Question about Dishwashers
SMEG STX dishwasher does not complete the wash cycle, stopping after 3 minutes on all cycles displaying error code E1. The machine seems to start with the usual whirring noise but then stops after 3 minutes without pumping in water. The machine is a few years old now but has needed 2 new control panels already although this does not appear to be the problem this time. Any suggestions? Thanks DW
5 Suggested Answers
  • 641 Answers
SOURCE: Dishwasher LD-14AW2, stopped working mid cycle
Since water doesn't drain out ,it could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Posted on Sep 15, 2007
  • 116 Answers
SOURCE: siemens hydrosensor dishwasher SE25A091GB/22
If you are still trying to sort out this issue try the following.
From what you say then it is most likely the aqua sensor on the side of the dishwasher. The gurgling sounds that you hear are likely the drain pump running and the un-drainable water sloshing in the sump.
Verify that there is actually water going to the dishwasher( Basic step but often overlooked)
Next the inlet valve will have to be checked. This is the part where the water line from the house connects to the dishwasher, under the toe/kick panel. Remove power from the dishwasher. Disconnect the dishwasher electrical connections (2 wires) to the inlet valve and connect it (carefully to 110 V power) using a jumper wire. With 110V power the valve should open and water will flow into the dishwasher, if not then the fault is in the inlet valve.
If this checks fine then the fault is likely in the aqua sensor...
On the outer left side (viewed from front) there is a panel, Behind this panel there is a small clear(of light blue) plastic mechanism with hoses and wires attached( There is usually a yellow disk at the top about 6cm in diameter) this is a float and sensor assembly there is tells the control the water level and works as an emergency drain if there is an issue. There will be a red stick protruding downward to the base and a Styrofoam float on which the stick rests. This is a pan overflow sensor if the stick is too high the unit will go into drain and cut off the fill valve power. The yellow disk is a diaphragm which senses water height. This unit can become stuck with wear and hard water.
Posted on Jul 28, 2008
SOURCE: Dishwasher Smeg DWD409SS
Please go to
Posted on Aug 21, 2008
  • 423 Answers
SOURCE: What is an E1 error code for an LG Dishwasher? Model LD12AW2
Please check at both ends of the drain hose and confirm that you do nit have a leak. Also, please confirm that water is not leaking directly under the dishwasher.
If you are certain that you do not have a real leak, check the impeller (under the mesh filter in the sump area beneath the lower dish rack) is not damaged and is firmly in place.
The E1 error code is a Leakage Error, detected by the motor spinning faster than it should if the unit is filled with water.
Please report back with what you find. Good Luck!
Posted on Mar 30, 2009
My mass 6 Bosch washing machine is locked up and was blinking in red light letter F what do I do
"Sd" - (Excess suds)
F8 followed by E1 - (water supply error)
F9 followed by E1 - (drain pump system error)
F5 followed by E2 - (door will not lock)
F7 followed by E1 - (motor drive error)
"rL" - (remove load)
Washer making error beeps - Door has not been opened and closed for at least 3 cycles
Washer beeps when HOLD TO START is touched - Door not closed
F# E# code other than as described above appears in display - System Code Error
"nt" (interrupted) - Cycle was paused or cancelled
Clean Washer LED flashing at end of wash cycle - The washer has run 30 wash cycles and is indicating a reminder to run the Clean Washer cycle
Sep 21, 2017 | Bosch Washing Machines
What is E1 error code
The E1 error code indicates a water inlet error. Do you still have your manual to test for this?
Jun 20, 2014 | Kenwood KDW243A Builtin Dishwasher
Dishwashing cycle starts for about 3 minutes then flashing LE light comes on and the machine stops. Why?
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
The Blade is locked.
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Try the following steps:
Unplug the washing machine if you see an LE error on the two-digit display electronic readout. This error indicates a miscommunication between the control panel and wash motor.
Press and hold the "Start/Pause" button on the front panel for five seconds.
Plug the LG dishwasher back in.
Run a cycle. The LE code will clear.
Aug 31, 2010 | LG 24 in. LDF 7811 Stainless Steel...
LG dishwasher error code E1
E1 is a code that the dishwasher displays after detecting a leak. There is a sensor on the pan at the very bottom of the unit. Take the bottom front panel off, look under the unit at the hose coming off the pump and your fill line to be sure no water is dripping. Run the unit in a wash cycle while doing this if possible.
Nov 21, 2017 | LG Dishwashers
Smeg WD1 12C, error code 10
I have a smeg wd1 12c washer dryer showing error code e01 any idea how to fix it?
Nov 06, 2008 | Smeg WDI12 Front Load Washer / Dryer
LG Dishwasher making grinding noise then blinking E1 code 10 minutes later
Well done by resolving this problem. The other way to avoid the siphoning problem through the drain hose is adding an air gap valve/connector (available at any hardware store). You can use it even if you don't have a garbage disposal in your kitchen sink. That will assure that you have the proper height of the drain hose.
Hope this helps!
Oct 22, 2008 | LG LDF6810ST Stainless Steel Built-in...
SMEG DI 612CA. Dishwasher
Pisss!!! Comin from my asss!!
Mar 04, 2008 | Smeg Dishwashers
Smeg DI 612CA
Take a look at this link
Would seem to be the anti flooding device on the inlet hose
Nov 19, 2007 | Smeg 24 in. STX2 Built-in Dishwasher
This new....just call out LG to repair under warenty!!
Jul 22, 2007 | LG LDF6810 Built-in Dishwasher
Dishwashers Logo
70 people viewed this question
Top Dishwashers Experts
