Question about Toshiba Computers & Internet
I have toshiba satellite c650 laptop but laptopb locket with power on password so please guide me how to reset password on toshiba satellite c650 password
  • 2,296 Answers
To reset the BIOS read the information from this link.
In case of your Toshiba laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Posted on Dec 29, 2010
Need to replace dvd player in Toshiba Satellite C655
http://www.youtube.com/watch?v=ChrYyWjaEMY Toshiba Satellite C650 L675 DVD Replacement Guide Installation -- L670 C655. Install Fix Replace CD DVD/RW Optical Drive Burner. This guide is useful for these laptop models: TS-L633 - 142, V000210060, C655D, C650D, L675D, L670D
Jan 30, 2013 | Toshiba Satellite A135 Notebook
Toshiba Satellite C655-S5125
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
11th heading down - Satellite A10. (A10 in Blue)
Go down to the second line, (Begins with A350D in blue), and click on -
C650. (You can also click on C655D )
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/disassemble-toshiba-laptop-1.htm
Now what is the problem? Post in a Comment.
Apr 21, 2012 | Toshiba Computers & Internet
Toshiba satellite c655 hinge replace
If you don't have the experience on disassembly the Toshiba Satellite c650 c655 laptop, we suggest you refer to the official maintenance manual firstly if you have. Here we provide a universal instruction for the reference, some steps may be not the same. If you need a detailed guide or manual, please contact us, we will email you if we have.
1. Please turn off your Toshiba Satellite c650 c655 laptop, disconnect the power adapter and remove the toshiba satellite c650 c655 battery.
2. Turn the laptop over. Remove the screws (may not exist) that hold the Toshiba Satellite c650 c655 hinges on the back of the computer.
3. Remove all the screws (may not exist) that hold the keyboard and keyboard bezel in place, then gently pry keyboard bezel using a flat head screwdriver. Lift the keyboard and unplug the keyboard cable from the motherboard to remove the keyboard. Now, you will see the toshiba c650 c655 laptop fan
4. Detach both hinge covers using your fingers. Unscrew the screws securing the Toshiba Satellite c650 c655 hinges to the laptop base.
5. Locate the screws on the LCD, pry the rubber screw seals using a flat-head screwdriver. Unscrew the screws attached under the seals. Remove the screen bezel.
6. Remove the screws securing the hinges d to the Toshiba Satellite c650 c655 LCD.
7. Now, you can remove the old Toshiba Satellite c650 c655 Hinges by sliding them out. Insert the new hinges in their correct place. Reverse the above procedure to assemble the laptop.
Mar 11, 2012 | Toshiba Satellite C655-S5068 Notebook
How to take shell off toshiba c655-s5049, i need to reset mother board
Pictorial disassembly guide for the Toshiba Satellite C655 and C650 series of Notebook PCs,
You can click on each photo one at a time, to enlarge.
Advisement:
1) Observe Anti-Static Precautions
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware components inside a computer.
I suggest you buy, and wear an ESD wrist strap, and connect it's alligator clip to a good ground source.
Example of an ESD wrist strap,
http://www.radioshack.com/product/index.jsp?productId=2103245
I connect to an unpainted surface, of the metal frame of an empty desktop computer case.
If your table you're working on has metal legs, connect to an unpainted surface on one of them.
Barring none of the above applies, at least place a large metallic unpainted object on the table, and connect to it.
Perhaps a metal serving tray, or metal (Unpainted) knickknack.
2) Use a multi-compartment container for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
If no multi-compartment container is available, use a clean egg carton.
label each egg holder.
Some screws look VERY similar to other screws.
Do Not mix them up.
What do you mean by reset motherboard? If your thinking is that you are going to remove the CMOS battery for a while, then reinstall it to clear a BIOS password, this = no.
There is a capacitor on the motherboard which keeps enough residual power, so that the BIOS password stays in play, even with the CMOS battery removed.
(The CMOS battery is referred to as the RTC Battery. Real Time Clock battery.
As soon as the Keyboard is removed, it is right there on the motherboard. Uses the same battery holder as a desktop computer, and it looks to be a CR2032, just like a desktop CMOS battery )
There are two pads which are shorted across briefly, with a small flat tip screwdriver.
Usually rectangular in shape, and each approximately the size of a BB.
This drains the residual power from the capacitor.
Location? Dunno
Generally under a small piece of Mylar plastic sheet, and sometimes under the Ram Memory modules, or under the wireless module.
Also, this link has a free Service Manual,
Under the Toshiba main heading scroll down to the subheading that begins with -
Satellite A10.
Go to the second line in this 'paragraph', and scroll across to C650.
Left-click on C650.
(You may also want to take a look at C655D)
After you click on the file name C650, it may take up to 30 seconds before the first page comes up.
It may also take additional time for the file to fully download.
Regards,
joecoolvette
Oct 11, 2011 | Toshiba Computers & Internet
My laptop is TOSHIBA C650 SOME OF MY KYES ARE NOT WORKING. PLEASE GUIDE ME. I AM STAYING AT ANDHERI MUMBAI. PLEASE LET ME KNOW THE NEAREST SERVICE STATION .
if it were to be that im not in Nigeria i would have serviced for you but the Best option for you is to get another Keyboard fixed for you laptop..
so pls go buy another and fix for your laptop...
for a lasting solution.
Pls remember to rate meeeeeeee
Dec 24, 2010 | Toshiba Computers & Internet
I want all the drivers of Toshiba Satellite Pro c650. Please its urgent. Thanks.
Please visit http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Communicate
Select the Downloads
This is how you need to select your model number and then select the operating system you have in your system.
Then you will get a list of drivers for your laptop.
Regards
Anand Sachan
Nov 02, 2010 | Toshiba Satellite Pro C650EZ1521 Notebook
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
Computers & Internet Logo
642 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
