Question about Zanussi Dishwashers
Its not filling with water; taking water in. - Zanussi Dishwashers
  • Zanussi Master
  • 3,247 Answers
If the tap under sink is open and no water is getting into the dishwasher then most likely the water inlet solenoid has packe up. You need to provide the full model number of the dishwasher if you want to know part number etc.
Posted on Dec 29, 2010
Is there a way to program more water in the filling program other than stopping the washer and adding water
Some machines work on the water "back pressure" and if the pressure is too high then the water will cut off prematurely in a similar way to fuelling up your car in that if you pull the trigger all the way and allow it to fill faster then the trigger cuts out. Take the nozzle out a bit and fill slowly and you get more fuel. With this in mind, throttle back the water pressure at the feed valve and see if that helps. It will take longer to fill and rinse, but should allow more water in the fill cycle.
Also, the more modern, so called "eco" or "green" machines use less water by design.
Oct 05, 2015 | Washing Machines
The toilet tank takes a long time to fill up
if the water keeps flowing then try replacing the flapper if it still flows then the fill tube gasket or tank to bowl gasket need to be replaced.
Mar 23, 2013 | Home
Why is it taking so much long to tank to fill?
Disassemble the valve assembly. It probably has mineral deposits in it. If this doesn't do it, replace the whole assembly. Costs 8-10 dollars
Jan 11, 2013 | Jacuzzi Bath Perfecta EZ33 959 White round...
Takes forever to fill tub
yes now days all the faucets are regulated to save water so they dont fill a large tub very fast. if you take off the diffuser (the screen wher the water comes out) depending on the brand you might find a plastic disc that restricts the flow. Take that out and see if that helps. Try just taking off the screen assembly and filling the tub first. It it does not fill faster with that off then you have another problem,and taking out the restrictor plate wont help.
Nov 26, 2012 | Coral Sea Spas Ariel Platinum DA333F8...
Wont fill with water
there is a fill valve at the back of the machine. Turn of the power. Take off the lid. Where the fill pipe comes in is a valve. Check to see if its giving a current reading or if its possibly blocked. If thats fine check back up your water source. If you take off the fill pipe shut off the water, and never work on a machine with the plug in.
May 24, 2010 | Frigidaire ATF6000ES Front Load Washer
Will not fill up with water before starting, it takes about 3-4 times brfore unit will run with full amount of water. loads take forever.
dish washers have a fill valve. the water supply line most likly has a net like filter that is stoped up with trash. Or fill valve is bad.
same thing happens to washing mashines. when they start filling up very slow you will TURN OFF water supply and diconect hose, look inside and there is the problem.
May 09, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Water takes 45 minutes to fill, can't figure out what is wrong, water just sprays out. i have a older model at my other house and it fills in five minutes. it shouldn't take that long for the tub to fill.
try switching hoses check to see if water flows freely through the hoses if clear then the water valve has crud in the valve and you have to replace the valve or clean out
Mar 08, 2010 | Maytag Atlantis MAV6000 Top Load Washer
When toilet water tank is filling water is
Take the top off the water control valve(shut water off first) You will see a diaphram. Replace it.
Sep 05, 2009 | Home
Slow cold water fill in washing machine
Take out the screen on the cold water side of the fill valve where the hoses attach, its probably clogged.
Mar 17, 2009 | GE Washing Machines
My bosch dishwasher does not fill with water (although it drains)
most bosch have the inlet valve at the end of the fill pipe and it has an anti-flood device.
try turning off the water, take off the fill pipe then reconnect it and see if this works.
taking off the fill pipe resets the anti-flood device
Nov 26, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwashers Logo
69 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
