Question about Canon PIXMA iP1600 Printer
Letter size is reduced.How do I correct it? - Canon PIXMA iP1600 Printer
  • Canon Master
  • 691 Answers
Please offer more information and be more specific about the exact problem and equipment you are using
Posted on Jul 07, 2008
How to copy legal to letter on copystar CS 4005i
Make sure your default settings are for AUTO paper selection and 100% magnification to start. That is the most common default settings. Then, under "Zoom" change to AUTO magnification and under PAPER SELECTION specify Letter (either landscape or portrait). Now when you copy a legal original (8.5" x 14") it will be reduced at 78% to fit it on an 11" sheet. An alternative is to use "X-Y" zoom. Now you can stipulate 78% for the "X" dimension and leave the "Y" dimension at 100%. You will want letter size paper to be feeding lengthwise (portrait). Now you can copy legals and the image is reduced top-to-bottom only, leaving it much more readable.
Mar 16, 2015 | Copystar Office Equipment & Supplies
I have Windows 7 op sys in my HP computer. My HP L7680 will now not print an Excel file on legal--reduces the size to letter. Help!
Software issue. Contact MS since HP will do nada for you since it is not a printer problem. Maybe your excel program is not really compatible with Win 7. Check it out.
Aug 23, 2017 | HP Officejet Pro L7680 All-In-One Printer
When printing a duplex booklet, the printout is reduced in size with larger margins than in original document. How can I get it to print regular size?
It happens when the documents is on A4 size and the printer is set to print on letter size (which is smaller in size). Hence the printer automatically resizes the prints which result in larger margins and print as compared to the actual document.
Therefore, when you print the documents (Press Ctrl+P) you have to select the paper (A4) from the print properties.
Hope it helps! Good Luck!
CreativeTECH
Mar 02, 2011 | Brother MFC-9840CDW Laser Printer
Hard Disk Partition
yes it is,first of all you need norton partition(not partition magic) then you can reduce the size of C drive, if you dont want to attach the size that you reduced you must create other drive f,g or other or the easy way when you reduce the size from C drive attach it to D or E.
Mar 15, 2010 | Computers & Internet
Reducing size of email attachments
you can simply use the compressors and winzip softwares easily available in the market..
Feb 13, 2010 | Microsoft Office Professional 2007 Full...
I want to copy a legal size document to letter size
when you place the letter on the document feeder manually select the paper tray with letter paper in it and auto enlarge.. you will find the enlarge/reduce button at the right side of the bottom icons on the display..
Nov 10, 2009 | Gestetner DSm660 Copier
HP PSC 2410 printing extremely slow
Hi
Thanks for using FixYa. The maximum speed of the printer is 8 pages per minute, which cannot be exceeded. This speed is measured using "Letter" sized paper. "Letter" is a U.S. standard paper size, which is smaller than European A4. Your print job may be very complex. Try the following:
  • Reduce the complexity of your document (reduce the number of multiple graphics, etc.).
  • Try a different graphics mode setting in the driver, under the finishing tab.
  • Try printing the document at 300 DPI.
  • If system resources are low, try printing with fewer applications running.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 09, 2009 | HP PSC 2410 All-In-One InkJet Printer
Konica 7022
If you have a server you can do this on the server, the clients will recieve the instructions.
In XP go to printer properties of your 4500 printer. On the General Tab.
Select Printer Preferences, on the tab Paper/Quality change the document size to Letter and paper type to auto select.
(If server) On server do the same in the Tab Advanced under Printing defaults.
Now you can print on Letter (8,5x11), format.
Kind regards,
Mark Peters
Field Engineer.
Nov 24, 2008 | Xerox Phaser 4500 Printer
Cannot reduce size from 11x17 to letter
The NP6551 is an analogue copier, using only mirrors and lenses. It has no way of rotating the image. If you want to reduce a 11x17 to a 8.5x11 both peices of paper need to be fed in the same direction, ie short edge first. Change one of your trays to LTR-R ('R' for Reduction) or feed the LTR paper in thru the bypass in the long direction. If you use te bypass you must specify the paper size as LTR-R, you cannot use FREE.
Jul 26, 2008 | Canon NP 6551 Black and White Copier
Faxes I send are reduced in size and have series of black line down right hand side.
If its reduced in size during transmit or copy then simply place a letter size document in the feeder and close the two sliders up to the sides of the paper. If you don't close the slider up to the paper it will go into auto reduction
Apr 27, 2007 | Canon LaserClass LC 8500 Plain Paper Fax
Canon PIXMA iP1600 Printer Logo
old marine
old marine
