Question about Amana ARS266ZBS Side by Side Refrigerator
For an Amana side-by-side.....what is typical freezer temperature ?
  • 4,793 Answers
Factory set to -18C but some are adjustable LOWER (if required) for hot envinronments.
Posted on Dec 29, 2010
How to test Damper control in Amana DRS2660bw MFG No PDRS2660bwo S/N 10650033CT
the control damper does not control the freezer temperature call a repair man as it possibly needs freon added
Jan 22, 2017 | Amana Refrigerators
Temperature control in fridge is turned all the way down but still too cold-25*, freezer=10*. What can i do? Amana SZD27ME side by side
Turning down the dial is not recommended as it does not turn the temperature down. Please return it the factory setting. If your temperature is too cold in the fridge, it may be the timer or thermostat. If it its in the freezer, it's the thermostat. If it both, you have a bigger problem, such as the compressor may be malfunctioning.
Jan 13, 2015 | Amana Refrigerators
I have an amana refrigerator w side by side with freezer at the bottom.what is the best temperatur settinfg is most economical for this type refrigerator?
if you have a fridge/freezer thermometer great.leave inside each one for at least 12 hours to get average temperatures if in use. Answer .. the optimum temp for the freezer is -18/20c.0f, for the freezer and +2/5c.34/36f for the fridge.
Mar 10, 2010 | Amana ARS266ZBS Side by Side Refrigerator
Ice maker -- not all cubes freezing, running water into rear portion of cube storage tray.
Purchase an inexpensive temperature monitor. Check temp in freezer. Ideally, you should have from 0 degrees to 10 degrees in the freezer. The icemaker calls for water at a certain temperature. There may be an issue with the icemaker, which has a "u-shaped" heater underneath the icemaker to loosen the ice prior to dropping ice in the ice bucket. Or, there could be an issue with your freezer control assembly (typically located in the fresh food compartment). Contact an appliance service company.
Feb 10, 2010 | Amana Refrigerators
17 yr old Amana frig freezer isnt cold enough lite display nowork
No it's not worth it! Sounds like its low on freon and they don't make R12 anymore, junk it
Jul 06, 2009 | Amana ASD2625KE Side by Side Refrigerator
Freezer is not making ice and the temp seems to be dropping.
You may have a defrost issue,Please check and see if it has an accumulation of ice build up in the back and post back.
Jan 10, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana XRSS287BB side by side fridge freezer (3 years old)
you may try hard restart by shuting the fridge off and unplugging it from the wall . plug in back in and after 5 min turn it back on . close both doors and wait one hour . check the temp. if the unit still will not respond calll the local woranty amana repairman only. hope this helps you
Jul 01, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Help, no water but have ice out of door on amana side by side.
The freezer temperature dial is set too cold and it is causing the water to freeze in the tube right where it enters the freezer section.If you turn the temperature selector one or two numbers warmer for the freezer it will help.
You will also have to turn the box off and let the freezer thaw real good so that the line will thaw. Once this has been done, it should work fine.
Jun 08, 2008 | Amana SXD524VW Side by Side Refrigerator
Amana Bottom Freezer control knob
http://amana.com
go here and scroll to the bottom of the page and click on "sitemap"
and you will find help information.
Mar 17, 2008 | Amana ARB8057CSL Bottom Freezer...
Amana ARS266ZBS Side by Side Refrigerator Logo
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
