Question about Samsung AW0603B Air Conditioner
Is there a drainage plug or hose on the air conditioner? It's leaking.
Air conditioner is leaking - I keep hearing about the drainage plug or hose.....is there one I can look at? Where is it? (Remember, I'm not a Mr. Fixya.......I'm a Mrs. Baker). Thanks. deejmcc
  • deejmcc Jul 07, 2008
    Thanks. I haven't seen a black plug. BUT I do see two metal type plugs. I may have to cut them or knocked them out and get a black plug to assist in the drainage process. deejmcc
  • 3 Answers
To increase the efficiency of the air conditioner's cooling to meet US energy requirements, most manufacturers eliminated the traditional drain plug. Instead, they switched to a design that used the extracted moisture from the room to help evaporatively cool the condenser.
To do this, the traditional fan blade was replaced with a 'sling blade' which was a fan blade with a rim or ring around it. The drain plug or drain hole in the bottom of the pan was eliminated and replaced with overflow notches in the back edge. Along with a solid piece drain pan, this provided a pool of water for the edge of the sling blade to dip into and pick up water to 'sling' or spray around the compartment to create evaporative cooling. The overflow notches established the maximum depth of the water pool and are also the lowest place when installed properly.
Although this is more efficient, this has caused 2 problems: increased noise as the water is slung around and water spray from the side air vents.
Persons have drilled holes through the pan or back edge as drains. This is not recommended as it negatively effects the colling ability of the unit and could lead to a voided warranty or premature failure.
Instead, insure that there is adequate pitch with the installation and make sure the overflow notches are kept clear.
If you 'need' a drain hose, my suggestion would be to drill into drain pan's back edge or the rear potions of the sides. The hole should be at the same level as the overflow notches. Once the drain hose is installed, block/cover the overflow notches to redirect the excess water to the drain hose instead.
Posted on Jan 14, 2009
If this is a window unit go outside and look under the bottom of the unit toward the back and if you see a black plog remove it. There could also be some slots cut into the back of the bottom along the back edge which are clogged up.
The unit must be installed with the outer caseing leaning slifgtly downward so water will towards the back of unit and out either through a removed black plug or slots cut into bottom of housing.
Posted on Jul 07, 2008
How to fix a leaking air conditioning unit
you need to specify the leak. is it water. in this case you need to open the cover, check the drainage cable and either use a thin metalic hanger to clear any plugged drain or you can use a canned air power spray.
Sep 05, 2014 | Samsung AS18A6RB Air Conditioner
My portoable ac is leaking on the floor . am i suppose to have a hose connected to the drain on the bottom in the back of the unit. please explain how i am suppose to drain my machine
a hose is only used for continued drainage in to a floor drain or sump. With out he hose, it's supposed to have a screw in plug to keep the water from flowing onto the floor. Then you would drain it into a low sided container that can hold at least 1 quart of water. Normally, the unit should warn you when it needs draining.
Hope this helped you.
Jul 02, 2011 | Amcor Heating & Cooling
Air-conditioning leaking inside car
  1. Air conditioner evaporator drain hose is blocked. Clear the drain hose where it exits the passenger compartment.
  2. Air conditioner evaporator drain hose is disconnected. Secure the drain hose to the evaporator drainage tray under the dashboard.
Apr 28, 2011 | 2005 Chrysler Town & Country
How to empty water out of unit?
drainage plug is really away to the ground, so you may want to place it on a hard surface or elevate it slightly to assist in the drainage function. You do get a short hose and drip pan in the box to help you empty the moisture into a larger pan, but you may want to keep a towel convenient as well.
Aug 03, 2010 | Soleus MAC-10K Air Conditioner
Wall unit leaking water new installationseems to be drain line problem.
I had this problem once. I took the front cover off the wall unit and located the the drainage hose and found a build up of dust which was blocking the outlet.
Jun 17, 2010 | Fujitsu 18C1 Air Conditioner
Constant leaking water
The unit must be level and the hose lower than the machine. -Good Luck-Ned_
Aug 23, 2009 | Frigidaire FAP094P1Z Portable Air...
Water in the Heater system
On the engine side of the firewall you need to find the small rubber drain hose. it is likely plugged up. dont stick anything hard in there or you can damage stuff inside the heater box.
May 27, 2009 | 1998 Ford Escort
Air Conditioner 3 in 1 danby SPAC12030 leaking water on the floor. No water in right side compartiment also no water in the back reservoir. Water leak from right side of the machine. From the right side...
I had that problem last year. When I took it apart I found that the drainage hoses that lead to the reservoirs were plugged with dust build up. I clean out the hoses as well as the rest of the insides. I have since placed the entire unit inside a shallow (under bed) style rubermaid tote and have not had any more water leaking. Hope that helps you.
Aug 04, 2008 | Danby Heating & Cooling
Danby PORTABLE Air Conditioner model DPAC10071 is leaking water from bottom base. The unit is 2 weeks old.
The base needs to be dumped regularly. The air conditioner sweats water during operation and the pan collects it. Your manual should give you the procedure on how this is done. In some cases there is a hose attached to the drain pan so that you can direct the drainage to a more conventional drain location.
Jun 27, 2008 | Danby Heating & Cooling
Samsung AW0603B Air Conditioner Logo
1,120 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
