Question about Philips HDRW720 DVD Recorder
DVD unit has stopped working - simply says no DVD - tried with several different DVD's and says the same. I know DVD's OK as I have another HDRW720 in another room.
    Sergeant:
  • 242 Answers
Dvd player lens problem, so change lens
Posted on Dec 29, 2010
Testimonial: "Thanks for info - can't do that myself - will try and get a replacement DVD unit. Best wishes"
Need to save Honeymoon recording but HDRW 720 won't save archive disc. How can I salvage my recording?
I am assuming that the unit turned off while you were using it because of power failure... Battery low.
The file is still there but it is corrupt and you should be able to retrieve it at least 90% of it.
I don't mind taking a look at it for you. we do have the hardware software needed to do the task and it is no charge if we cannot get back the file.
Tony
May 30, 2014 | Philips HDRW720 DVD Recorder
Tip
Factory Service Manuals for HDRW720 and many other devices available.
Factory Service Manual for HDRW720 and many other devices available. Purchace and download from https://www.completeservicemanuals.com/
on Jan 25, 2008 | Philips HDRW720 DVD Recorder
I have a philips hdrw720 dvd recorder. i cant play recordings anymore and i get a letter "C" on the video screen.. anyone know how to fix this? thanks
There are three things you can do that will eventually give you a working solution. Depending on the level of problem. Start with 1 progress to 3 until it works.
1. Use a cleaning disc. (one that use an alcohol based liquid)
2. If the cleaning disc does not solve it, you can use an ear bud, with some iso-propyl alcohol to clean the DVD lens on the drive directly. (you have to open the player and the drive)
3. The guaranteed working solution is to replace the DVD drive inside the player. This is quite a simple process, as most players use a standard IDE DVD-ROM or DVD writer.
You simply remove the face plate, (apply power to the drive, and press eject first) the tray will open. Unclip the tray face, and then with the tray open you can unclip the plastic face plate too.
Remove the old drive, and fit the new drive by reversing the removal procedure.
Once everything is assembled you should be able to watch DVD's again. If you can't find a cheap DVD drive locally, try ebay.
I have done this on over 50 players for my clients in the past. I use LG DVD roms and DVD writers for the DVD recorders, irrespective of brand.
Let me know how it goes.
Feb 28, 2010 | Philips HDRW720 DVD Recorder
Dvd recorder TV Guide will not work.
Contact the vendor of TVGuide onscreen. They can help troubleshoot the issue. You an contact them at Macrovision CE Support <ce_customer_support@macrovision.com>
Dec 30, 2009 | Philips HDRW720 DVD Recorder
Philips DVD hard drive recorder HDRW720 locks up
Do you have a disc locked up inside?
I found that there IS a manual release for the disc tray UNDERNEATH the unit. It is a sort of toggle lever that you have to slide to the other side and that releases the disc. The Manual does not even mention this manual release lever!
Also, it may be hidden or covered by a paper like cover.
GL
Mar 26, 2009 | Philips HDRW720 DVD Recorder
Output is snowy when unit is on
bad connection in cables somewhere
Oct 30, 2008 | Philips HDRW720 DVD Recorder
Cone of HDRW720 Hard Disk
In order to use this software you need motherboard with two IDE ports.
You have to use both primary IDE ports, HD must be single mode...
IDE1 Primary - Your HD
IDE1 Secondary - Don't use it
IDE2 Primary - Your HD
IDE2 Secondary - Don't use it
Because it was so long ago I don't remember exact details, and it takes time to reconfigure PC...
But if need help let me know, and I will get you step by step instructions...
May 26, 2008 | Philips HDRW720 DVD Recorder
HDRW720 will only do demo mode
The error code has a Nucleus Group and Number followed by an Error Code.
The Nucleus 2100 references
DS_HDD_Communication
Check the communication between the digital board and the hard disk drive by querying the device type of the device type of the hard disk.
The Hard drive 282206200034 is no $399.80 available from partstore.com which you can just drop in since it is formatted. If you can find a hard disk which is rare due to the small size no one buys, it can be formatted to just drop it in. You will need the hard drive ( 120GB ATA), the PC communication cable 312278590017 $22.75 and the Service DVD 312278590710 $36.96 which will allow you to format the hard disk for the unit. I would do this for you but you might have other problems with the system which can only be found with more diagnostics after the drive is installed. Or it could be a drop in and go.
For the unit which is stuck in trade (demo) mode,
Unplug the unit.
Simultaneously hold the Stop + Open close while plugging in the unit.
Apr 15, 2008 | Philips HDRW720 DVD Recorder
Pictures distorted play/record mode
Run the diagnostic software by unplugging the unit. Hold the Play while reinserting the power cord. Continue holding the Play until the diagnostic program is displays NUC XXXX where XXXX is a series of numbers. Once the diagnostics is finished it will pass or fail. To return to normal operation unplug the unit and reinsert the power cord after 15 seconds or so.
Mar 30, 2008 | Philips HDRW720 DVD Recorder
What do i need in order to record from my t.v. to the dvd player?
You can go to the manufacture's website and go to customer support or downloads, or if they have a search box, simply type in the model number and add manual to see if it appears (usually in a PDF file) or try the website www.retrovo.com that carries a lot of manuals. Again, in the search box, input your model number and manua for the appropriate PDF file.
Feb 10, 2008 | Philips HDRW720 DVD Recorder
Philips HDRW720 DVD Recorder Logo
158 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
