Question about Sony Micro Vault Classic 4GB USB 2.0 Flash Drive
Flash clé usb sony vaio
Not open and shows 0 memory
Posted on Jan 14, 2011
My Sony Vaio SVE15129CAB can't read Sandisk USB flashes
Are all your Windows Updates Current, up-to-date? What is the file/data format on the flash drive? If you open the Computer folder is the Flash drive there? On other Laptops what opens the data on the Flash drive? The software? Do you have the same software?
Apr 04, 2013 | Computers & Internet
I have 32 gb of Problem with the Chain Saws i have 32 gb of sony vaio flash i can,t format it from my computer. and when i want to format from cmd i see this error ((cannot open volume for direct access))
Make sure you have nothing that has the drive open. close all windows. Click start, then My Computer. Do not click on the flash drive.. but right-click on the drive.. then select format from that menu. If you are browsing a drive windows has a fit if you do anything like that with it open.
Apr 12, 2011 | Sony Micro Vault Classic 4GB USB 2.0 Flash...
Hi i have Sony vaio 32 GB flash disk it is good but when i copy a file into it it is good but when i remove the flash from pc and connect it again it is no file in my flash . please help me
Everytime you want to remove your usb flash disk, you have to safely remove it.In order to do that, you have to left clik at the bottom right of the screen at an icon that looks like a usb socket
as the image belows shows.Select then your usb disk that you need to remove , and after a verifying message that says you can remove it with safety, you can finally remove it.
Comment faire pour changer la combinaison d une serrure bouton simplex
English to French translationJ'ai trouv? cette instruction ailleurs sur ce site (merci ? pctuneup191):
PROC?DURES POUR CHANGER LA COMBINAISON DE S?RIE CIPHER SIMPLEX 1000 SERRURES
1.) ASSURER LA PORTE EST OUVERTE.
2.) Introduire la cl? CONTROL DF-59 ? l'Assembl?e de changement de combinaison (SUR LE DOS DE LA
PORTE) et d?visser le cylindre en tournant le CLE.
3.) Consid?rer que l'Assembl?e PLUG changer compl?tement hors de la porte.
4.) Tournez le bouton PORTE EN DEHORS dans le sens horaire jusqu'? ce qu'il s'arr?te, puis la rel?cher.
5.) PRESSE DANS L'actuelle combinaison FERMEMENT.
6.) Ins?rer la cl? de b?tons dans les roues MANCHON changement de combinaison. IL YA INSERT sur les neuf
Heures.
7.) Tourner la cl? CLE DOUCEMENT montre jusqu'? ce qu'il s'arr?te ? la position 12 heures. NOTE
Les encoches de combos LA MANCHE CHANGEMENT QUE le manchon est d?plac?.
8.) Tourner la cl? CLE ANTIHORAIRE RETOUR ? la position neuf heures jusqu'? ce qu'il s'arr?te.
Retirer la cl? CLE.
9.) Tournez le BOUTON DE PORTE EN DEHORS (tout le chemin, jusqu'? ce qu'il s'arr?te), puis rel?chez.
10.) Taper la combinaison en appuyant sur les boutons. Utilisez au moins trois chiffres et un
maximale de cinq ans.
11.) Tournez le bouton PORTE MONTRE UNE FOIS, tout le chemin, jusqu'? ce qu'il s'arr?te. HOLD dans cette position et
VERIFIER SI LE p?ne est r?tract?.
12.) COMMUNIQU? la poign?e de porte.
13.) Tournez le bouton PORTE DROITE One More Time ? la position STOP. ? ce stade, LE LOQUET
Doit pas se r?tracter sauf si vous utilisez la nouvelle combinaison.
14.) REINSERT la bouteille dans le dos de la porte en la vissant dans une montre avec la DF-59
KEY CONTROL (NE PAS TROP!)
Retirer la cl?.
Un Df-59 cl?s peuvent ?tre achet?es sur ce site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
La cl? de serrage (SMPBC201278 Simplex: SpannerWrench 9,00 $) vis?s peuvent ?tre achet?s sur ce site:
http://www.ckilock.com/Mpage18.asp
Vous trouverez un lien pour t?l?charger le manuel de votre mod?le sur cette page:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
Ce sont des fichiers PDF, n?cessitant Adobe Reader pour ouvrir. Il ya un lien sur la m?me page pour t?l?charger Adobe Reader.
Service ? la client?le peut ?tre contact? directement depuis ce lien:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Assistance technique ? partir de ce lien:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Bonne chance!
Sep 09, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
I insert a usb 4 gb flash drive and I get a message to insert it after I do. Why does this happen.
the usb driver might be corrupted. you will need to uninstall the usb drives. They are located in the device manager. once you uninstall the usb drives they will automatically reinstall. Then restart the computer and you should be fine.
Jan 19, 2010 | Sony VAIO Digital Studio PCV-RX860...
Sony VAIO USB2.0, 400GB (Memory Stick) Removable data storage
First of all...R u really sure that u r using a Genuine Sony Flash Drive????? Because if u r...there's no way u will lose ur DATA.Now there r a lot of Chinese stuff in the Market...that's what usually happens when u use chinese cheap stuff.
Jun 26, 2009 | Electronics - Others
Vaio 8gb flash drive
reformat it..... that should solve any issues
Sep 28, 2008 | Sony VAIO Digital Studio PCV-RX860...
Sony Micro Vault Classic 4GB USB 2.0 Flash Drive Logo
182 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
