Question about Acer Aspire™ T180 PC Desktop
Hi can you help me please i am trying to find out where do i connect all to wires to the board
    Genius:
  • 1,354 Answers
Hi
go to following link you will find all the details for your desktop
http://www.acer.co.in/acer/service.do?LanguageISOCtxParam=hi&miu10einu24.current.attN2B2F2EEF=3350&sp=page15e&ctx2.c2att1=158&miu10ekcond13.attN2B2F2EEF=3350&CountryISOCtxParam=IN&ctx1.att21k=1&CRC=832315095
Posted on Dec 29, 2010
DVD input failure
use a hdmi input and try the same
Apr 05, 2008 | Proscan PS27115 27" TV
F 12
Hi there:
F-12 means Communication Error
First i suggest to check some bad connections, wiring faults or a bad board.
Try unplugging the dryer and checking connections, wiring and the board for burnt or bad connections.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Dec 15, 2011 | Hotpoint Ariston ASL65VXS Electric Dryer
Goodman gmp0753 wont turn on condenser. The thermostat yellow wire is not connected to the unit. Does this play a part in my problem and where does this wire connect inside the furnace.
Hi, yes this is your cooling wire. Connect it to the Y terminal on the circuit board if this unit has one, or to the yellow thermostat wire coming from the stat. You will either have a board with these marks on them, R for hot, Y for yellow and cooling, W for heat which is heat, and G for fan which is green. If no board, look for all of these wires as they have to be there and they may be connected by wire nuts. Just connect the yellow to yellow and the outdoor unit will run. Very easy for you. Please be kind when rating me for my help.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Jul 02, 2010 | Heating & Cooling
Does not make ice consistently starts and stops wiggled wires to circuit board and works for short time u line clr 2060
Hi, If you can move the wires at the board and it works for awhile, look the wires over good, but you will more then likely need to replace this board. I wouldn't recommending soldering it as you are taking a chance on soldering other parts of the circuit together causing more problems. I have soldered boards, blower boards on a/c & heating equipment, as I have the know how, but you should look into the price of a new board. You will need to go to a appliance parts store to get it or order one. I wish you the best of luck on this and was hoping to save you money. If you want to try and solder, you really don't have anything to loose, as if it does not work, you will need a new board anyway, so give it a try. If I have been of help to you, please rate me and I ask that you be kind when doing so. This would be very kind of you for doing this. Please keep me posted on this.
Sincerely,
Shastalaker7
Jan 23, 2010 | U-Line Refrigerator Ice Maker
Hi Guys I have disconnect my front Panel USB connections in my System iam using intel 945 GCNL mother board. Please help me with screen shot , its very difficult to connect at back Please help me.
Open your manual to page 40. Your better off download the manual. You'll need Adobe Reader to view the manual. Using the program Adobe you can zoom in which will help greatly. You'll be able to see exactly where each wire goes. Here is the link for your manual;
http://downloadmirror.intel.com/15115/eng/D945GCNL_ProductGuide02_English.pdf
Figure 20. Internal Headers. Intel Desktop Board D945GCNL Product Guide. If your USB wires should be marked. To help you connect the correct wire to the USB MB pins use the guide provided below;
http://www.directron.com/installusb.html
There are a few different types for USB connections. You'll find one just for your MB on the site.
Happy holidays!
Mike
Dec 15, 2009 | Intel Motherboard
How do you wire a transfomer and relay together on a central air.(bryant)I took the wires of and now witch wire goes were.I going to change the two.HELP ME
This may be somewhat difficult depending on the year make and model. I will try to help without this knowledge.
There are 2 sides to the transformer. Read the label to see which is which. One side is labeled 24 volt and the other side is labeled 115 volt.
The 115v side will probably only have 2 wires. A white wire and a black wire. The white one will connect to the common or neutral system. If there is a circuit board it will plug on to the 120v Common terminal (probably marked L2). If the air handler does not have a circuit board, the white wire will connect to the other white common wires by a wire nut.
The Black (hot) 120v wire will connect to the 120v L1 terminal on the circuit board. If there is not a circuit board, read the schematics to find out where to wire nut the black 120v wire to. It will obviously be connected to a 120v incoming hot center after the blower door switch.
The 24volt wires will connect in a similar fashion to the circuit board. T1 will connect to the 24v hot terminal on the board. The T2 will connect to the 24v common terminal. If there is not a circuit board you will need to read the schematics very carefully before proceeding. It may be a good idea to add a 2amp fuseable link on the 24v T1 wire just in the case we are wrong.
The 24v hot wire may be wired in multiple ways without a circuit board. One way is to be wired to the Limit side of the Fan/Limit switch (located on back wall of the burner compartment just above the gas valve. Another way is wired to the gas valve. Please read the schematics located on the blower door. I hope this helps at least a little. Let me know please. Thanks.
Aug 14, 2008 | Heating & Cooling
WD62 programmer wiring
hi robbie,
you can slowly try each plug to every slot in the board. they are not interchangeable. they have keys that would not fit to other slots.
i hope i was able to solve your problem..please rate me...tnx
drcool299
Jul 03, 2008 | Hotpoint Aquarius WD63 Front Load...
Connecting USB From Front Panel
you can connect it using manual 0f the mother board.
if you dont have the manual then download it from the product manufacturer site.
Jan 04, 2008 | PC Chips (M925G) Motherboard
Acer Aspire™ T180 PC Desktop Logo
12 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
