Question about Breville BBL600 5Speed Blender
Hi my name is inti.I had problem with my blender BBL 600/A.Machine is on,but blade not spin.
How do I remove old blade?
Hi Paul,
There is a collar on the base of the jar that screws onto the jar. You will need to unscrew the collar and fit a replacement blade. make sure the seal is replaced with the blade and the collar is screwed back securely.
See this link for the parts of the blender.
CUISINART CANADA SmartPower Premier 600 Watt Blender CBT 500C
Also see the product description for the blade.
https://www.youtube.com/watch?v=rdBxUAsT_TQ
Mar 04, 2015 | Cuisinart Replacement Cbt-Bg-1 Blender...
Smoothie maker 600
Check to see if the jar has any cracks or if the blade assembly or collar have any cracks.
Is it possibly leaking from the tap valve?
If the blades or tap lever are cracked I would recommend replacing them, however if the jar is cracked i would just buy a new blender. These are great for smoothies but they are all discontinued and parts wont be available for much longer.
May 05, 2013 | Back to Basics 600 Smoothie Plus Work Top...
Breville bbl 300 blender
remove it and then take it to the Canadian Bearings ( if you live in Canada)
Mar 19, 2013 | Blenders
My wolfgang puck 1.6 hp professional blender will not spin the blades if there is anything in the blender container.
This is not really the solution it is just a better description of the problem that I am also having. This is a great blender however the part where the cup blades conect to the motor is made of plastic.
So what has happened here is that the motor is fine, the cup is fine only the plastic part that makes the motor turn the blades has worn down therefore rendering the blender useless. I would like to know where I could get this small part to change on my blender!!!
Jul 30, 2012 | Wolfgang Puck 1.6 Hp Professional Blender...
Where can I find a blade & gasket for my Juicelady JL 600 Blender?
i have a blade and gasket that i am willing to sell. my base is broken so I have no need for it now.
email me at mimitascoe@gmail.com
May 28, 2011 | Juicelady JL600 Professional Work Top...
Need new base for dicer. The part where the grid slides in
the smoothie pro 600 dosen't spin any more.
It turn on but no spinning on the blades.
Jun 17, 2010 | Back to Basics 600 Smoothie Plus Work Top...
The lights are on but the blades inside the blender are not mving.
the blender only hums and the blades do not move. I cannot get the blade to rotate even while empty. Need new assembly???
Jan 29, 2010 | Cuisinart CB-600 Blender
Cuisinart fpb-5ch blender not working
Remove blender attachment completely, turn machine on and see if it will spin with all attachments removed - if it spins, then replace the blade assembly - parts available from Cuisinart. If it doesn't spin, send to Cuisinart for repair (call first).
Dec 11, 2008 | Blenders
Breville BBL600 5Speed Blender Logo
114 people viewed this question
Top Breville Blenders Experts
Mike
Joseph Hoffmann
Are you a Breville Blender Expert? Answer questions, earn points and help others
