Question about Karcher 1750 Psi Elec Pressure Washer
Pulsing, has started .changed electri/water supplies still pulsing. has been in use for 2hours thanks mark
I have pulsing water in my home, I have tried everything to resolve this problem, can you help
Do you have a water pump and live in the country? I would check the water pump first. If not, check your water lines for clogs. You may need to replace the water lines inside the house. Depending on where you live, they may be clogged with lime. Otherwise, I would check with your city or village to see if there's a problem with the city's water.
Sep 27, 2014 | Washing Machines
Hi. I have a 1990 c1500 silverado. Originally it had a manual gear box which was replaced with a turbo 700R4. Now ive put in a new engine and a turbo400. the T700 came with an electronic pulse generator...
I would use the electris set up for a 400,they were availiable in the late 80s and you can still get the parts.The rotor(tone) is different that 700 because inside hole is larger.You can buy a kit from GM to reprogram the cluster to match tire size and ratio.Calibration Kit - 25085515
Re-Programming Kit - 25084374
F-LENS - Clear Instrument Cluster Cover - 16130044
Feb 14, 2011 | 1990 Chevrolet C1500
What doe error code CE signify????????..
4. Troubleshooting
4-2
4-2. Service Inspection Mode
- Press the Delay Start + Normal + Power keys at the same time for two seconds to enter Service Inspection Mode.
- "ALL" is displayed for the first three (3) seconds and then "t1" is displayed.
- You can change the mode by pressing the Normal key. Each time the Normal key is pressed, the mode changes in the order of t1 ? t2 ? t3 ? t4 ? t5 ? t6 ? t7 ? t8.
- If you want to activate a mode while operating the dishwasher, the door must be closed (The Door switches are ON.)
- If an "oE", "LE" or "tE1" error occur, make sure to enter Service Inspection Mode after resolving it.
- Service Inspection Mode is described in the following table.
Mode Related parts Symptoms Note
t1
Inlet Valve
Flow Meter
Low Level Sensor
4E
9E
If you press the Delay Start key, water is drained for 45 seconds and then the water supply starts.
If the pulse count is more than 660, change the mode.
Make sure to change the mode when the pulse count is more than 660 in t1 mode.
t2 Circulation Motor A nozzle does not inject
water.
1. Press the Delay Start key to start or stop the Circulation Motor.
2. If a low water level is detected, water is supplied again and the operation continues.
t3
Circulation Motor
Heater
Thermistor
HE
1. Press the Delay Start key to start or stop the heater and the circulation Motor.
2. If a low water level is sensed, water is supplied again and the operation continues.
3. The current temperature is shown on the display.
4. If the water temperature is more than 70?C, the Heater does not operate.
t4 Fan Motor The Fan Motor does not
operate. Press the Delay Start key to start or stop the Fan Motor.
t5 Drain Pump
Low Level Sensor 5E 1. Press the Delay Start key to start the 2 parts.
2. When draining is finished, "t5" is blinking on the Display LED.
t6 Low Level Sensor
When the Micro Switch
is turned on/off, there is
no change on the display
or a symbol other than
On/OFF is displayed.
1. MICRO SWITCH On
? The sensing state is displayed as 'On' on the 88 segment display.
2. MICRO SWITCH Off
? The sensing state is displayed as 'OFF' on the 88 segment display.
t7 Thermistor There is no change in the
water temperature. The current temperature is displayed.
t8
Half Load Position of
Distributor Motor
Micro Switch
(DMR77 Model)
PE
1. If you press the Delay Start key, the parts operate just once.
2. There is no stop function.
3. While the Distributor Motor is operating, its sensing state is displayed as On/OFF on the 88 segment display.
4. When the Distributor Motor stops, the sensing state (On/OFF) of the Micro Switch is displayed.
Caution
If it has the power problem, you must check the FUSE first.
This dishwasher has the FUSE upon the Base. Refer to the 4-10 page.
Try these steps to solve your error there is no CE code listed in the manual
Dec 12, 2010 | Samsung DMR78AHS Builtin Dishwasher
I am getting a CE error, what does that mean? Bill
4. Troubleshooting
4-2
- You can change the mode by pressing the Normal key. Each time the Normal key is pressed, the mode changes in the order of t1 → t2 → t3 → t4 → t5 → t6 → t7 → t8.
t1
Inlet Valve
Flow Meter
Low Level Sensor
4E
9E
water.
t3
Circulation Motor
Heater
Thermistor
HE
4. If the water temperature is more than 70ºC, the Heater does not operate.
t5 Drain Pump
t6 Low Level Sensor
1. MICRO SWITCH On
→ The sensing state is displayed as 'On' on the 88 segment display.
2. MICRO SWITCH Off
→ The sensing state is displayed as 'OFF' on the 88 segment display.
t8
Distributor Motor
Micro Switch
(DMR77 Model)
PE
Caution
This dishwasher has the FUSE upon the Base. Refer to the 4-10 page.TRY THESE STEPS AND SEE WHAT HAPPENS THERE IS NO CE FAULT CODE LISTED IN THE MANUAL
What is code f 9
Try to clear it doing the following:
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and select HOLD TO START. If the problem
remains, call for service.
F errors usually indicate an electrial prible with the exception of:
FH water supply issue.
F2 drainage problem
Jul 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Under water for about 31/2hours vtx1300
If it was mine, I wouldn't attempt to start it until after a complete tear-down of (at least) the engine. Fluids need to be flushed and replenished with fresh. Three hours is long enough to soak about everything.
May 03, 2010 | 2003 Honda VTX 1300 Retro
Changing from pulse to tone dial
For the GE electric 2.4 GHZ phone where there is no switch, you have to press the program button and hold until it beeps (talk button will start flashing), then press the tone (star) button and program again. It will beep for confirmation
Dec 12, 2008 | Lands Phones
Water dispenser starts running when freezer door closed
if you wich to disable the despenser for water in the door just unplug the electrial connector on the water valve it has 2 selenoids on it one is for water in the door it has the largest plastic line under the selenoid
just unplug the connector to that selenoid
you will still have ice and it will despense through the door
Apr 20, 2008 | KitchenAid Superba 21.6 cu. ft. Top...
Karcher 1750 Psi Elec Pressure Washer Logo
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
