Question about Danby DFF8803W 8.8 Cu Ft Frost Free Refrigerator & Freezer
An H is showing on Diplomat APM6855 cooler temp gauge
Running cooler than normal (indicated by temp gauge), hot air not hot, thermostat not the problem (recently replaced), check engine light NOT on.
as far as the temp of the air blowing...it in direct proportion to engine coolant temp...try a hotter thermostat....as for the faan running continuously that is a seperate problem and sounds like a faulty rheostat or fan switch...rheostat is elect, switch on the fan motor that enables different speeds and may beinternal on your truck. only parts store will know . if it is replace fan motor. if not , test switch and then test rheostat
Feb 09, 2014 | 2002 GMC Sierra 1500
We have just had a power cut and now the power is back on the fridge freezer is beeping it will not allow me to set the right temp inside. What shall I do? Make Diplomat fridge freezer APM6855-1
some times when the power is cut off and then turned on there is an "EMF" spike this spike in the power line will blow out an "IC" in the program bord,, if there is no built in protection for this
it often hapens to older units,,,
Aug 10, 2010 | Refrigerators
My 03 Jetta TDI temperature gauge had been indicating that the vehicle is operating at below normal temp some of the time. Even after a highway run. I had not had a rad flush in since l owned the car...
I think the light you are seeing is for low coolant. There may have been a small air pocket in the system. So just check the coolant level. If it is low add some. It's not uncommon to add a small amount a day or two after work was done on the coolant system.
May 18, 2010 | 2005 Volkswagen Jetta
Heaterblows cool air my temp gauge showing truck is overheating
change the thermostate and gasket after you change it let the truck heat up then cool then refill the radiator again after the thermostate opens do not open the radiaator with the truck hot or the upper hose hard
Dec 10, 2008 | 1992 Ford Explorer
Temp gauge cold and then heat turns not so hot
make sure the antifreeze is full. if so, replace thermostat and refill
Nov 20, 2008 | 1996 Honda Accord
Haier Wine Refrig runs to cold
change your temperature sensor, it's broken and it's going to down temperature
Aug 22, 2008 | Haier HVF042 Wine Cooler
Heating up
This may be normal, depending on the thermostat installed. They make optional thermostats of various temps. You can probably get a 190 degree thermostat. It will probably not have a significant effect on the engine operation, but may give you some peace of mind.
Aug 24, 2017 | 2006 Hummer H3
Refrigerators Logo
113 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
