Question about Frigidaire ATF6000ES Front Load Washer
It washes then it stops, then it read err - Frigidaire ATF6000ES Front Load Washer
    President:
  • 1,554 Answers
The control board has detected an error. Press any button to wake the machine then wait for 5 seconds. Press and hold the START/PAUSE and CANCEL buttons simultaneously then the failure code will appear in the display as an "E" followed by two numbers, a number and a letter or two letters as long as the buttons are held. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. Post back the code for further assistance.
Posted on Dec 29, 2010
What does it mean when the blood pressure cuff reads E1
If your blood pressure mahine is like those fro Walgreen's:
Walgreen's Blood Pressure Error Readings.
Error Codes
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
Mar 31, 2017 | The Health & Beauty
It won't stop running it is reading err 1
OK but with no make/model we can not look that up
Oct 29, 2015 | Washing Machines
Err code 3
From manual at pag.3:
err code 3Appears when pressure value did not increase during cuff inflation: 1) cuff is not fastened 2) air connector is not connected properlMake sure cuff tube is properly connected to monitor, cuff is securely fastened and exhaust rate is between 2 mmHg and 5 mmHg. Make sure air connector is inserted properly into tube and monitor.
refer to manual
Mar 05, 2012 | Lifesource UA 767 Plus Digital Blood...
How do I reset my Frigidaire Affinity Front Load Washing Machine? When I press a button the ERR code comes on and then it turns off.
My Fridgidaire Affinity front load washer has a ERR pause and I can't reset it. How do I clear this
Jan 17, 2010 | Washing Machines
Err code e10
it sounds like your brushes are gone you need new brushes in the motor
Dec 18, 2007 | Frigidaire GLTF2940ES Front Load Washer
Zanussi err problem
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Dec 10, 2007 | Zanussi FJS1225W Front Load Washer
Err pau
Press "stop" & "cancel" together for over 10 seconds to clear the display; and continue your..........
And rate me pl.......
Dec 01, 2007 | Frigidaire Affinity ATF7000E Front Load...
Err err err
Nov 16, 2007 | Frigidaire Affinity ATF7000E Front Load...
Err Err err err err pau
Nov 15, 2007 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire ATF6000ES Front Load Washer Logo
77 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
