Question about Cell Phones
G five key pad not working - Cell Phones
    Sergeant:
  • 242 Answers
Change new keypad
Posted on Dec 29, 2010
Need to change code on door key pad
  • Enter the five-digit code programmed into the keypad from the factory. Find the key code in the card stored in the glove box of your Mariner.
  • Press the "1-2" button on the keypad immediately after inputting the factory code.
  • Enter the five-digit key code you wish to store for your keyless entry system within five seconds of pressing the "1-2" button.
  • Read more : http://www.ehow.com/how_7442543_program-entry-pad-mercury-mariner.html
    Jul 05, 2015 | 2008 Mercury Mariner
    G five t33 mobile key pad not working
    sir please service your cellphone in the g five service center.they will change the new keypad to solve the problem...........
    Jan 11, 2011 | Cell Phones
    How do I change the code for key less entery on the key pad on door
    Programming a personal entry code The factory set code cannot be reprogrammed but you can create your own 5 digit personal entry code. When pressing the controls on the keypad, press the middle of the controls to ensure a good activation.
    Up to three personal entry codes may be programmed to the vehicle. To create your own personal entry code:
    • 1. Enter the factory set code.
    • 2. Within five seconds press the 1-2 on the keypad.
    • 3. Enter your personal 5-digit code. Each number must be entered within five seconds of each other.
    • 4. Press 1-2, 3-4 or 5-6 to indicate which of the three personal entry code positions you wish to use.
    • 5. The doors will again lock then unlock to confirm that your personal key code has been programmed to the module.
    Tips:
    • Do not set a code that uses five of the same number.
    • Do not use five numbers in sequential order.
    • The factory set code will work even if you have set your own personal code.
    • If you program a code to a position that already contains a set code, the previously-set code will be erased.
    Erasing personal code
    • 1. Enter the factory set 5 digit code.
    • 2. Within five seconds, press the 1-2 on the keypad and release.
    • 3. Press and hold the 1- 2 for two seconds. This must be done within five seconds of completing Step 2.
    All personal codes are now erased and only the factory set 5 digit code will work.
    Good luck (remember commend and rated this).
    May 03, 2010 | 1996 Ford Explorer
    My numbers 1234789 in letter pad don`t work.But if i pres 3,4,5 at one time will open Help in Google Chrome
    The numbers five and six don't seem to work on my letter pad. All other number keys work fine. I have a Dell Inspiron notebook. Does anyone know how I can fix this? HELP!!!!
    Dec 04, 2009 | Computers & Internet
    My touch pad will not work thus rendering the oven useless. It will not respond to touch. Is there anything I can do sans a new processor pad?
    HI. Unfortunately, the touch/key pad is not repairable. Once the circuitry is damaged, the entire board must be replaced. Most units will have an Incorporated control board, that will have the touch/key pad integrated into the main board assembly. If this is the case, simply replace the entire oven control board. If the touch pad is separate from the main control board, replace the touch pad board.
    NOTE_ This may be a simple control fault. In this case, simply unplug the unit, or shut down the appropriate circuit breaker for five minutes. This will reset the control. If the issue's persist, replace the failed component.
    Dec 03, 2009 | Jenn-Air JGR8775QD Gas Kitchen Range
    Our GE countertop microwave key pad does not work. The start and clear button does not work. owners mamual jes1651 . unit is 2 years old.
    HI. Kindly, unplug the unit for five minutes. this will drain all power, and reset the main board. Once the five minutes have passed, simply plug the unit back into the power outlet. If the error continues, the touch pad should be replaced asap.
    Oct 19, 2009 | GE Microwave Ovens
    Microwave Oven
    I report from owner manual.
    F3 means : Short circuit on key panel (your touch pad).
    You get F3 error if a shorted key panel is detected for more than 60 seconds.
    Solution: . Replace key panel (touch pad).
    Try first unpluggign power cord for five minutes.
    If you think that the problem may had been caused by water inside the keypad you can try using an hairdryer on the keypad, taking care not to melt the keypad plastic.
    If that does not work, then replace the keypad.
    You can buy replacements here. or Order GE Microwave Ovens Parts Here
    Mar 08, 2009 | GE JVM1630 Microwave Oven
    Ice and water won't come out dispenser
    here is link to your owners manual subzero.com
    and here are instructions for using the lock feature..
    LOCK For Models 685 and 695, the lock feature is used to prevent unintended ice and water dispensing. When the dispenser is locked, all key pads on the glasswell are deactivated to allow cleaning or to prevent small children from using the dispenser. To activate the lock feature, hold down the LIGHT key pad on the glasswell until the key pad lights flash once and the red LOCK icon is illuminated (approximately five seconds). The lights will remain in the state they were in before the lock feature was activated. To deactivate the lock feature, hold down the LIGHT key pad until the key pad lights flash once and the red LOCK icon is no longer illuminated (approximately five seconds). The lights will remain in the state they were in before the lock feature was deactivated.
    Thanks Peyton
    Mar 02, 2009 | Sub-Zero 695/S Side by Side Refrigerator
    Nothin works on my key pad
    Here are lock / unlock schemes for three recent Sanyo models:
    - Press and hold Stop/Cancel for 3 seconds
    - Press and hold Stop/Reset for 3 seconds or so
    - Press Stop/Clear five times
    Hopefully one of those will work.
    If none of these work for you, contact Sanyo Service Customer Service.
    We're happy to help and we appreciate your thoughtful rating of our answer.
    Jul 10, 2008 | Sanyo EM-V5405SW 1200 Watts Microwave Oven
    Cell Phones Logo
    42 people viewed this question
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
