Question about AEG Dishwashers
Aeg sensorlogic 50700 first showed c2 message; we drained & cleaned filters 3 times; worked half cycle and now showing error message c3?
  • AEG Master
  • 3,247 Answers
Error message C3 is most likely indicating the flood switch is triggered. This means water is leaking from under the sump. The C2 error is linked to drain problems which you cleared.
Posted on Dec 29, 2010
Hi, i have an AEG Lavamat 1100. Although the machine runs through the spin cycle, and shows the wash cycle as being finished, when i open the door there is still water in the bottom of the machine and the...
Hi bwileman435,
It may not be draining well, because it is dirty, did you clean the Drain Pump filter?
Please follow my below Tip on how to do it:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
Kind Regards d")
* If this solution helped you, please rate it
Aug 05, 2011 | AEG Washing Machines
My Kenmore HE 3 washer keeps stopping mid cycle and beeping showing an F 02 message. We cleaned out the hose but it is still doing it. If I unplug it and do the spin/drain cycle again it will work...
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Aug 01, 2011 | Kenmore HE3T Washer
My Washing machine Brand : AEG and model : 84740 update and problem is when switched on its showing error message C3. And blinking 3 light as well one is 1400 light , and other 2 is washing program
Quote 'German made AEG washing machines (update) C3 indicates float switch fault' unquote.
Sorry- looks like a service call is required ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jun 28, 2011 | AEG Washing Machines
AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
Jun 10, 2009 | AEG Lavamat 88840 Front Load Washer
I have a c1 error on an AEG oko favorite 50700 What dies this error mean
I don't understand why replies talk about the C2 and C3 errors... The problem is C1! I have the C1 error. I start a programme, it does the draining cycle to check empty then starts filling. MI can hear water entering but it sounds slow at a low flow rate. If I leave it going, eventually the programme stops and the error is displayed: C1 Opening and closing the door allows the programme to continue. I get the error after the various stages of the programme, when it is filling for the next wash or rinse. So it's 4 or 5 times I think during the programme. Now, if I help the filling... When the appliance is filling, I open the door, and poor in a kettle or two of water, then the error does not happen (the fill is within the time expected by the appliance?) So I am thinking one of two things is wrong: 1) I have a flow rate problem BEFORE the water connection to the appliance. E.g. It is blocked somehow. 2) There is something which opens/closes the "tap" within the machine which is causing the flow rate to be low and it does not fill quickly due to that. No idea which of these two, but I did disconnect the hose of the supply and check that water flows quickly from it into a bucket, so I am thinking there is something inside the machine which "opens the tap" and it's not doing a good job of it. Anyone got a clue?
Dec 18, 2008 | AEG 24 in. Favorit 50730W Free-standing...
Please help
your machine is draining too slowly. When it initiates a drain cycle, the water level switch is sensing the water level is still too high after 60 seconds so the computer1.gif stops and generates this fault code.
Here are the things to check;
* Check the drain hose and make sure it is not plugged or inked.
* Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
* Check/Clean Drain Pump Filter of foreign objects
* Check for Drain Pump Failure
* Check the Inlet Valve for proper shut off
* Check the Pressure switch for proper operation
Feb 07, 2008 | AEG Lavamat 88840 Front Load Washer
Dishwasher fail on C3 (leak prevention system)
http://www.kunnig-elektro.de/reparatur/spuelen/aeg/zulauf2.html
in German ... anyway a couple of pictures :)
Dec 15, 2007 | AEG 24 in. Favorit 50730W Free-standing...
AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!!
Dec 10, 2007 | AEG L86800 Front Load Washer
I have a dishwasher that only works intermitently...
most fault codes are 10, 20,30.........90 not familar with c2. ther is a fault earky on in a prog where if the pressure switch does not retun to empty the prog stops and displays 10 or 30. the pipe leading from the front of the sump to the pressure switch can sag. tieing it up to stop the sag can cure this..
Feb 27, 2007 | AEG 24 in. Favorit 60870M Free-standing...
Dishwashers Logo
2,213 people viewed this question
Top AEG Dishwashers Experts
paul
paul
Kolbrun...
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
