Question about Braun 8585 Electric Shaver
No close shaves
I replaced the cutting block and foil , and it doesn't shave as close as it us to. It takes longer to shave.
  • longbeard Sep 03, 2008
    DOES NOT HARDLY SHAVE AT ALL. I REPLACED THE CUTTING BLOCK AND FOIL.
  • nyudad Sep 28, 2008
    I have the same problem. Shaved better before I replaced the parts!
I called Braun which is part of the Gillette company. Their customer service person sent me out an entire new cutter. Seems the replacement ones are not the correct ones to use. No cost and excellent customer service!
Posted on Feb 07, 2009
I had the same problem. Mine is 4 years old. Turned out it was the drive/motor assy. My local repair shop replaced the assy and with parts, labor and tax came to $46 and they had it done within a couple of days. Not too shabby. I tried to find a repair manual to see if I could do the work myself and couldn't find one. But the price for the repair shop to do it wasn't all that bad.
I've replace the cutting surfaces and the thing just won't cut.
Posted on Sep 02, 2008
I have braun shaver 190s1 fully charged but the blades are not rotating for me to shave
One or more of the shaving heads is stuck on the blade foil. The latter is very delicate and wears. If there is a break in the foil often a metal shard intrudes into the path of the moving blades and it gets stuck. Remove the foil and turn on shaver - if it runs it is the foil that has to be replaced.
Nov 22, 2013 | Braun Health & Beauty
Trimmer of my Panasonic EX3833S is not working
panasonic es3833 replacement foil and blades
panasonic WES9979P combo set for electric shaver panasonic es3833 replacement heads.
panasonic WES9941P outer foil for electric shaver panasonic es3833 replacement parts.
panasonic es3833 replacement blades
panasonic WES9942P replacement blade for electric shaver part panasonic es3833 replacement parts.
Aug 25, 2013 | Panasonic ES3833 Electric Shaver
What is a foil electrical shaver?
Foil electric shaver use an oscillating motion in order to cut hairs through a foil. The blade inside positioned in line and may contain up to four rows of blades. The foil electric shavers are ideal for men who are just starting to shave or men with slow beard growth.
Feb 06, 2013 | Health & Beauty
The screen on my braun shaver has holes and needs replacement can i get new ones for it? its the one that says caution for use only with braun series 549 class 2 power unit www.braun.com it has a trimmer...
Braun 8985 replacement foil and blades is braun series 5 combi 51S foil and cutter replacement pack.
But costomer reviews in amazon.com who take braun series 3 combi 30B foil and cutter replacement pack is fits to Braun 8985 perfectly, very smooth and close shave. Shaves much better than the Braun 51S screens foil.
You consideration
http://www.amazon.com/gp/community-content-search/results/?ie=UTF8&search-alias=community-reviews&tag=best-electric-razors-20&Go.x=0&linkCode=ur2&query=braun%208985&camp=1789&Go.y=0&creative=9325&idx.asin=B001VH6F9G
Sep 16, 2011 | Braun 360° Complete 8985 Electric Shaver
I dropped my 8985 braun and it will no longer shave with the foil head on. It does work if you remove the foil. Did I loose a part?
You probably dented the foil head enough to stop the vibratory action of the blades, thus the working when the foil is removed. Braun has a replacement foil and blade kit sold at Walmart.
Dec 04, 2010 | Braun 8585 Electric Shaver
Making a funny noise and not shaving well
8585 shaver gave higher tone and stopped cutting especially after a few days growth, even with new cutter and foil. Cutter wasn't pressing against the foil properly due to a bit of wear on the spring clip holding the cutter pin. Fixed with about 1cm of cigarette paper moistened and rolled into a 1-2mm ball. Stuffed that into cutter pin hole and rammed home with the cutter pin. Take the foil off and wiggle the cutter - if its feels loose, this might help, though the battery might just be getting old.
Jul 10, 2010 | Braun 8585 Electric Shaver
Not shaving close enough.
This problem is usually cause by a worn out shaving head (foil and cutters). Braun suggests that you change these every 12-18 months for best performance. You will find replacements at shaveroutlet.com for your model 4501 Braun shaver. See link below.
http://shaveroutlet.com/foil-cutter-fit-braun-4000-series-flex-control-twin-control-p-146.html
It is also possible that your shaver is running too slowly due to an old battery if you've never replaced it. If you require a new battery, it can also be ordered from shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
To change the battery you will need to be able to do a little soldering. Open the shaver by removing the two round screw covers on the bottom of the shaver and then the screws underneath. You will also need to remove the foil and cutters and then the swivel frame which is attached by two tiny screws. Once removed, you will be able to open the shaver from the bottom and seperate the front and back. Remove the circuit board to easily get to the battery.
Note: The tabs on this type battery will work for most applications however they may be slightly different than some original equipment. For these instances, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather that removing them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can them solder the tabs from the new batteries to the old existing tabs
Feb 19, 2010 | Braun 4501 Electric Shaver
Shaver started making a much louder buzzing sound, no longer shaves as well and now hurts a bit to use. Can this be fixed?
Hello Robert, It sounds like the foil screen might have been damaged and is causing poor shaving performance. Typically, a screen will get small holes or tears in it after providing good service for some years, however, these very thin screen foils, can get damaged other ways too.
The best way to restore the best shaving performance is to replace both the foil screen AND the cutter head block (cutter head) as it could be possible that the cutter blades have become damaged or nicked and have caused the foil screen to become damaged, as a result.
I would contact www.electricshaver.com and see if you can purchase a new set of the cutter block head and the screen foil for your particular Braun shaver model. As the Braun 360 is a tradename used on a couple of different model numbers, you really need the four (4) digit model number in order to locate the correct replacement parts.
Here's a link to their page with the various Braun replacement cutter blocks and foil screens. You might find your model number amoung them, otherwise, you can also give them a call at 1-888-476-1785 and ask them to assist you with selecting the proper replacement parts.
http://www.electricshaverstore.com/get_list_125.htm
As you are no doubt aware, replacing the cutter head and foil screen is the best and simplest way to restore an electric shaver to a like new shaving condition and much less expensive than replacing the entire shaver.
I hope you find this Very Helpful and best regards!
Nov 11, 2009 | Braun 360° Complete Electric Shaver
Braun 8585 series
I found that the hole that the blade slots into had become worn and the blade was wobbling about too much under the foil. To solve it I wrap a small piece of masking tape around the metal shaft that slots into the hole and then push the blade back firmly into the slot. This seems to result in the blade pushing more firmly against the underside of the foil and giving a shave like new again.
Oct 10, 2008 | Braun 8585 Electric Shaver
Remington es1000
The Remington ES-1000 was probably the best slot-head shaver ever made by Remington. I cannot believe that the market demand was so low as to prompt a cancellation of production. I believe that the production run was limited to about 4 years or so. I have 8 of these shavers and keep a couple old Remington slot heads around as well. The ES-1000 was not perfect. The batteries were way too small and stressed so battery life was poor.You could not buy individual blades as you could with past Remington slot-head units.Also, the edge of the head was too exposed and sharp and when used for body shaving would tend to cut the skin.Slot-head shavers are superior for body shaving and for skin that is suseptible to shaving bumps.They are also great for young men that are prone to ingrown hairs.My guess is that the Norelco 3 head has taken it's place. Those shavers actually use 3 small slot heads. Rumor has it that shavers.com is trying to have a new slot head manufactured in Asia.
Dec 05, 2007 | Remington ES-1000 Electric Shaver
Braun 8585 Electric Shaver Logo
339 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
