Question about AEG Freezers
AEG Electrolux model s75358kg3 Could do with a schematic of the freezer as fan appears to have either failed or iced up. Symptoms are freezer running ok fridge no cooling at all. Also holiday function is nor available
  • ian_prime837 Dec 29, 2010
    Hi
    This has not told me anything I didn't know or mention in my question To test fan I need to know where contacts are which means specific information re this model
  • 4,059 Answers
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp. The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it'll be the control.
Posted on Dec 29, 2010
  • AEG Master
  • 19,396 Answers
Hi.
The service manual for this unit is not available. From your description the problem is either the fan or the defrost system.
To test if fan has iced up you simply perform a complete defrost. If the fan restarts working, then it was blocked by ice. The damper fan motor rarely fails. For this reason you usually test other parts before going for the fan. The fan motor can be tested by energizing it directly (jumping its contacts), or by reading Ohms. A faulty temperature control can cause the fan not starting.
The problem is more commonly the defrost system. This part comprises the evaporator and it is located behing the freezer firewall. The function of the defrost system is preventing coils from freezing. When defrost system is defective you get no cooling and the compressor is usually quite busy most of the time.
In defrost system locate and replace the defrost thermostat. This is the part that most commonly fails. The thermostat can be tested reading Ohms at its terminals.
Here an example of the repair done on a different fridge: When the fridge is not cooling...
Regards.
Ginko.
The top two shelves are not freezing and the food on those shelves and that area of the door have defrosted. The bottom seems to be freezing. I can hear the fan running and do not feel any drafts from
Obviously that freezer is not achieved the required temperature. There are several reasons for that:
- Defrosting system is not working, which leads to accumulation too much ice on the evaporator that prevents heat transfer and reduces air circulation despite the fan is running.
- The problem with draining condensate after defrosting cycle which also leads to accumulation of ice.
- Leaking gas from the cooling system (reduced cooling capacity)
- Faulty compressor
Dado
Jan 05, 2015 | Electrolux Freezers
Freezer not get cold enough
Thermostat needs to be set
Jun 22, 2014 | AEG Freezers
Coils frozeup and iced on top shelf of freezer---did a defrost--when shut the door don't hear the shhhh sound-nothing blocking it and seal is good--light is on but won't freeze any food--threw out alot! ...
Defrost the unit totally so you can see no more ice, may take a day or more with door open, once done, restart the unit, check you can hear the fan running in the freezer, if not, replace fan unit, if you can hear it, the defrost timmer may have failed or the defrost element has gone. If the unit appears to work correctly, dont be fooled, the problem will return, if the unit does not work as it should, regas is required. Hope that helps.
Dont forget to vote for the solution, thankyou
Mar 04, 2011 | Frigidaire 13.7 cu. ft. / 388 liter...
I have a true tuc48-f freezer..Problem: Frost build up to the point that the doors freeze shut and I have to scrape the ice off. Also at time it make a rackety noise like the fan hit solid ice.
It seems you have diagnosed your own problem.
Check the defrost circuit. It appears your defrost cycle is not working.
Also,check the door seals closely.
A loose or broken door seal can contribute to these symptoms as well
Sep 17, 2010 | True TUC48FADA Freezer
Fridge/freezer. Freezer works great but fridge is
Air from the freezer is blown into the fridge by a fan, some new type frigs have electronic controls that open and close a vent to frig. the older ones have two vents in the frig from the freezer and when covered with frost or ice the air will not reach the frig. check for ice or just defrost the freezer if there is ice or frost, also check for food or plastic over vents in freezer. Also check that the freezer fan is running as these sometimes become blocked or defective motor.
Mar 07, 2010 | Electrolux Freezers
Electrolux premier eco freezer leaking. Water appearing on the floor. Ice building up inside the freezer.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help
Oct 11, 2009 | Freezers
Upright freezer not cooling adequately
Go to there website and see if you can find your model. You can also contact them from there.
http://www.aeg-electrolux.co.uk/node145.asp?CategoryID=2595
Also get yourself a stand alone fridge and freezer thermometer - leave it in for an hour -that will establish what the temperature really is which will help in diagnosing the cause.
Also trying unplugging it for 15 minutes so the display board loses power - then plug it back in - sometimes that will reset it.
May 04, 2009 | AEG 7.59 cu. ft. / 215 liter Upright...
Aeg fault codes
aeg santo fridge/ freezer
The fridge part of my appliance is not getting cold please help
Apr 13, 2008 | AEG 10.35 cu. ft. / 293 liter Upright...
Freezers Logo
390 people viewed this question
Top AEG Freezers Experts
Gil Shultz
Victor Nwachukwu
Victor Nwachukwu
AJMAL KHAN
Are you an AEG Freezer Expert? Answer questions, earn points and help others
