Hello, I have recently bought the techwood lvd1963d tv/dvd for my bedroom, however the standby light is big and bright and lights the whole room. It cant be covered by anything as it is also the sensor for the remote. Can the light be switched off somehow when on standby? I cant find an off button on the tv for the tv either, only a standby button, is unplugging the tv every night the only option?
SOURCE: STANDBY LIGHT IS FLASHING
The standby light blinks 5 times
Posted on Mar 30, 2008
SOURCE: LED Dimmer on Emerson CKD 9901
On Those Clocks No You Can't
I Normally put a shirt over the led screen light that way i can sleep hope ive been helpful to you
Posted on Jul 18, 2008
SOURCE: TV keeps turning itself on and off, onto standby
I managed to find a local repair man who fixed the problem. He put in a new transformer.
Posted on Dec 05, 2008
SOURCE: Sky plus remote code for Acoustic Solutions TV
The code is 065 pal.
Posted on Dec 09, 2008
SOURCE: I have an Emerson TV 32
i turned on my tv and it blinks green continuesly. it wont turn off to red light. i unpluged it for 30 min. repluged it and green light comes on and wont stop blinking
Posted on Jan 22, 2009
When I turn off my Luxor TV in the bedroom the standby light flashes blue then orange. The lights are very bright & I have to get out of bed to switch off at the wall socket. What is the problem and...
The alternating blue orange light means you have put a reminder on for a program that hasnt started before you switched off, you need to remove the reminder before you turn the tv off then the light will be steady blue
Sep 14, 2011 | Audio Players & Recorders
The power light (bright blue) on my Olevia 26" LCD burns brightly in my bedroom ALL DAY and ALL NIGHT. Is there anyway to dim it?
Had the same problem and took the easy way out: I cut a small piece of electrical tape and covered the LED. There is no way to dim it.
Dec 23, 2009 | Olevia LT27HVX 27 in. LCD Television
My satellite remote control only work at close distance I have canged the batteries I tried it with the other box from bedroom in bedroom they work fine in the sitting room both dont work
Hello Aykuturer,
There are two things that you can try to resolve this problem.
1) most common interferrance for the sky remotes are WII sensors to close to box. or the TV back light is interfearing with it. If this is the case then turn off the WII (if you have one) and try that. If it is the TV back light then you can turn this down or off.
2) If you are still not getting any joy from these then you could always go to EBAY and purchase a Magic Eye / Remote Eye. They are resonably cheap from there.
Once you have got your Magic eye. Connect it into RF OUT 2 at the back of your sky box.
Then with the remote press SERVICES, 4, 0,1, Select then 4 make sure that you turn then power on and then save.
This will sort out any IR problems you are experiencing.
Hope this helps you out, If this does then please leave a thumbs up.
Cheers Little Dish Fitter.
Oct 23, 2009 | Samsung DVD-V4600 DVD Player/VCR
Comcast remote does not work after dark, works just find in day
I have had the same problem I have two bell receivers one in the bedroom and one in the living room, in low light the remote in the living room would work much like yours, but if I took the same remote into the bedroom it worked fine in low light, the second remote responded exactly the same, the problem in my situation was the TV had a light sensor that adjusts the picture depending on the light in the room, with this option turned off. The remote works just fine in low light situation.
Oct 20, 2009 | DISH Network IR Remote Control
Flashing lights on alba stb8
Its just the box updating its self mine dos it about 2 or 3 in the morning red green makes the whole room light up nowt to worry about unless its in the bedroom then a real pain ken
Jul 16, 2009 | Televison & Video
Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Mar 25, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Picture settings messed up!
Loose cable or wrong setting. Channel, input type, etc. Also. make sure the audio isn't plugged into the video input [either end]
Dec 03, 2007 | Toshiba 27AF45 27" TV
Dish network box hookup question.
Are you sure that the antenna in isn't threaded? You may be looking at the wrong jack... All antenna inputs are threaded co-axial "F" connectors. If you ARE sure, could you post a pic of the back panel?
Sep 12, 2007 | iLO 2600 Television
Televison & Video Logo
102 people viewed this question
Top Televison & Video Experts
