Question about Canon iPF700 InkJet Printer
MY CANON PLOTTER SHOWING HARDWARE ERROR 03800500-2F2F. HOW TO OVERCOME THAT. PLS SUGGEST.
Error code 03130031 2618 print
The hardware error code indicates that a print head failure has been detected. Other possible causes of this error are a faulty cable connection to either one of the PCB's.
First try replacing the Print Heads and if the problem persist, re-seat the cabling to the Relay PCB and the Carriage Unit PCB.
Since you are unable to access service mode, you will need to ignore the normal print head replacement procedure and replace the printheads whilst the plotter is turned off.
The plotter will need to be disassembled to access the print head.
See the following service manual for a detailed guide:
http://mail.davin.be:8888/CANON/BOOK%20IPF/IPF750/ipf750_755-sm.pdf
Nov 06, 2013 | Canon imagePROGRAF iPF8000 Printer
Hardware error
hello, can you specify what error number is?...i have a service manual for this ipf710 plotter and i can tell u what is wrong with it or you can download the service manual from the below link:
http://goo.gl/daFE3c
good luck
Sep 11, 2013 | Canon imagePROGRAF IPF710 Printer
My canon ip2700 colour wont print
how to overcome my ip 2700 canon 006 error?
May 10, 2012 | Canon Pixma iP2700 InkJet Photo Printer
Hp plotter 500ps problem by when given the command affter than plotter show on display system error 81:01. pls give to soluction.
Have you solved this problem, as I post it's 3 months old. This is a serios problem and refers to paper axis shut down.
Jun 08, 2011 | HP DesignJet 500ps InkJet Printer
System error on plotter screen
Follow-up to previous message... ended unexpectedly.
Enter the test mode and run the ELECTRONICS test. The plotter will tell you in plain English what the problem is. If it hangs up, power down.
Jul 06, 2010 | HP DesignJet 1050c plus InkJet Printer
CANON iX500 error 5C10
5C10 error message. cancel the print job and turn printer off. for 5min by unplugging it from all source of power supply this will occasionally rectify the problem, hope this helps pls do let me know
Mar 31, 2009 | Canon Pixma iX5000 InkJet Plotter Printer
Canon ipf 8000 Error Code E161-403F
I have had two of my Canon plotters give this error.message, I had to manually move the carriage unit and replace the printhead. On one of the plotters the error message returned, on the second plotter I was able to go into service mode where it asked me to replace the printhead. I just went though the motions since the printhead was brand new and I was able to get the plotter to function correctly.
Feb 21, 2009 | Canon imagePROGRAF iPF8000 Printer
Canon iPF 8000: Hardware Error 03800500-2F2F and 03800500-2F30
it's a multiple problem....there is no enough ink for the head managment sensor to understand the good function of the print head.
Print a nozzle check to see what is going on
Then come back for more information
Feb 10, 2009 | Canon Office Equipment & Supplies
File not opening-Disk Network error
I got a .mbd extension file and unable to open this? could you suggest me how to overcome this issue
Jan 07, 2008 | Microsoft Office Access 2003 (077-02871)...
Canon iPF700 InkJet Printer Logo
213 people viewed this question
old marine
old marine
