Question about Sharp R-244 800 Watts Microwave Oven
I was cleaning inside the microwave and a rectangular part on the inside came off the right hand wall. I cleaned it further and tore it. Is this needed in the microwave, can I get a replacement?
    President:
  • 2,992 Answers
That piece is called the waveguide cover. It's a mica sheet that goes over the hole in the side of the oven where the microwaves enter the cooking cavity. While the oven can work without it, you should replace it. It's meant to keep food particles and dirt from getting into the area of the microwave antenna, where it can possibly lead to damage.
I gather from researching the part that yours is a UK model oven. Here is a source for the replacement waveguide cover. If you're in some other part of the world, at least you'll know what you're looking for when you search for a more convenient source. You may be able to find a replacement locally, as the waveguide cover is a commonly-replaced item. Check with appliance parts houses or service shops in your area to see if one might be available.
Posted on Dec 29, 2010
Mx 100 subwoofer repair
open the microwave door, look for a silver rectangular plate inside,try cleaning the plate with a damp cloth.
Oct 18, 2013 | Microwave Ovens
Just bought one of your microwaves - model HB-P100N30AL-S3 - and after using it a couple times, I noticed that there's a piece of what looks like cardboard inside the oven on the right-hand...
That's the waveguide cover, which protects the waveguide and magnetron from moisture, grease, and food particles, which can carbonize, arc, and damage these parts.
It should be kept installed and kept clean.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 27, 2017 | Hamilton Beach Beach 87108 Microwave Oven
Replacement of the Cover Inlet plate inside the microwave, this is part # 8184604. I have the part, I just need to know what to do to replace it. Thanks,
Hi
To locate the inlet cover, look towards the interior side of the microwave next to the microwave display. The inlet is typically located near the back of the microwave, in the middle of the wall.
Unplug your microwave from the electrical outlet and remove any food or containers.
Wipe the inlet cover, typically located on the right side of the microwave in the middle of the wall, with a damp cloth. The cover must be kept clean or it will not protect the microwave.
Dry the inlet cover with a soft towel.
Leave the microwave door open for several hours to air out the inlet cover.
Examine the inlet cover for wear and tear. If the cover has too much damage in the form of scratches or holes, it may need replacement.
Remove the inlet cover, if desired. Insert a putty knife under the plastic nail that holds the inlet cover in place. Pry out the nails and set them aside. Pull out the micro plate in front of the inlet and set it aside. Remove the inlet plate.
Install a new inlet plate. Slide the new inlet cover into its place. Replace the nails back into the side of the microwave by aligning them with the holes of the side.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 20, 2011 | KitchenAid KHMS145KSS Microwave Oven
Put a hamburger in to heat, on a paper plate. The interior began to spark. the plate on the Right hand side appears to have a something black and charred (as if a piece of meat or grease has adhered to it)...
Usually the sparks are from exposed metal. Clean the oven, and the table and anything else you can inside. Then just try nuking a cup of water. That gives it something to work with and it won;t make any sparks itself. Then just see if the sparks are gone. If the paint has come off inside the cavity and exposed some metal you can get sparks but that usually means replacing the microwave. If its caused by an object or buildup then a good cleaning stops it.
Oct 10, 2010 | Whirlpool MT1110SKQ 1100 Watts Microwave...
Arcing while cooking.
Make sure the inside of the oven is clean and the waveguide cover on the right wall of the oven is especially clean and not damaged. Don't ever run the oven without food in it. If the waveguide cover is damaged it will arc no what but you can probably get a replacement for a few bucks. The magnetron may already be so damaged that it'll never work right again.
Oct 19, 2009 | Daewoo KOC-925T Microwave Oven
Panasonic nn-s558ba microwave won't power on
Lee,
Have Landlord replace unit after verifying that outlet has power.
In the future, follow manufacturer's cleaning instructions and DO NOT
run microwave without something in it (even a microwave safe cup of water).
Larry Hanson EH&S Specialist
Apr 04, 2009 | Panasonic NN-S558BA/WA Microwave Oven
Microwave ovens
The Magnetron has failed, causing the waveguide to become damaged. If the waveguide is damaged/burned the microwave can not be repaired and should be replaced.
Dec 25, 2008 | GE Advantium 120 Convection/Microwave Oven
Burning smell from Microwave
If you clean any appliances always plug out the unit power supply do spray any liquid in the unit that can enter inside the control, instead just wipe it with rug not spray. In this situation you have to call for a qualified technician. Maybe there are some wires that burned or rust in the control that cause the short circuit inside the unit..
Dec 27, 2007 | Whirlpool MH7135XE Microwave Oven
Microwave ovens
The cover is probably the magenetron. That is where the microwaves come from. If the bread was moist, it might have left condensate in the unit which is causing the sparking. Unplug the unit, leave the door open over night. If you can remove that cover, do so. Be sure to carefully replace it before using the unit. Never turn on a microwave with nothing in it.
Dec 16, 2007 | Sharp R-1480 Microwave Oven
Microwave ovens
Can't tell you much about your little rectangle, but sparks can result from left over food particles that got carbonized, and a good cleaning might get rid of it, unless you like looking at the sparks(I heard you shouldn't stare at a microwave while working though, washing machines are safer). make sure you unplug it while cleaning or doing anything else, those micros are dangerous as hell. Take care
Mar 15, 2006 | Sharp R-220BW Microwave Oven
Sharp R-244 800 Watts Microwave Oven Logo
207 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
