN], screen press [OPTN][F6:->][F5:ANGL] [EXE].
Exemple 18.53 deg
18.58 [F1 Degree symbol] [EXE] shows 18.58. At the bottom of the screen appears a new option DMS with a left arrow. By pressing the corresponding key [F5], the screen displays 18 deg 34 min and 48 secs. To enter an angle in DMS, exemple the one above, you procedd as follows:
18[F4]34[F4] 48 [F4] [EXE] displays 18.58
Hope it helps.
Posted on Oct 03, 2009
  • 24 Answers
SOURCE: can the battery die in a casio fx-300es? it says
i think so, mine died
Posted on Dec 02, 2009
I am using fx-991ms calculator.The numbers are not visible.How can i increase the brightness of the screen.
when the battery gets low the display digits will dim, but not always the case, you can try sticking something under the calculator to to change the angle of the screen.
Feb 18, 2015 | Office Equipment & Supplies
How to change from degrees to radian mode casio fx-cg10
In Run>Mat screen press SHIFT MODE to enter the setup screen. Scroll down to the line Angle. Press F2:Rad to set angle unit to radian, See Screen capture below.
Jul 06, 2014 | Casio FX-300MS Calculator
I have casio fx-82MS scientific calculator.which display 'd' letter on the screen.after i switched off the calculator even it wont delete.how do i get rid of that?and is it cause my reaguler...
Most likely you set the angle unit to degree. As long as you do not calculate trigonometric ratios you won't get incorrect results. Switch the angle mode to radian if that is what your calculations require.
Aug 21, 2013 | Casio FX-82MS Scientific Calculator
How can you change the mode on a casio fx-9860g calculator to deg. mode?
Press SHIFT MENU to bring up the setup screen. Use the arrow keys to move to the "Angle" line and press the function key for the desired angle mode.
Mar 04, 2011 | Casio FX-9860G Slim Graphic Calculator
How the heck do you change a casio fx-9750II from radian to degre
  1. With calculator turned on, press [MENU] if you do not see icons.
  2. Use the navigation arrows to highlight [RUN-MAT] icon or press 1.
  3. In the Run-Mat screen press [SHIFT][MENU] to enter the (SETUP).
  4. Press the DownArrow 5 times to highlight the ANGLE option.
  5. Press [F1:Deg] to select degree.
  6. Press [SHIFT][EXIT] to (QUIT) the SetUp screen.
  7. Do your geometry ( I would say trigonometry).
Apr 07, 2010 | Casio FX-9750GPlus Calculator
Casio fx-300es---how to convert radians to degrees
You use the key combination [SHIFT][ANS] (DRG>).
If the default angle unit is degree
Type in the angle value in radian, say 1.2.
Press [SHIFT][ANS] (DRG>).
The screen displays 1: deg symbol, 2: a raised r for radian, and 3; a raised g (for grad).
1.2 [SHIFT][ANS] (DRG>) [2: raised r] .
The screen displays 1.2 with a raised r to the right of the 2.
Press [=].
The answer is 68.75493542
Dec 02, 2009 | Casio fx-300ES Calculator
Motorola cordless phone - can't read the screen any more. I ttok out battery and replaced it , but still the same.
Is the screen a LCD? These screens are difficult to read and only by changing the viewing angle makes it visible. If the screen has completely become black or all the numbers look like 8's? Since you've already replaced the batteries,eliminating all electrical malfunction my instinct is of the leakage of liquid in LCD screens( remember the old calculators, and how it responded if the screen was pressed hard). In that case the entire display screen will have to be changed. If it isn't cost-effective, I guess instead of attempting repair--------- get a new phone.........sodeep
Oct 21, 2009 | Uniden Cordless Phone
Can't find angle measurements function on casio fx 9750
Exemple 18.53 deg
Hope it helps.
Aug 20, 2009 | Casio FX-9750GPlus Calculator
Problem with Casio FX 260 Calculator
Read the screen capture about the MODES of this calculators. DEG,RAD, and GRAD remind the user that the angle units in trigonometric function calculations and coordinate conversions are in degrees, radians or grads. They have nothing to do with the other calculations you are doing.
You can only remove DEG by changing the angle unit to RADians or GRADs. In so doing, the new unit indicator (RAD, GRAD) will be displayed instead. There is no point worrying about the angle unit indicator unless you are performing coordinate conversions or calculating trigonometric functions or the inverse trigonometric functions.
MODE 9 cancels the FIX display format: decimal are displayed with a fixed number of decimal places (set by the user). After this key sequence the decimal display format reverts to NORM(al).
Dec 03, 2008 | Casio FX-260 Calculator
Casio Fx-82TL calc display problem
it seems the problem is on the lcd. technicians usually use soldering iron to apply heat to the cable connecting the lcd to its mainboard.
Sep 16, 2008 | Casio FX-115ES Scientific Calculator
107 people viewed this question
jasbo
jasbo
