Question about Samsung Galaxy S GTI9000 Smartphone
I had the phone for one month and now yhe battery is going flat after 6hours low use. Even if the phone is fully charged and turned off,turn the phone back on again after 6 hours the battery is flat.
  • 1,188 Answers
Hi!!
Since the battery drains even when you have it off there is a hardware issue. I was going to tell you that it was either the battery or the phone. Since you say that the battery dies when the phone is not a factor, I would have to say that your battery needs replacing. I have the galaxy S captivate and my battery is great, I had the Vibrant also and it too had good battery life.
Good luck!!
EJ Kudelka
Posted on Dec 29, 2010
Blackberry 9720 suddenly went dead wont charge
Hi Michelle. I have the same phone and it happened to me a few times. On most phones the battery swells up when it reaches it's charging life end. In the 9720 the battery can still LOOK okay even though it might have reached its life-span. I eventually purchased a new battery, and wholaa, problem solved. A piece of additional advice is: Do not chat with you phone on the charger. Unplug the charger when battery is fully charged: We tend to charge the phone anytime and every time before we go to work or somewhere - you have to let the battery run flat on its own at least once a month, then start a fresh charge from fully flat to fully charged. This will prolong battery life. I a new battery does not solve the problem, have the charging pin checked out. Alternately if you know someone that has the same handset as you, ask them to stick your battery into their handset and visa versa. Hope this info help :)
Aug 26, 2014 | Blackberry 9720 Smartphone White, Factory...
Xperia X10i. Only four months old and all of a sudden the battery will not charge. Not from the mains or with the usb cable. I have even ordered another battery to go along with the car charger that I...
Hello,why the phone is still shutting down is because the cell of the battery is weak and can power on the phone for to long, that's why it shots down so quick,
You will need to replace battery with a new one for longer talk hours.
Make sure you charge battery for 6hours before use.
Take care.
Nov 16, 2010 | Sony Ericsson XPERIA X10 Cell Phone
My phone turns off randomly
I'd go to your local carrier store and get a new battery.
Oct 09, 2009 | LG RUMOR Cellular Phone
Battery
Your battery is gone, you will need to replace a new battery because the old battery is at it age. When you get a new battery, charge it 24 hour to fully charge it before you use, it is very crucial to maintaince the life of battery
Jul 20, 2009 | Apple iPhone Smartphone
Battery problems
You need to replace your battery.  When you do follow these steps to preserve battery life.
1.  Fully charge battery for 24 hours 2.  Make sure that you use the phone without charging it until the phone tells you the battery is low. 3. Fully charge the battery until it reaches full again.
The reason your battery is failing to hold a charge is a problem call battery memory.  The less power that you use off the battery the less capacity the battery has.
Jan 04, 2009 | Nokia 7270
Charging indicator stays red
Hmmm...is the USB cable plugged in to a powered PC? Could be cable or battery issue. Red light means that the battery is very low on juice. Return it to where you got it from if you can't solve it on your own.
you want a repair service
Oct 16, 2008 | HP iPAQ hw6965 Smartphone
Battery life under 5 hours
have you let the battery go totally flat as this is recomended to do every couple of months because if you dont let the battery go totally flat this stops the battery from full recharging and will cause bad cells in the batt so i would let hte battery totally flat till it wont even light phone up then fully charge for 16 hours see if this improves the battery if not then the charger is probably over heating and cutting off so you could replace the charge hope this is some help to you
Nov 19, 2007 | Samsung SGH-D900 Cellular Phone
Charging new phone
it wont harm your phone they just recomend 24 hours to make sure the bat is ok and that it gets fully charged but remember to let your bat go totally flat from time to time this will prolong the life of your battery as it does them no good just keep topping it up so i sugest to let it go totally flat say once a month this will keep your battery lasting longer between charge hope this helps
Oct 26, 2007 | Motorola Mobility RAZR V3
CELL PHONE TURNS OFF
I dont know the prolem.but i suggest u that dont repair it by urselves.Go to the service center and they will repair ur  cell in free,because it is under gurentee
Oct 23, 2007 | Motorola Mobility RAZR V3
I got a signal the battery was low, and now after charging my phone doesn´t start again??
Do a search on the site http://wiki.xda-developers.com/ Try the Keywords "Bricked"
Feb 02, 2007 | O2 Xda II Smartphone
Samsung Galaxy S GTI9000 Smartphone Logo
318 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
