Unable to close error message "Paper Jam" - Office Equipment & Supplies
  • murphy8586 Jul 07, 2008
    The printer is a Brother MFC DCP-130C Ive done everything you suggested, more than once. No result. Still burning bright like a beacon in he night !
  • murphy8586 Jul 08, 2008
    I have done all that Ajkil recommends - repeatedly - but with no success
    Sergeant:
    Champion:
  • 250 Answers
Double check that you have no small pieces of paper stuck in the printer that might have torn off. This happens sometimes and blocks a sensor or switch.
Posted on Jul 08, 2008
    Genius:
  • 2,035 Answers
If the paper is lodged too far into the printer and can't be removed:
Press the power button to turn the printer off.
Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
Close the front cover.
Press the power button to turn the printer back on.
Resend your document to print.
Ensure that:
The paper is a recommended paper for inkjet printers.
You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
The printer is on a flat, level surface.
The left paper guide is against the side of the paper.
You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
The left paper guide does not cause the paper to bend in the sheet feeder.
Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
Envelopes or the appropriate specialty papers are selected in the printer driver.
You are using a paper or envelope size supported by your printer.
Posted on Jul 07, 2008
  • Anand Kumar
    Anand Kumar Jul 10, 2008
    This is hard ware failure on the printer try getting it service if its out of warranty or if within warranty get done by the company.....
  • 13,433 Answers
Unplug the printer, inspect it for paper jams, take the printer apart as far as possible and clear any paper jams in it.
for more specific instructions I will need to know the brand and model of your printer.
Thank,
Ekse
Paper jam on screen will not reset
To clear the error message Paper Jam after you removed the jammed paper, open and close the scanner cover.
If you still receive the error message, a small piece of paper may be stuck inside your Brother machine.
Refer the below link for the steps to remove any ripped paper remaining inside your Brother machine:
still receive the error message Paper Jam after removed the jammed paper...
Apr 22, 2014 | Brother International Brother MFC-J4510DW
On a clx-6200 message says "paper jam 0-c=open/close door. what door is this?
It is telling you that there is a paper jam. Open the door, pull the jammed paper out, close the door, it should clear the message.
Apr 21, 2012 | Samsung CLX 3160fn All-In-One Printer
Unable to Clean 5A
The machine does not work due to a paper jam or some sensor problem.
Clear the paper jam, try to clean the sensor on the top of the printhead.
Mar 03, 2012 | Brother MFC495CW
I have a message on my display screen that says "unable to print 36" What does that mean and how do I fix it?
36 usually means that a paper is jammed. You will have to open it up and manually remove the paper.
Mar 22, 2011 | Brother MFC-845CW multi-function...
Hi, I've got an HP Photosmart D7160. It continually says "Paper Jam". Actually the error screen says something like "please remove paper jam and then press OK", but there is no paper...
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.get more help and information for hp printer support hope this helps you.
Thanks
Michel
Feb 21, 2011 | HP Photosmart D7160 InkJet Printer
Error message is " paper
Check for a tiny piece of paper or some toner that may be covering a sensor.
Jan 07, 2011 | HP LaserJet P2055d Printer
I am unable to remove all of the paper from the jam. it is at the back of the machine.
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Nov 04, 2010 | HP PSC 750 All-In-One InkJet Printer
Unable to print
I have a Brother MFC665CW and it has error message
"Unable to change 50" after paper jam. Paper is all cleaned
out of machine and still shows message.
cenprop@bigpond.com
Apr 08, 2010 | Brother Office Equipment & Supplies
74 people viewed this question
k24674
