Question about Asrock 880G Extreme 3 ATX MB AMD 52 GTs DDR Motherboard
I have an asrock 880g extreme 3 the doctoor debug is coming up 85 on the led displY, THE MONITOR IS IN SLEEP MODE AND IT WONT BOOT UP
  • scottraine66 Dec 29, 2010
    the graphics are on board and i reset the cmos and removed the ram and put them all back in still nothing
    Genius:
  • 1,288 Answers
Nvidia Graphics cards can trigger this problem, can you try swapping the graphics card and rebooting to safe mode to load the vanilla drivers (F8). If that works, could be issues with the card.
You might want to reset your CMOS to default as another test, to eliminate any issues there.
Finally, If you can get it to reboot using the OLD (original card) after resetting the CMOS, try running it with the standard drivers first, it that works, then it could be a driver issue
Posted on Dec 29, 2010
  • graeme ian hunter Dec 29, 2010
    The Code 85 points to a video issue, unless you are getting a message informing you that you have changed hardware (CPU)?. Where there is no video and it will not boot, the issue looks like it originates with the onboard graphics. You could try using a seperate graphics card as suggested, if you can lay your hands on one and see if that resolves the issue. However, if the board was under warranty, and given some of the comments I have read about this board on the internet, I would be very inclined to return it, as it is looking as though there is a fault
  • scottraine66 Jan 06, 2011
    Thanks i have sent the mobo back to aria they are going to check it and replace if needed but ty for all the help
    regards scotty
Asrock z77 extreme 4 not loading windows 7 boot with vista no audio dr.debug A2 &A6
http://www.asrock.com/support/faq.asp?id=334
GO TO SERVICES AND RESTART WINDOWS AUDIO.
OR I SUGGEST YOU TO UNINSTALL THE AUDIO-DRIVER.
FIRST GET A NEW ONE.
http://www.drivermax.com/
DRIVERPROGRAM.FREEWARE DO A SCAN.
Feb 15, 2014 | Asrock Computers & Internet
M15x gaming laptop screen wont come on after sleep mode or reboot. What can I do?
Looking at your last comment, it looks like you got it working??? Just an heads up, in the future, you might not want to put your laptop into sleep/standy mode while performing an update. If you lose power or have to do a hard shutdown you could corrupt the update and your PC might not boot back up.
Jan 09, 2013 | Dell Alienware M15x Gaming Notebook
My monitor won't light up
have u checked the internal fuse take the back off and look for a glass fuse? is the led lit? if Yellow led is on, means the monitor is in 'sleep' mode. There is no signal being sent from whatever it's connected to. If it's a computer, try checking the connection(s), make sure it's not come lose inside the computer, try if you can the computer on a different monitor or the monitor on a different computer.
Dec 05, 2011 | LG Flatron L1951S 19" LCD Flat Panel...
My computer was working fine and i turned it off to incert a stick of RAM but when i turned it on it didnt boot and the debug code light said 00 which means not used
pull the new stick and start up with out it. check that the new stick is the right kind and that it is compatible with the other stick and your board. also make sure you are using the right slots. some boards must have the memory in specific slots. you could also have gotten a bad stick of new memory, try booting with the new stick only
Jun 08, 2011 | Asrock 880G PRO3 AM3 AMD 880G HDMI SATA...
Monitor wont come out of sleep mode
One possiblility will be the failing power supply due to bad caps (leaking/bulging tops). You can take a look inside first before making the decison to buy a new one or not.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
May 16, 2010 | HP Q1859 18 inch Monitor
HP w2207 monitor keeps "going to sleep" then it will not come back on and says no input signal.
most times this is indicator of a video card problem, most times you try booting in to vga mode and see does it go to sleep. if it does not go to sleap you video driver is bad and needs to be reinstalled. if it does go to sleep it is usually video card issue. to boot in to vga mode turn ur pc off and once u press on to put it back on start pressing button F8 and advanced menu will come up and you have to choose boot in to vga mode. if this does not work same way go to safe mode with networking and reinstall video driver by going in to device manager.
Nov 27, 2009 | HP w2207 Monitor
The light is always yellow and the monitor wont turn on
Yellow led light means the monitor is in 'sleep' mode. There is no signal being sent from whatever it's connected to. If it's a computer, try checking the connection(s), make sure it's not come lose inside the computer, try if you can the computer on a different monitor or the monitor on a different computer.
Nov 22, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Gateway 2" monitor won't display
blown capacitors this can be fixed I can help or advise you how to do it but it will require soldering internal components.
Mar 04, 2009 | Gateway FPD2275W LCD Monitor
Benq 24" wont comes back after sleep mode
Try to install the OS once again.
If it turn up the same again then it may be the logical board problem.
Apr 12, 2008 | BenQ FP92W LCD Monitor
Asrock 880G Extreme 3 ATX MB AMD 52 GTs DDR Motherboard Logo
683 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
