Question about Refrigerators
I wish to replace the thermostat on a European Whirlpool ART 472/3 fridge freezer. This is a 70/30 top fridge/bottom freezer arrangement with the thermostat located right hand side of the fridge compartment. I have removed the thermostat dial, but cannot see any obvious means to remove the plastic thermostat housing. Please can you advise?
  • 3 more comments
  • Ron Beattie Dec 29, 2010
    The answer given that "Its fitted by screws and clips are holding it.This clips are to be un-clipped and screws needs to be removed"
    Does not really help when there are no screws nor clips visible around the plastic housing.
    Can you be more specific on the location of the fixing screws. Note this is for removal of thermostat/light fitting plastic housing surrounding the thermostat.
    The thermostat you are now refering to is the one located front top of the refrigerator and is not the one needing replacement.
    The one which I need to replace and as described earlier is located inside the refrigerator section on the right hand side.
    Maybe if you have diagram/instructions for this unit.
    Thanks and Regards
    Ron
  • Ron Beattie Dec 30, 2010
    Any update on last comment regarding position of thermostat ?
  • Ron Beattie Jan 01, 2011
    Any update?
    Can somebody please offer some assistance?
  • Refrigerators Master
  • 22,326 Answers
The plastic cover is clipped into the casing ,flip this out by squeexing a bit and pulling backwards then you will see the nut that holds the thermostat the next good bit is getting the probe wire out ,best of luck its not that difficult though
Posted on Jan 01, 2011
  • 5,370 Answers
Its fitted by screws and clips are holding it.This clips are to be un-clipped and screws needs to be removed.Also a thin knife will help to loosen the thermostat housing.This is the thermostat,which you have to remove:--- I wish to replace the - helpmech_28.jpg
------------------ Also click this link directly,to check more images of the part :--- http://www.espares.co.uk/part/fridges-and-freezers/whirlpool/art472/3-(856447215010)/p/1084/278/0/709510/208951/whirlpool-service-w4-frid.html ------------- This should help. Thanks.Helpmech.
Posted on Dec 29, 2010
  • raj somaiya Dec 29, 2010
    The thermostat which is located behind the refrigerator control knob.That panel from where you removed the knob/dial.Remove that panel.There are screws on the base and front.
    Click the link directly:---
    http://c.searspartsdirect.com/lis_png/PL..." target="_blank" rel="nofollow" http://www.searspartsdirect.com/partsdir...
    You have to see part number 1 that is panel.part number 2 is bracket.Part number 3 that is screw.Remove the screws the panel will get loose.This has to be done after you remove the thermostat dial/knob.You have removed so now remove panel,.Part number 4 is light switch,part number 5 is light bulb,.Part number 7 is screw and part number 8 is plug.And part number 9 is thermostat.Part number 10 is also screw.You have to remove part number 10 to get part number 9 which is thermostat.
    Check the diagram and remove the screws,this should help.Thanks.Helpmech.
Ice lump build-up on left side of the lower back panel inside the fridge section of fridge freezer. Compressor is on continuously. Any help appreciated. Thank you.
Check the operation of the thermostat. Try raising the temperature og the refrigerator side and see if the compressor stops.
Oct 30, 2017 | Whirlpool Refrigerators
My whirlpool 472/r,freezer working but fridge not,any ideas,thanks
You either have an iced up evaporator coil (found in freezer) due to a failure in the defrost system: evaporator defrost heater, defrost thermostat, or a failed evaporator fan motor.
May 28, 2015 | Whirlpool Refrigerators
Neither the refrigerator or freezer temperature controls work. Can't adjust them and food is freezing in the refrigerator.
Sounds as though the thermostats have both gone. Before you replace them remove the mains plug. Fridge is easier than the freezer. The wire on the freezer runs under the top shelf usually. Good luck
Nov 24, 2013 | Whirlpool GI5FSAXVY Stainless Steel ...
I have the same problem in my freezer. Water is freezing in the top. I opened the back panel and found a half inch hole with a white plug in it, It looks like it was there on purpose. There is a hose that...
On fridges with cool wall technology, the function of the hole is to allow water which condenses on the back of the fridge to drain into the tray at the back of the fridge (on the outside) where it evaporates. It seems like this is the arrangement that you have.
Mar 04, 2011 | Whirlpool Refrigerators
Whirlpool refrigerator and freezer problem. a cup was place in the refrigerator to catch the percipitation coming from an inlet from the freezer. Which they are two inlets located in the center back of the...
It sounds as though you have frost or ice buld up under the panel in freezer compartment.Remove the 4 screws in freezer and 1 green ground wire.Inside you may see ice or frost buld up.Some causes are-Your drain tube may have a obstruction in it.It is located on center rear of freezer compartment.And if you pull fridge out and remove bottom rear panel you will see a plastic tube going into a drip pan.Pour hot water in the freezer and use hair dryer to defrost till water drians to bottom rear of the fridge.After you defrost the freezer cheak the bimetal defrost thermostat cliped on condensor see if it is balged on top where the wires go into thermostat.If it is you will need a bimetal defrost thermostat for it.If not cheak your defrost timer in can be locted around the temp control in fridge or under kickplate on bootom front of fridge.Advance the timer with a flat head srew driver look close it there will be a hole around light or control panel turn till fridge turns off.the element should turn on >if those @ things do not work you may need a thermostat control If you have electronil controls you may need a new board
Mar 17, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Greetings! My Whirlpool 21 is not cooling on the bottom, but the fridge is OK. Art
I do not understand your question because your note says it is a top freezer, but the fridge is ok?
The bottom section IS the fridge on this type.
May 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
We have a whirlpool freezer on top but the bottom of the fridge is freezing
Set both freezer and fresh food controls to their mid position.
If after 24 hours the temp is still too cold replace the thermostat aka cold control.
Feb 21, 2009 | Whirlpool ED2FHEXN Side by Side...
Whirlpool top freezer bottom fridge
check if compressor is running if no check thermostat , bypass thermostat if comp starts change thermostat. if comp does not start call repair man as comp will have to be changed, major operation.
If comp is running OK then check evap fan motor
Oct 16, 2008 | Whirlpool ER6AHKXPQ Top Freezer...
Refrigerators Logo
293 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
