Condensor fan fuse keeps blowing motors and boards have been changed but same result in few days
  • 2,133 Answers
Dear friend, without knowing exact problem changing parts is not advisable. With your statement I could understand that condenser coil full of dirty- clean it. And then check capacitor for compressor by reading amps. If amps gradually increase capacitor to be replaced. And also wiring for not short circuited.
Posted on Dec 29, 2010
98 Dodge Caravan keeps blowing the wiper fuse. Works for a few seconds then blows.
check for bare wires grounding out , wiper motor failure or wiper shafts seizing up and overloading the motor
using a bigger fuse will only result in the wiring harness burning out and possible fire in the car
May 21, 2017 | Dodge Cars & Trucks
Condensor fan goes on low speed on hot days resulting in poor cooling, some days works fine, i checked pressures on days it was working normal.
Does it have a Motormaster feature? Motormaster controls condensor motor speed to control high pressure. A condensor thermal sensor signals the control board, don't forget to test the thermistor, stick it in ice and hot water and look for a speed reaction.
Heat pumps have a relay that switches the outdoor fan to low speed on Heat mode, this relay or its signal may need some checking.
May 18, 2015 | Filter Heating & Cooling
I have a 2002 dodge ram 1500 4.7L engine. Air conditioning only blows cold air when vehicle is moving; warm air when idling... please help. Thanks!
Start by checking the condensor fan to make sure it is running while you have the ac on. If it is not blowing check the condensor fan motor fuse that is located in the totally integrated power module. If the fuse is bad it is most likely that the condensor fan motor is bad and is drawing too much amperage and will need to be replaced. Now I am assuming it has an electric condensor fan motor. Make sure that the condensor is free of debris, a dirty condensor will cause high discharge pressures that will cause poor or insufficient cooling at idle.
Aug 26, 2013 | Cars & Trucks
Ford focus 2006 engine overheating once ac swicth is on..
CHECK TO SEE IF COOLING FAN IS RUNNING.IF NO CHECK COOLING FAN FUSE AND RELAY.THE COOLING FAN NEED TO BE RUNNING WHEN AC ON BECAUSE AIR CONDITIONER PUT A LOAD ON ENGINE.COOLING FAN KEEP RADIATOR AND AC CONDENSOR COOL.FAN NEED TO RUNNING.
Sep 04, 2011 | Ford Focus Cars & Trucks
My A/c is out in my 1997 accord and i think i found the problem..In the mornings when the air outside is cold, my a/c does blow out cool air, and when it's hot out, the a/c blows out hot air. The problem...
no, your condensor fan motor is not working. if its faulty, install a new motor. not the fan leaf, only motor assembly. its cheap too. but first you have to check refrigerant leaks. then check condensor fan. thanks
Jan 28, 2011 | 1997 Honda Accord
Lilair condintioner not cold,condenser fan not blowing fuse keeps blowing out what can be done
you most likely have a bad fan on that condensor for a/c. look also for naked wires on or around fan motor. if none found, try replacing the fan motor.
Aug 19, 2010 | 1997 Honda Civic
The AC in my 2004 Honda Accord only blows cool air when I am driving at higher speeds. When I drive slow or am stopped, it's warm hair coming out. My mechanic said the compressor isn't working properly...
it is a premature failure, That does indicate a bad/failiing compressor, or low oil charge, to low freon. If you trust the mechanic then go witht he compressor replacement and condensor. Unfortunately most oarts stores/shops require the condesor to be replaced for warranty purposes on compressor replacements.
Jul 22, 2009 | 2004 Honda Accord
Bottom blower dose not go on
you should have two wires that go to a capacitor for turning the motor the right way durring start up then you should have two wires for run current. Now my motor has red and blue as the run voltage and blue and a white wire to the capacitor -6uf+/-10-5%@250AC. This cap is mounted on your fan shroud and refer to you top motor wire configuration, as both blower motors is in like the same wire colors to cap. Now my lower motor keeps blowing the thermal fuse and dose not overheat as the thermal needs at least 360 degrees of heat to blow yet my moter when running is not that hot.... I would replace the motor and cant seem to find one where did you find yours.
Apr 25, 2009 | Windchaser PAC9 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
