Question about Panasonic KX-T7630 Corded Phone
We have the Panasonic KX-T7668 phones in office, it is now no longer showing the incoming call numbers on the display, just the word 'Main' Any ideas ?
SOURCE: caller id
try pressing the transfer button when the phone is ringing (without lifting the handset) - it should work through a cycle of displays until the phone number is displayed.
Posted on Jan 30, 2009
  • 146 Answers
SOURCE: forwarding a call
Lift handset, dial 3 or 6 ( depending on model) - key outside line access code - key phone number (eg mobile)- key # - hang up
Posted on Jan 08, 2008
doctox
  • 51 Answers
SOURCE: Transfering incoming phone calls Mod. Panasonic KX-T7730
do you mean call divert?
its possible.
we could do it.
Posted on Jan 17, 2008
  • 65 Answers
SOURCE: Caller Id does not always show up
call panasonic 1-800-211-7262
Posted on Feb 05, 2008
SOURCE: Panasonic KX-TG6051M 5.8 GHz -Caller ID view problem
I have a panasonic KX-TG6051CM 5.8 phone with 3 handsets. After less than a year 2 of the 3 handsets developed the same problem, almost in the same time ( a couples of hours apart). The battery indicator shows low battery and is charging continuously even though the battery is fully charged ( when i swap the battery with my 3rd handset, the battery indicator shows fully charged and works fine ). The handsets were never dropped, never used in a moisture ladden environment ( like bathroom ) and when not in use they were kept in the charger. Any help or suggestions will be much appreciated.
Posted on Mar 24, 2008
INCOMING CALLS SHOW "601 DAY" ON THE PANASONIC KX-T7630, THE CALL DISPLAY IS GONE, HOW DO I FIX THIS?
Next time you have an incoming call:
-Leave the handset down (do not answer the call).
-Press the 'transfer' button to scroll through the different displays until the caller ID is shown.
-Lift the handset to answer the call.
-The next time you have an incoming call it should show the caller ID.
Nov 15, 2016 | Panasonic KX-T7630 Corded Phone
How to stop / edit all incoming calls ringing to other 2 extensions at the same time?
What phone system are you using?
I will gladly show you how
KX-TEA/TES/TA series or KX-TDA/TDE/NCP series
Oct 25, 2015 | Panasonic KX-T7633 Corded Phone
Phone Display
Panasonic KX T7633 user manual pdf
the link above is the manual
The Panasonic KX-T7633 is a telephone that will satisfy your demand for a user friendly operation. You can enjoy the hands free conversations offered by the speakerphone facility that the Panasonic KX-T7633 features. The 2.5 mm headset jack that you will find in this Panasonic KX-T7633 phone will enable you a hands free usage for paperwork or PC. It has a 3 line LCd that gives you a readable and clear display. It is available in charcoal and white color. This phone gives you an opportunity to choose the right color that will go along with the d?cor in your home or office. This device looks professionally because of the executive design. The Panasonic KX-T7633 has 24 programmable keys with dual color LED. It also has a 3 line caller ID LCD with back light. You will love the headset jack. It supports caller ID. The Panasonic KX-T7633 has a speakerphone, Intercom, automatic redial and an LCD display. There is a chance for 8 way conference call. It also features a digital XDP (eXtra Device Port) jack. I warmly recommend this phone for your home or office. You will be extremely satisfied. Panasonic phone models are very durable and you can use it for years to come. It will serve well to your every wish. Before using the Panasonic KX-T7633, it is recommended to read the Panasonic KX-T7633 user manual. If you have lost yourmanual, you can always download one here, free of charge: DOWNLOAD PANASONIC KX-T7633 USER MANUAL PDF
Jan 07, 2014 | Panasonic KX-T7633 Corded Phone
My KX-T7730 can't display, no tone.
KX-T7730 Phone must be connected with a 4wire line cord. you may be tested it with a 2 wire line connector.because other normal phones only needed 2wire line cords.Just connect a new 4w cord to under socket located to main unit & other end connect directly to the tel;system & see is the phone confirmed OK.
& let me know .Good luck.
rishanranatunga@gmail.com
May 25, 2009 | Panasonic KX-T7730 Corded Phone
Caller id
Nov 18, 2008 | Lands Phones
Display for Caller Id incorrect
After calling Panasonic US at 1800-211-PANA (7262) regarding my kx-tga5420 and kx-tg5230 system's handsets.
On the handset, verify that Caller ID Edit is turned on first.
Menu-->Initial settings
Go to Caller ID edit
Select Auto edit ON
Save
Exit the menu
On the handset main display
Hit the button that relates to CID
Scroll down until you find the desired 1-xxx-xxx-xxxx number that you want to
be displayed as xxx-xxx-xxxx
Hit the edit key until you see the number displayed as xxx-xxx-xxxx
Save
(Note: You have to initial a call once you have saved the change.)
Now hit the TALK button to dial this number
Now when you receive calls from this number it wll show as xxx-xxx-xxxx instead of 1-xxx-xxx-xxxx.
Jul 06, 2008 | Panasonic KX-TGA520M Cordless Expansion...
Panasonic KX-T7668 Name Display
I just managed to do this on my own phone.
Press programme button, enter programme number (**1234), using the up down arrows move to number 004 which should be xtension name. Press clear, to delete any information, then enter new name using keypad. When complete press enter in the middle of the up down keys, pick up and reset handset and it should be stored.
Jun 03, 2008 | Lands Phones
KX-T7730, all the phones connect with operator ring at the same time when having an incoming phone
please i need your help,i use KX-T7730 in my office and of recent when incoming calls comes in all the phones in the office starts ringing and also i would like to know how i can lock and unlock the phone so as to prevent other users from accessing it.Thanks
Apr 10, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7630 Corded Phone Logo
284 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
