Question about Sony OM MHC-GX555/GX355/GX255/RG170 Shelf System
Hi, I have a SONY MHC-RG170. I'm experiencing a problem with CD player. I cannot open the box and when I try to play it, the message Mecha error appears. I'd want some to solve this problem. Serigne
SOURCE: Erratic CD tray behavior on SONY MHC-881 Shelf system
change cd head
Posted on Nov 27, 2007
  • 3 Answers
SOURCE: shelf cds is blocked SONY CMT-HP7
To get the cds to play, and 5 to eject, you can try taking off the sides of the consul and using compressed air. As for the shelf problem, I'm not really sure.
Posted on Jan 19, 2008
junit80
  • 81 Answers
SOURCE: I have a Sony MHC-GX470 stereo...it will not play
the mechanism is bad or in human terms the motor that excepts and moves the disc has gone out i reccomend taking it to a repair shop to get a estimate because it may jus be cheaper to replace it.
Posted on Jun 26, 2009
ETRONIC
  • 62 Answers
SOURCE: sony mhc-gx450 cd player is not reading.I used a cd cleaner and d
First unplug the unit and press the power button to make sure all the power is out of the unit. Try to take a cotton qtip and clean the lazer lense with alcohol. after wipe it clean with a new cotton qtip to remove the film the alcohol produces. Do not use a lot of alcohol and drip it all inside of the unit though.
Also if you tried a cd-r try a real copy instead. Make sure your cd's are ok.
Good luck.
Posted on Feb 16, 2010
  • 713 Answers
SOURCE: Have a Sony MHC-GX255 showing
replace fuse.
Posted on Feb 22, 2011
In my sony home theatre MHC - GZR88D i want to play music as dvd , usb ,etc.... ,don't played only one word is shown that mecha error , what can i do
Probably means there is something wrong with the DVD drive. Check that a disc is not inserted wrong. You could also try cleaning the DVD lens.
Jun 28, 2015 | Sony Audio Players & Recorders
Sony mhc- rg 55 MECHA ERROR disc spin then turn off
My mhc-rg 55 shelf system reports a Mech error when I turn it on (after rotating the CD tray to try to take up each CD twice ) Then is shuts down.... I took the unit apart and saw noting obvious... (Of course it was more difficult to reassemble and still doesn't quite fit properly.) But the problem persists. Looks like it over to the repairer. Sorry - No solution here
Nov 21, 2012 | Sony MHCEC99 Mini MP3 hifi system Shelf...
How to fix mecha error on sony mhc-gx555
https://us.en.kb.sony.com/app/answers/detail/a_id/38877/~/the-stereo-system-malfunctions,-stops-responding,-or-displays-mecha-or
Jan 09, 2012 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Why My sony Mini Hi-FI MHC-GZR88D says Mecha Error
How to resolve mecha error in sony mhc-gzr88d
Oct 08, 2011 | Audio Players & Recorders
Cannot open cd tray. Cannot rotate cd's. Plays only one cd and intermittently. Get 'mecha error' message. Had similar problem last year without 'mecha error' message, which was...
In some cases this is due to the main spindle getting jammed or there are mechanical errors which as mentioned needs a reset.
Also in some cases when the CD does not play it is possible that the optical head is a suspect. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD . If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
Sometimes certain cleaner disks will not be tracked to run for cleaning as it will not be read and so will reject. Hence it is ideal to manually clean the laser head eye using a cleaning swap /cotton bud with gentle pressure on the lens eye.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
Jun 25, 2011 | Sony MHC-RG290 Shelf System
I have a Sony MHC-GX470 stereo...it will not play cd's...when you load a cd in it comes up with "mecha error"...the cd changer will not move between cd 1, cd2 and cd3 either.
Jun 26, 2009 | Sony MHC-GX470 Shelf System
DespLady
It is error message of HiFi when it finds problem in Tape Mechanism. Tape mechanism is stucked and needs to be reset. Open your HiFi and rotate the capstan wheel with finger and then try to power up.
Jul 20, 2008 | Sony MHC-GX450 CD Shelf System
Shelf cds is blocked SONY CMT-HP7
Nov 09, 2007 | Sony CMT-HP7 CD Shelf System
Kenwood 10 disc changer
i have a sony mini Hi-Fi Component System MHC-GX470. I comes on, the Radio and Tape deck plays well. the CD Player says "mecha Error" and hangs. CAN YOU PLEASE HELP ME???
Jun 23, 2007 | Kenwood KDC-CMP59FM 10-Disc CD Changer
212 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
