Question about DeLonghi 6707E Oil Filled Radiator Heater
My radiator leaks oil after turning it on for about 10 mins. It worked ok for about 20 days, how can I fix the problem?
    Novelist:
    Champion:
  • 224 Answers
These are sealed units and should never leak or need refilled. If the unit is only twenty days old I would suggest that you return it to the store you bought it from and try another one. Sorry this is probably not the answer you wanted to hear but it is just the way they are, a sealed unit.
Posted on Dec 29, 2010
Yamaha radian overheating
Hi, Anonymous and the usual suspects are:
1. Engine oil level and SAE weight are too low or not circulating.
2. Insufficient or blocked air flow over the engine.
3. Heavy combustion chamber carbon deposits.
4. Ignition timing retarded due to faulty MAP, CKP, or CMP sensor.
5. Carburetor jetted too lean.
6. Leaking intake or exhaust valve.
7. Water coolant old or low change every two years.
8. Water pump failure.
9. Radiator clogged, cap loose or malfunctioning.
10. Radiator fans not coming on.
11. Clutch slipping, brakes dragging, heavy load, towing a trailer etc.
12. Idling too long without moving.
13. For constant hot weather temperatures, mountain, or desert riding conditions consider adding an oil cooler and or cylinder head cooler.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
yamaha radian starting running problems when warm
http://www.ringcar.com/15_4dddb4095a8f2e12_1.htm
Yamaha YX600 Service Manual
OEM parts for Yamaha
http://www.badrad600.com/Radian%20Manuals%20-%20Complete%20-%20Printable/Radian%20Owner's%20Manual%20Clean%20Complete%20Final.pdf
May 26, 2014 | Yamaha YX 600 Radian Motorcycles
Engine wont fire after over heating n freezing up over nite did fire after thawing out with no leaks
I am thinking that the coolant froze in the block and now you have major problems in the engine . Have a compression test done to check for head gasket and cracks
Jan 10, 2014 | 1986 Jeep Comanche
My 2000 jetta is leaking coolant , it only does this when i turn it off after a 10-20 min drive(im guessing this leak is somewhere within the heating core, since i cant find where that water is going , all...
take it to an accredited radiator shop and have the system pressure tested ' could be a cracked plastic radiator tank leaking under pressure
May 06, 2017 | Cars & Trucks
1999 Triumph Daytona 955i My bike overheats when stationary for 5+ mins. The temperature rises to the redline then piddles out of the expansion tank.The fan does not kick in with the bike running, but...
Hi, Chris_goslin and the usual suspects are:
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Idling and Overheating Video
Help Bike Overheating Motorcycle Forum
Triumph Daytona 955i 2002 Service Manual
http://www.triumphestore.com/
Triumph Daytona 955i Handbook
Apr 29, 2017 | Triumph Daytona 955i Motorcycles
Leak - upper corner radiator tried Stop Leak now smoking oil from
most likely not. unless your coolant system was nasty dirty gunked up. more likely, that steam coming out of the radiator is also in the upper part of your engine super heating it, expanding stuff too, too much. when it contracts, gaps open up that shouldn't. my guess is a head gasket or intake manifold gasket
Mar 26, 2010 | 2001 Jeep Cherokee
How to fix oil leak from top of a manual gearbox housing
sorry but its going to be a big job. you need to remove the gearbox to open up and get to the seals. you could try and use an additive in the gear box, its like oil seal for engine you can get it for engines gear boxes and difs and power steering. it sometimes goes by seek and seal, in older vehicles its quite good. you will need to replace the oil it will need to be done twice to clean it all out so it can get a good seal.. i.e change oil run engine get the gearbox to move for 20 min then change the oil as its warm not hot so let it cool down for 10-20 min then drain. put the seek and seal in and top up with oil and run as normal, check after a few days to see if its worked. usual does.
Jun 12, 2017 | 1995 Ford Ranger Supercab
Same problem , car has only 86,000 miles
replace that thermostat again...flush radiator any way...then see how it runs...
Aug 28, 2009 | 1996 Cadillac DeVille
Oil leak out of side of engine on a 02 Oldsmobile Alero
It's a very easy fix and can be done in under 10 min, may be 15 min. The oil pressure sensor has gone bad and is common to leak after a few years. The housing is made of metal and the top part is made of plastic, the plastic cracks due to time and you have a problem like yours. Auto Zone  sells the oil sensor for your car and can give you the step by step instruction to replace the sensor. It's best to change the sensor from the bottom and remove and replace the oil filter if you think you need more room. The other thing to if you don't want to replace it your self, you can pay the person at a garage to have your oil and filter changed and ask them how much more will he charger you to change the sensor. The sensor can be changed the same time the filter is so it's only going to take an extra 5 min to un screw the old one out and screw in the new one, like changing a spark plug. Good luck and hope this helps. Ok and buy some break parts cleaner to clean up all the oil so you don't have to smell burning oil all day when you drive.
Jun 19, 2009 | 2001 Oldsmobile Alero
Dodge Neon 98 Engine Oil Pressure
you might try and change the pcv valve, my car hand a similar problem in the summer and i never changed it. the pressure blew my cam seal and i was leaking oil like crazy. i dont know if it will fix it but they are cheap. i would give it a try.
Jan 14, 2009 | 1998 Dodge Neon
DeLonghi 6707E Oil Filled Radiator Heater Logo
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
