Question about HP Office Equipment & Supplies
I have a hp laser jet P 3015 he display the error fuser error 59.1 how to resolve the problem
  • 37 Answers
The error means that there is a motor startup error. Try to:
1. Turn the printer off, and then turn the printer on.
2. Check and reset the fuser and toner cartridge to make sure they are not hindering gear movement in the drive train.
3. Check the main motor's cable to ensure that it is seated properly.
If the error persists, replace the main motor.
Posted on Dec 29, 2010
Hp laser jet pro 400 m401 printer 59.A0 error
SOURCE:HP color laser jet printer is displaying error
Developing disengaging motor error. Run the component test to verify that
the print developing disengaging
motor is working correctly.
. Reconnect the connectors J468 and
J1020 between the developing
disengaging motor and the DC
controller PCB.
. if motor is not rotating Replace the developing disengaging
motor.
or
problem due to cairtage leaver lock cairtages not engage properly i hv found max problem of this leaver it found damaged due to improper opening the doorpls follow
above steps if problem not resolved then call hp engr for 4th step.
I Hope It Works.
Sep 15, 2017 | HP Office Equipment & Supplies
Hp color laserjet 5500 error 59 ck printer error
list of error codes
http://www.printertechs.com/printer-troubleshooting/hp-error-codes/195-numeric-error-codes-50-59-hp-laserjet
HP COLOR LASER PRINTERS 4600, 5500 ERROR 59.3, 59.4 1. A fuser motor error. 2. Replace the fuser drive assembly. 3. Replace the D.C. controller board.
Jan 04, 2017 | HP Office Equipment & Supplies
i have nOt used this site before but i believe they do have a description of the error code you describe. it said problem is defuser or main motor error, heres the link
HP LaserJet Error Codes 50 59
Apr 20, 2016 | HP Office Equipment & Supplies
I have an printer Laser jet HP P2055d the problem is 59.f0 error i need every body help thank you
This is a hardware problem, time for a new printer, below are the causes for this error:
  1. Transfer belt is locked up and cannot rotate.
  2. Sensor SR17 (primary transfer-roller-disengagement) is bad.
  3. Damaged or broken fuser drive gear. Typically, a grinding or clicking noise will be heard during boot up.
Mar 15, 2016 | HP LaserJet P2050 P2055DN Laser Printer -...
HP PRINTER LASER JET 600 ERROR 59.00.90
HP is one of the most reputed tech brands known for its range of unique and high-end printers. Although the printers and scanners are manufactured with the highest quality parts and technology, the devices are still prone to errors and defects. Some of the common issues faced by people while printing and scanning are printing error, connection errors, invalid print commands, cartridge issues etc. So why you waste your time call now: 877-690-9305
Support For Hp Printer Call Toll Free 877 690 9305
Jun 17, 2014 | HEWLETT PACKARD - LASER JETS HP LaserJet...
Hp laser jet 3015, 7 horizontal lines, with ghost images printing/copying.
Hi:
Ghost images or repetitive image defects can be caused by one of two things. Either your toner cartridge is defective or your fuser is bad. The fuser is the component that heats up and fuses the toner to the paper. To determine which one it is do this. Start to print or copy something and shut off the printer just as the paper is going under the image drum but before it enters the fuser. If the problem you described is evident on the paper at this point then the problem is related to the drum. If the problem is not showing up on the paper at this point then the fuser is the culprit and it most likely would cost more then the unit is worth to repair.
Andrew
Nov 12, 2013 | HP LaserJet 3015 All-In-One Printer
59.50 error on HP laserjet 3015 printer
Possible solution:
2. Check and reseat the fuser and toner cartridge to make sure they are not hindering gear movement in the drive train.
4. If the error persists, replace the main motor.
*If you need any technical help on printer then you can reach at http://www.vtechsquad.com/printer-support/
Apr 08, 2013 | HEWLETT PACKARD - LASER JETS CE526A...
Display showing error 59.C0 on Hp Colour lasejet 3600 printer
59.C0 ERROR
An error occurred with the developing separation-drive assembly.
1.Check that the following connectors on the driver PCA are seated correctly: J403, J405, J213.
2.Check that connector J1020 on the DC controller is seated correctly.
3.Check that connector J5008 on the fuser motor is seated correctly.
4.Replace the developing separation-drive assembly.
5.Replace the memory-controller PCA.
6.Replace the fuser.
Jul 11, 2011 | HP LaserJet 3600n Printer
Hp color laser jet printer is displaying error 59.co on the display pannel
controller PCB.
motor.
or
problem due to cairtage leaver lock cairtages not engage properly i hv found max problem of this leaver it found damaged due to improper opening the doorpls follow above steps if problem not resolved then call hp engr for 4th step
May 14, 2010 | HP LaserJet 4700 Printer
HP 3015 laser printer with ghost image
A fuser image should only be about 1 1/2 inches away, 3 inches sounds like a drum problem.
Aug 03, 2009 | HP LaserJet 3015 All-In-One Printer
167 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
